+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 20
Thread: beginner: hopefully simple question about regulators
  1. #1
    nyoo Newbie
    Join Date
    Feb 2008
    Location
    Boston, MA, USA
    Posts
    57
    Default beginner: hopefully simple question about regulators
    Hopefully a simple question. I'm still not comfortable reading the datasheets without an advisor. If somebody could please advise me, I would be grateful.
    I have a pump which requires 12VDC, 1.4A.
    I want to power the pump with a wall adapter (what some folks call a "wall wart") that gives 20VDC 1.0A.
    Now, there is a regulator called an LM7812, that will give a regulated 12VDC output. The headline on the datasheet (from Fairchild) describes this component as a "1A regulator". But later, the datasheet claims a maximum 2.2A peak current.
    If I put 20VDC 1.0A into an LM7812, do I get 12VDC 1.6A out?
    Thanks for your help.
  2. #2
    kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    Quote Originally Posted by nyoo View Post
    No, you'll get 12V @ 1.0A output with 8 watts of heat dissipated in the 7812.
    The easiest solution is to find a 12V 2A wall wart.
  3. #3
    Willbe Good Willbe Good Willbe Good
    Join Date
    Aug 2008
    Location
    MD
    Posts
    1,238
    Might burn up both the pump and the adaptor
    Not continuously.
    But from http://www.hosfelt.com/
    you could buy an
    "adaptor", which is really a
    12 VCT 3 Amp (6-0-6) Power Transformer
    for $8.99, it's part number is 56-192
    and four
    Diodes, 1N5401, at $0.12 ea.
    and build yourself an unregulated supply that should be able to power this pump.
    Hosfelt has wall transformers but they don't go up to 1.4 A.
    You could also get two of their
    12 VDC @ 800 mA Adapter $US 3.25
    Mfg. - DV-1280
    2-1/4" x 1-7/8" x 2-1/8"
    Input: 120 VAC, 60Hz, 16 watt
    Output: 12 VDC @ 800mA
    The enclosure and the 6ft cord are
    black. Center is positive for polarity.
    Right angle coaxial jack.
    OD - .215", ID - .082"
    part number 56-922
    and wire up some kind of current sharing arrangement with two 0.5 ohm 1/2 w resistors, but it's not very elegant.
  4. #4
    RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent
    Join Date
    Oct 2005
    Location
    BC, Canada
    Posts
    1,448
    Blog Entries
    1
    The difference between the 1A and 2.2A figures is mainly that 1A is the guaranteed minimum that it will deliver while 2.2A is not. It isn't clear but I suspect that the 2.2A peak is measured for a short duration, not steady state. You cannot rely on that 2.2A at all times.
    This series of regulator works a lot like a smart series resistor. By this, I mean that all it does is put just enough resistance in series with the power supply line to drop the voltage from whatever you put on the input to 12 volts. By smart resistance, I simply mean that the regulator varies this resistance so that it maintains 12 volts at the output regardless of the current drawn through it.
    If you use this regulator, you will find that the amount of current you can get out of it in your application will depend on how hot it gets. The amount of power turned into heat in the regulator is equal to the current passing through it multiplied by the voltage drop across the input to output path. If your wallwart is indeed able to push out 20V at 1.4 amps (more on that later) then the regulator input voltage will be around 20 volts and the output will be 12 volts. So the regulator must dissipate 8 x 1.4 = 11.2 watts.
    Now, to figure out how this will affect the regulator, we must look up the Thermal Resistance Junction -Air and I find the value there to be 65 degC/watt. This means that the junction temperature will go up by 65 degrees C for every watt the device must dissipate if you attach no heatsink. In your case the temperature rise will be 11.2 x 65 plus the ambient temperature, which is way way above 125 deg C which is the maximum allowable for this device's junction. So what will happen is that the internal thermal shutdown circuit will turn off the regulator's output because it will get smoking hot. The solution to this problem would be to attach a substantial heatsink. Let's say, for example, that you bolted the regulator IC to this heatsink:
    http://www.aavidthermalloy.com/cgi-b...=530002b02500g
    This heatsink has a rating of 2.6 degC per watt when relying on natural convection (open air). To get the junction to ambient thermal resistance we add this value to the LM7812 Thermal Resistance Junction-Case which is 5 degC per watt. So the net is 7.6 degC per watt. Your junction temperature will get up to 110 deg C (85 degC plus ambient of 25). This is still below the absolute max rating of the regulator and so it should work OK. The heatsink will get quite hot to the touch.
    The last problem is that wall wart. Usually DC wallwarts are not regulated and they have some internal resistance, so they are usually rated for voltage at their rated load. This means that your wall wart will probably deliver more than 20 volts when you are pulling less than 1.0 amps and less than 20 volts when you are pulling more than 1.0 amps. This may help keep your LM7812 a little bit cooler than our prediction above. But at that amount of current, the wallwart will likely overheat. This is bad.
