| What is swamping of a transistor?What will happen to the gain of the transistor due to swamping??What happens to the distortion level?? Last edited by rag's; 22nd August 2008 at 05:46 PM. | |
| I think "swamping" happens when a transistor's input signal level is too high and it clips which makes horrible distortion. A dictionary says, "to inundate, to burden, to overwhelm".
| So swamping would be the same as overdriving a transistor? EDIT: Or do we talk about swamping with analog signals and overdriving with digital.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 22nd August 2008 at 07:09 PM. | |
http://www.allaboutcircuits.com/work.../multiamp.html Of course I have no idea if that's what Rag's meant. Torben
__________________ Curiosity was framed. Ignorance killed the cat. | ||
| I have used balancing emitter resistors with paralleled transistors but I have never called them swamping resistors like at All About Circuits. An analog signal clips and produces severe distortion when the input signal level is too high. A digital signal is already clipping so overdrive doesn't affect it. A radio circuit is also "swamped" when the signal level is too high for it. Then it produces cross-modulation of the signals and they appear all over the dial.
| I have heard of swamping resistors used in tuned circuits to broaden the bandpass.
__________________ Forget injuries, never forget kindnesses. | |
Crystal filters have replaced most tuned circuits now because the bandwidth is wide and flat and the skirts are very steep.
| I was having problems with a poor Internet speed and an engineer for the cable complany came round, made a few measurements and concluded that the signal was too strong so he increased the attenuation. Perhaps this was an example of swamping.
If the signal is too strong then the poor receiver will have cross-modulation of all those signals plus cross-modulation of the harmonics of all those signals.
In this cct, both emitter resistors affect the dc bias, while only Re1 affects the ac voltage gain. So for gain, rather than Av=Rc/r'e+Re1 you have Av=Rc/Re. | ||
