+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 27 of 27
Thread: Safety Question!
  1. #16
    jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent
    Join Date
    Jun 2006
    Location
    Cleveland, OH, USA
    Posts
    1,589
    Quote Originally Posted by Larry4911 View Post
    Halon is also much more poisonous than Co2.
    But obviously not for the same reasons.
    Larry
    Can you provide something more than an opinion on that?
    John
  2. #17
    Larry4911 Newbie
    Join Date
    Aug 2008
    Location
    Devon
    Posts
    54
    Well, alright maybe not as dangerous from asphyxiation but it's definitely toxic.
    I have designed and installed halon systems for commercial premises and the requirement was to allow 30 seconds, after the alarm sounds, to evacuate the room before the release of the halon gas.
    This link may help with this question.
    http://www.trivenimarketing.com/ceas...chemistry.html
    Larry
    Confucius says: "One in three is a teacher."
  3. #18
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,853
    Blog Entries
    13
    Larry
    hi Larry.
    It depends which of the Halon gas types you are working with.
    Extract:
    Halon flooding systems do NOT displace enough air so as to be
    a hazard of suffocation. CO2 systems, by contrast, lower the oxygen
    content of the room to a level which supports neither combustion nor
    human life.
    http://yarchive.net/chem/halon.html
    Link to my Articles: http://www.electro-tech-online.com/a...icgibbs-55450/
  4. #19
    Larry4911 Newbie
    Join Date
    Aug 2008
    Location
    Devon
    Posts
    54
    Very true Eric.
    Larry
  5. #20
    Join Date
    Jun 2006
    Location
    Cleveland, OH, USA
    Posts
    1,589
    Moreover, CO2 at relatively low levels stimulates the respiratory system to hyperventilate. That is discomforting in itself, and if continued can lead to respiratory alkalosis, which is quite dangerous.
    Bottom line, next time I have an on-board fire in an aircraft, I will put it to a vote of the passengers -- would you rather have a little discomfort or be burned to a crisp?
    It is not a question of something one does as part of every flight. It is done to save lives in relatively rare circumstances. The approved Halons (and maybe Halotron) are the best things we currently have for that purpose.
    BTW, the concept that a pressurized airplane is like a closed bottle is a bit misleading. The pilot can control the control the ratio of outside air to recirculated air.
  6. #21
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,853
    Blog Entries
    13
    Quote Originally Posted by jpanhalt View Post
    As a side issue, which I am sure you are aware of, carbon monoxide does not stimulate the respiratory system, so a person is unaware of the danger until its too late and they passout.
    BTW: I would also opt for the fire extinguisher being used onboard.
  7. #22
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,026
    Quote Originally Posted by eblc1388 View Post
    I for one would support the banning of CO2. Don't hold your breath though.
    Sure. All you need to do is ban the use of all hydrocarbon fuels and coal. Piece of cake. Of course the increase in the use of horses to replace all the cars could lead to another kind of odoriferous pollution.
    Carl
    Curmudgeon Elektroniker
  8. #23
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,026
    Quote Originally Posted by ericgibbs View Post
    That's true. But are you confusing carbon monoxide (CO) with carbon dioxide (CO2)?
    Carl
  9. #24
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,853
    Blog Entries
    13
    Quote Originally Posted by crutschow View Post
    No I am not.
    Carbon Monoxide CO, is colourless and odourless.
  10. #25
    Join Date
    Jun 2006
    Location
    Cleveland, OH, USA
    Posts
    1,589
    Interesting concept. Consider this: horses eat hay, which is cellulosic. That is, like sugars C6H12O6. In other words, the carbon is partially oxidized already. Now, assume your horsey converts that to energy by oxidative metabolism (you hope). That gives C02!
    It is somewhat less efficient than a good IC engine overall, and in terms of CO2/BTU* is considerably more (i.e., bad) than a good engine burning a fully reduced fuel like gasoline or diesel. So much for horse sense. It will make the "problem" worse for the same amount of power.
    John
    *Almost wrote horsepower, but I know how you Brits like your units.
  11. #26
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,853
    Blog Entries
    13
    John
    hi John,
    Horsepower is good, I'm comfortable with 33,000 ft-lbs/min.
    An American researcher recently did a 'carbon footprint' calculation for the American Cheesburger,,,
    its a staggering 200 million metric tonnes of CO2 per annum.
    He did a full audit of all it takes to produce the burgers.!!!!
  12. #27
    Join Date
    Jun 2006
    Location
    Cleveland, OH, USA
    Posts
    1,589
    hi John,
    Oh, sh*t, too. Due, of course, to our inefficiencies.
    John
+ Reply to Thread
Page 2 of 2
First 1 2
  1. Arc Welding Safety First :)
    By blueroomelectronics in forum Chit-Chat
    Latest: 28th November 2007, 08:16 PM
  2. Safety Policy
    By Khalid57 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 10th May 2007, 02:52 AM
  3. Transformer safety
    By Dr.EM in forum Chit-Chat
    Latest: 8th November 2006, 02:12 PM
  4. Car mmobiliser safety
    By SimonW in forum Micro Controllers
    Latest: 5th February 2006, 02:46 AM
  5. Cmos Safety
    By ElectroGeek_87 in forum Micro Controllers
    Latest: 3rd April 2005, 09:53 AM
Tags for this Thread