    RadioRon
  5. #5
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,067
    What does it say on the adaptor name plate?
    Are you sure it can provide enough current?
    Is 20V what you measured with no load connected?
    It's possible that the output of the adaptor will drop to 12V when fully loaded so no regulator is required.
    if I know the answer.
  6. #6
    nyoo Newbie
    Join Date
    Feb 2008
    Location
    Boston, MA, USA
    Posts
    57
    Hmm, I thought this question was going to be simple.
    kchriste, thanks for the warning. I will give up on the 20DC and LM7812 idea. Clearly, it will result to fire and it will not result in a working pump.
    Willbe, thanks.
    I see the 12 VCT 3 Amp (6-0-6) Power Transformer on the hosfelt site, but it's "temp out". What's the 6-0-6 mean? The four diodes you mention, are you thinking of a bridge rectifier?
    I like better your other "not elegant" arrangement, as I already posess several 800mA 12VDC wall adapters. Can this really be done? Please could you sketch out for me how I would join the two adapters' output with two 0.5 ohm 1/2 w resistors?
    RadioRon, thank you very much for some basic electronics. I now understand the importance of reading the fine print around Thermal Resistance Junct - Air.
    Hero999, the plate on the side of the wall adapter says "Output 20VDC 1.0A". I haven't measured anything with a voltmeter yet.
  7. #7
    Join Date
    Aug 2008
    Location
    MD
    Posts
    1,238
    I took it to mean it's 12v center-tapped.
    Yes, a full wave bridge.
    If you don't use the 0.5 Ω resistors and just put both adaptors in parallel, + to + and - to -, you'd get 1.42 A @ 12.2 v into your motor (see Thevenin voltage and resistance assumptions underlined below).
    Try it without the resistors. If you get 12-13v across your motor you'll probably get a satisfactory motor lifetime.
    Otherwise, the positive output lead of each 12v adaptor goes to one end of a 1/2 Ω resistor. The other end of one resistor connects to the other end of the other resistor and connects to the + terminal of the pump, and the adaptor negative leads connect to the pump negative terminal.
    Assuming each +12v @ 800 mA supply is actually a +14v supply with an internal 2.5 Ω resistance, you should then get 1.39 A @ 12v into your 12v/1.4 A = 8.6 Ω pump motor.
    You can measure the voltage drop across each 1/2 ohm resistor to verify equal current sharing.
  8. #8
    eblc1388 Excellent eblc1388 Excellent eblc1388 Excellent eblc1388 Excellent eblc1388 Excellent
    Join Date
    Jan 2005
    Location
    UK
    Posts
    2,226
    the 1.4A is the rated pump running current.
    Usually it will need a few times more than that to start running.
    L.Chung
  9. #9
    nyoo Newbie
    Join Date
    Feb 2008
    Location
    Boston, MA, USA
    Posts
    57
    Willbe, I measured the no-load voltage of the 12VDC wall adapters. It's wanders about 14VDC. Does that meet your assumption "Assuming each +12v @ 800 mA supply is actually a +14v"?
    eblc1388, you must be correct that the initial start-up of the pump will require more than 1.4A current. Does that mean the proposed solution -- two 800mA wall adapters with their positive leads tied together -- will not work? Or is there some compensating "wall adapter magic" for the start-up load? Could I use three wall adapters, tied together as Willbe suggests? Could I add a capacitor for the start-up event? (But please let me emphasise my "beginner" skill level with electronics.)
  10. #10
    Join Date
    Aug 2008
    Location
    MD
    Posts
    1,238
    I somehow wasn't able to write correctly that when you parallel adaptors, measure the current delivered by each to make sure the 800 mA rating is not exceeded in any one of them.
    If it is then use a low value resistor in series with that adaptor to lessen it's current share and put more burden on the other adaptor.
    If the pump needs a higher startup current you can parallel more adaptors, while checking for proper current sharing.
    There seems to be an optimum value for the current sharing resistor. If it's too low you can't equalize the current properly and if it's too high there won't be 12v available to run the motor.
    And if you used a 20v source, you'd need an (20-12)/1.4 = 5.7 Ω voltage dropping resistor, and this wouldn't be good since motors usually like to be driven from a "stiff' (low impedance) voltage source, because they demand more current as the load increases.
  11. #11
    Join Date
    Aug 2008
    Location
    MD
    Posts
    1,238
    Yes; see below
    see below
    see below
    So Voc = 14v and Vload @ 0.8 A = 12v. (14-12)/0.8 = 2.5 Ω internal Thevenin equivalent resistance for each wall adaptor.
    Let's say the pump motor resistance during startup is 2 Ω, about 5x lower than the normal apparent resistance [due to the back emf generated by a running motor].
    You can confirm the startup resistance with an ohmmeter. Rotate the pump shaft and take a reading with the shaft stationary, repeat this a few times, and average the ohm value.
    Two of these wall adaptors in parallel look like a 14v supply in series with 2.5/2 = a 1.25 Ω resistor.
