Old 24th August 2008, 07:33 AM   (permalink)
Interesting paper.
http://opiod.01www.com/asa_2005/rcl_.../126_Gross.pdf
Forget injuries, never forget kindnesses.
Mikebits is offline
Old 24th August 2008, 07:36 AM   (permalink)
Originally Posted by Claude Abraham View Post
The transformer issue has been refined and optimized ad nauseum for over 125 years. There isn't much to discuss. BR.
How wrong you are! In fact magnetic amplifiers might make a comeback and magnetism itself is far from being fully understood.
"The magnetic amplifier is important to many phases of naval engineering because it provides a rugged, trouble-free device that has many applications aboard ship and in aircraft. These applications include throttle controls on the main engines of ships; speed, frequency, voltage, current, and temperature controls on auxiliary equipment; and fire control, servomechanisms, and stabilizers for guns, radar, and sonar equipment."
http://www.tpub.com/content/neets/14.../14180_131.htm
Chumly is offline
Old 24th August 2008, 08:01 AM   (permalink)
As far as I am aware, they have never gone away..
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 24th August 2008, 01:53 PM   (permalink)
Originally Posted by Mikebits View Post
Thanks for that Mikebits. Kind of makes my point really.
Oh, and thanks for editing your previous post Chumly.
The email I got was:
Bull crap! All things being equal in that we are talking about the same voltages and currents vis-à-vis RMS equivalence, then AC has more transmission losses than DC. Clearly you have never heard of AC effective resistance.
I'm not sure why you felt the need for rudeness.
Yes, there is a lot of loss in AC power lines but if you read the link Mikebits posted you may understand why I was correct in what I said.
Larry
Confucius says: "One in three is a teacher."
Larry4911 is offline
Old 24th August 2008, 02:23 PM   (permalink)
Oh, and Edison later patented the electric chair in order to show the danger in AC transmission. Just thought you might like to know.
Larry
Old 24th August 2008, 04:56 PM   (permalink)
Not really true - there was an ongoing battle between Edison and Westinghouse - one DC and one AC. Both were trying to prove the others system was the most dangerous - including various barbaric displays in the streets. The invention of the electric chair was just another stunt to try and discredit the rivel system.
There's even a film about it, which is quite interesting.
Nigel Goodwin is online now
Old 24th August 2008, 06:03 PM   (permalink)
I changed it as soon as I realized that I posted before I editing.
I most often start with putting down general thoughts (sometimes pretty wild!) then editing them, but in this case I copy-pasted without edits as I half-asleep. Naturally I changed it very shortly thereafter.
Nope you are still incorrect when you said "The reason AC is used is precisely because it has less loss........"
As discussed you do not understand AC Effective Resistance.
Chumly is offline
Old 24th August 2008, 06:15 PM   (permalink)
Here is the definition of the word comeback: "A return to formerly enjoyed status or prosperity" and in that context they are not as popular as they once were and my post has merit.
Understand that the word comeback does not infer that the concern in question has "gone away" as you suggest above.
As discussed I said "magnetic amplifiers might make a comeback" and yes they were more popular by default as the alternatives were fewer!
Wiki says and I concur:
In later years, improved vacuum tubes, followed by the transistor, would come into play for the production and regulation of high-power AC and radio waves. Recently, however, a resurgence in the interest and applications of the magnetic amplifier is resulting in new uses for this venerable technology.
At one time, magnetic amplifiers were considered as an alternative to vacuum tubes because of their rugged construction, high reliability, and lower working voltages. Consequently, vacuum tubes had a definite lifespan due to heater filaments that eventually burned out over time, or a loss of vacuum resulting in potentially-destructive arc-overs within the tube.
Magnetic amplifiers were used early on to control large, high-power alternators by turning them on and off for telegraphy or to vary the signal for voice modulation. However, the alternator's frequency limits were rather low to where a frequency multiplier had to be utilized to generate higher radio frequencies than the alternator was capable of producing. Even so, early magnetic amplifiers incorporating powdered-iron cores were incapable of producing radio frequencies above approximately 200 kHz. Other core materials, such as ferrite cores and oil-filled transformers, would have to be developed to allow the amplifier to produce higher frequencies.
http://en.wikipedia.org/wiki/Magneti...fiers_(history)
Chumly is offline
Old 24th August 2008, 06:39 PM   (permalink)
Thanks for the history lesson, but I was one of the engineers back in the 1950 and 60's working on industrial mag amp systems...
I have no need to read Wiki on this occasion.
Eric
PIC tutorials:
Old 24th August 2008, 07:08 PM   (permalink)
Fair enough, do you thus think the definition of comeback and the subsequent viewpoint to be incorrect?
In any case, and outside of such silliness, if you have any info in regard to the topic at hand, I would be more than pleased to read it and respond in kind.
Chumly is offline
Old 24th August 2008, 07:14 PM   (permalink)
I would be thrilled if you could locate that as per YouTube or otherwise. In fact any videos on the pioneers of power distribution / power generation would be great!
Much thanks!
Chumly is offline
Old 24th August 2008, 07:20 PM   (permalink)
In any case, and outside of the silliness at hand, if you have any info in regard to the topic at hand, I would be more than pleased to read it and respond in kind.
There is no silliness or confrontational intent.
But with ref to Mag Amps you are pushing on an open door.! I agree with you.
I cant say it any plainer than that.
My usage of 'comeback' is that 'something' that has gone out of fashion/use and is now coming back into use, as you have stated the Mag Amp is still in service, so how can something make a comeback if it hasn't gone out of usage.
Eric
PIC tutorials:
Old 24th August 2008, 07:37 PM   (permalink)
Much thanks!
I also saw that TV documentary.
Eric
PIC tutorials:
Old 24th August 2008, 07:39 PM   (permalink)
......so how can something make a comeback if it hasn't gone out of usage.
Ah....because I use the word in the relative sense and not the absolute sense, as such my text indicates this context.
I can't be responsible should you wish to apply the word outside the context of my text! Well I could take said responsibility but I won't (insert punchline).
I'm off the Costco to buy some stuff......
Chumly is offline
Old 24th August 2008, 09:37 PM   (permalink)
That's what I said, basically.
Larry
Transformers Question Tsuebo General Electronics Chat 2 13th January 2008 09:43 PM
transformers danielsmusic General Electronics Chat 5 24th July 2005 07:46 PM
AC transformers Teletech General Electronics Chat 11 19th February 2005 11:47 PM
Transformers cduleck General Electronics Chat 4 11th February 2005 12:19 PM
LED and Transformers question computer Electronic Projects Design/Ideas/Reviews 4 22nd December 2004 10:19 AM
