DC caused too many fires and that's why it's not used in transmission lines. Larry | ||
| rezer, I'm sure it will depend on 10 types of takers. But I'll cast my vote for AC being safer. But make no mistake, both can kill you easily. Your heart only requires 35mA to make it on or off, depending on its current state. | |
However my point was DC is much more likely to cause fires and sparking than AC at the same currents. Larry | ||
| [quote=Larry4911;339846]I don't know where you got that titbit. But it only takes 6mA AC across the heart to stop it. I think you mean 35ma between arms maybe. However my point was DC is much more likely to cause fires and sparking than AC at the same currents. Larry[/QUOT Ooooooh, I see Muhammad89
__________________ When you Teach, You Learn Twice! | |
| At the same potential and impedance, the safety concerns for AC or DC should be considered equivalent. Respect both as neither care a bit about your safety Lefty
__________________ Measurement changes behavior | |
| It's also depending on the frequency of the AC voltage if the frequency is close to man's avarage heart beat rate (60 a 70 Hz) than the chance it will disturb the heart beat is pretty big and more lethal than just a DC voltage with the same values of course it starts all about 63V or higher (that's what I learned on school ) i normaly say every thing lower than 48 Volt is considered safe (not lethal) you still can burn your self and have a not so good time if you are a conductor for many amps at that voltage Robert-Jan | |
__________________ "Remember, you're special.....just like everyone else." Last edited by rezer; 24th August 2008 at 11:04 PM. | ||
DC is used for various reasons: penetration, choice of positive or negative, easier arc control and a greater selection of rods are some. However, AC is still used and is still available on a lot of stick machines--it's easier to build an AC welder, and you don't have as many problems with arc blow. AC arcs just fine. Ever seen the sparks in a power outlet when you unplug a fan while it's turned on? Torben
__________________ Curiosity was framed. Ignorance killed the cat. | ||
This is interesting reading: http://en.wikipedia.org/wiki/Tesla_c...ctrical_safety Whether AC or DC is worse, I don't really worry about. I'm with Leftyretro--treat it all with respect. Even if it won't kill directly, you can even start a fire with a 9V battery, or get a slight zap, jerk your hand back, and gash yourself on the sharp metal of the hard drive cage because you didn't turn off the computer before reaching in to plug in a fan (happened to me). Torben
| I don't know about starting fires. I imagine AC and DC are equally bad. DC only tends to be worse because the usual source is batteries which can provide huge currents. At higher voltages AC is probably worse because the peak voltage is higher than the RMS and dielectric heating also becomes a more significant factor. As far as electricution is concerned I know for a fact that power line frequency AC is more worse than DC. For a start the peak voltage is 1.414 times higher (this should be pretty obvious) as it interferes with the heart beat more than DC. Quote:
The electrical code in the UK allows much higher DC voltages than AC voltages in situations where people might be electricuted e.g. Any conductors with a greater potential difference (which respect to each other or earth) greater than 60VDC or 25VAC in a dry area or 30VDC or 12VAC in a wet area (damp skin is much more conductive than dry skin) need to be insulated from the user. Any appliance with a only basic insultion between the user and the live parts does not require an earth conductor if it's operated with a voltage below 120VDC or 50VAC. These aren't exact quotes, just what I can remember from the 17th edition of the wiring regulations. I think this is a pretty dangerous myth which needs to be crushed as someone might incorrectly assume that 50VAC is pretty safe because 48VDC is and be electricuted as a result.
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez Last edited by Hero999; 23rd August 2008 at 02:22 PM. | ||
| I also have to agree AC is safer, IN A WAY. As alot of people know, say if you grab onto a peice of wire being fed AC, most people know that your muscles will contract, and cause you to grip the wire! With AC, you have a small chance of actually getting your hand off when the voltage is 0. With DC, there is no 0V point, so your hand is pretty much stuck there. AC is also dangerous in its own ways. like the heart fillibration stuff. AC is more likely to fillibrate your heart than DC, since its more like pulses. And also, AC arcs just as good as DC! Maybe the DC causing more fires/arcing was because there was no low point in the voltage, where the arc could possibly exinguish. Interesting thread!
__________________ The 3 laws of science.... 1. If it smells bad, It's chemistry. 2. If it's mushy, It's biology. 3. If it doesn't work, It's physics. www.laserpointerforums.com A forum for disscusion of lasers and laser shows! www.laserchat.org IRC chat for laser and electronic related stuff. | |
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez | ||
AC is usually used because it is so much easier to transform the voltages with AC. The power grid generators run at 35,000 volts or so, but the voltage is stepped up to 400,000 V or 132,000 volts for transmission on pylons, then down to 33,000 V, 11,000 V, and so on depending on what the final voltage is. All those voltage changes are much easier with AC. AC motors are also simpler and can be made without brushes or electronics. For undersea cables, the capacitance of the cable makes AC more lossy so DC is used, but at very high voltage. It also has the advantage that a DC link can join two networks of different frequencies or ones that are not synchronised. http://en.wikipedia.org/wiki/HVDC_Cross-Channel | ||
| | (permalink) | ||
And in any case it's current not voltage that is often the higher function of specific losses due to I squared Z. Last edited by Chumly; 24th August 2008 at 07:20 AM. | |||
| Not so! In one major way DC is more difficult to work with. Given the same heating effect when making the comparison, and given the same volts and amps when making the comparison, the DC arc will be herder to quench than the AC arc. Thus the switch gear and arc suppression must be more robust for the equivalent DC system. Why you might ask? Because DC is steady state yet AC falls to zero twice per cycle. Last edited by Chumly; 24th August 2008 at 07:30 AM. | |
| Transformers Question | Tsuebo | General Electronics Chat | 2 | 13th January 2008 09:43 PM |
| transformers | danielsmusic | General Electronics Chat | 5 | 24th July 2005 07:46 PM |
| AC transformers | Teletech | General Electronics Chat | 11 | 19th February 2005 11:47 PM |
| Transformers | cduleck | General Electronics Chat | 4 | 11th February 2005 12:19 PM |
| LED and Transformers question | computer | Electronic Projects Design/Ideas/Reviews | 4 | 22nd December 2004 10:19 AM |