    So the startup current draw will be 14/(1.25 + 2) = 4.3 A and the voltage across the pump will be 2 Ω x 4.3 A = 8.6 v. The pump may start under these conditions.
    If the pump does start I'd check how close you are to not starting by putting a low value resistor in series with the motor. 10' of #30 or 1' of #40 AWG is 1 ohm.
    Or, see if it will start when using only one adaptor.
    If you wanted the 4 A startup surge supplied by a capacitor, assuming a 1v drop during startup giving 11 volts across the motor [assuming the pump motor has its own on-off switch] and a 1 second startup period, with C = I*(ΔT/ΔV), this is C = 4*(1/1) = 4 Farads.
    It's probably cheaper to parallel several wall adaptors.
    If you ran the pump on one adaptor, once running the pump would draw 14/(8.6 + 2.5) = 1.26 A and have 1.26*8.6 = 10.8 v across it.
    There would be (1.26/0.8)^2 = 2.5x the normal heat dissipation in the adaptor, so the adaptor wouldn't last very long.
    Startup current would be 14/(2 + 2.5) = 3.1 A and startup voltage would be 3.1 x 2 = 6.2 v. The pump might not start with this low voltage.
  12. #12
    nyoo Newbie
    Join Date
    Feb 2008
    Location
    Boston, MA, USA
    Posts
    57
    Willbe, thank you for the detailed explanation of how the low value resistor is for limiting one (or the other) adapter's share of the current. I think the fault is on my side; I somehow wasn't able to hear correctly what you were sketching.
    It seems like the Ohm's Law math handles eblc1388's concern: assuming 2 ohms, 14/(1.25 + 2) = 6.2 A. Therefore, two adapters in parallel will handle the surge on start-up of a 1.4 A pump. The specification page for this particular pump states that the pump requires only a 2-amp fuse. Does that confirm it?
  13. #13
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,067
    You could PWM the motor at 60% duty cycle.
    The adaptor can probably handle 1.4A surgers at this duty cycle so it wouldn't be a problem.
  14. #14
    nyoo Newbie
    Join Date
    Feb 2008
    Location
    Boston, MA, USA
    Posts
    57
    I'll take it that the 2-amp fuse in the pump manufacturer's spec sheet means the two-adapter solution will survive the start-up current. Can someone please confirm?
    If you all have the strength to go back to the point where there was
    - an "elegant" solution from which I diverted you, and
    - a "not elegant" solution which we pursued....
    At my local Radio Shack I see, at hosfelt price's, a 12.6VAC 3A power transformer. After the discussion about start-up current for the pump motor, is that elegant power transformer still a viable solution?
    The transformer has 3 (black, black, and yellow) wires facing the 115VAC mains, and 2 (black and yellow) wires facing the 12.6VAC. Also for sale was a 4A 400V full-wave bridge rectifier for about $2; however, it only has 4 connection points. Do I connect the yellow mains wire to earth/ground, and there's no polarity in the others?
    At http://www.kpsec.freeuk.com/powersup.htm, they mention a smoothing capacitor. Using their calculation, I get 2uF. Does that sound right?
    This solution will cost. The two-adapter solution will cost me nothing (bless the inventor of yard sales). Is there an upside to this power transformer solution?
    Thanks again.
  15. #15
    Join Date
    Aug 2008
    Location
    MD
    Posts
    1,238
    Two adaptors will handle 1.6 A steady state current which is >1.4 A. I doubt that the short-duration startup current will hurt the adaptors.
    Is it a slow blow or fast blow fuse? If you can find trip curves for the fuses you can approximate the startup current. Generally a 2 A fast blow fuse can handle 4 A for one second.
    The + - markings are the DC output of the bridge; the ~ marking is the AC input.
    I wouldn't give Radio Shack a single penny.
    I don't think you need one for a motor. It will raise the DC voltage across the motor somewhat.
    The internal resistance of the transformer might be 1/2 that of the two adaptors.
    Thanks again.
    Measure and see how the pump behaves with one, two and three adaptors at the limits of what will be demanded of the pump. Hopefully you can then predict what the pump will do with a heftier transformer.
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. Video: Ohm's Law Applied to Simple Circuits (Beginner)
    By ElectroMaster in forum General Electronics Chat
    Latest: 23rd January 2008, 02:56 AM
  2. question on voltage regulators
    By ant9985 in forum General Electronics Chat
    Latest: 26th September 2005, 02:47 PM
  3. Simple Beginner Electrical Circuit Projects
    By Fei in forum General Electronics Chat
    Latest: 23rd January 2005, 11:45 PM
  4. very very simple request for a very very beginner...
    By sonaiko in forum General Electronics Chat
    Latest: 8th December 2004, 06:46 PM
  5. How to make simple LED color thingo.. (beginner)
    By tim_l_012 in forum General Electronics Chat
    Latest: 14th June 2003, 12:59 AM
Tags for this Thread
