| OK, just received a lab-volt AE 793G the same as leader LBO-522? Off ebay for £42. I've only ever used an oscilloscope in a college lab, and only for Hz and TTL so need some advice. Injected RF at 20Mhz cos it's a 20 Mhz oscilloscope. At the lowest time devision of 0.2µs and the times 5 out. I'm getting 8 peaks of a sine wave on the screen. Is it because A) my RF genny is in need of tune. B) The scope is up the pictures Or C) that's what it's supposed to read. Any ideas please? Thanks Larry | |
| hi Larry, Assuming your scope has 5 X divisions across the screen. Set at 0.2µS/div with the Xmulti set a *1,the X sweep would be 1µSec. With the Xmult at *5 the sweep would be 0.2µSec The period of a 20MHz sine wave is 0.05µSec. So would expect to see 4 positive half cycle peaks. ie 4 cycles. If it was mult *10 it would be 8 cycles EDIT: In line with on1aag, IF you have 10 X divisions marked on the scopes graticule, it OK, IF only 5 X divs then its wrong. How many marked X divisions are there on the graticule .??
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 22nd August 2008 at 04:25 PM. | |
| Hi Larry, 200nS and the 5x multiplier depressed gives you 40 nS/div. 10 horizontal divisions are 400 nS. The period of a 20 MHz signal is 50 nS. There will be eight periods on the screen. Looks fine to me. on1aag. | |
| Ok, so that's two differing opinions. Any more? Oh yes, and have you watched music on a scope. It's wild insn't it Yes, ten. Larry Last edited by Larry4911; 22nd August 2008 at 05:54 PM. | |
| I'm watching Gemeni FM on my new/old scope. First time I've ever watched radio. It's great. Larry | |
Not two different opinions, different answers, either could be correct. Some scopes have 5 X divs on the graticule others have 10 X divs. In your case you have 10, so the display is correct. Yes, we all go thru watching audio on the scope, try watching the video signal on your TV' s A/V socket. Connect a mike to the scope and watch your own voice.
| [quote=ericgibbs;339741]Yes, we all go thru watching audio on the scope, try watching the video signal on your TV' s A/V socket. What frequancy for video? This only goes to 20Mhz. Oh, yeh! And this scope has TV-H and TV-V. Will that make a difference on video out or is that just for TV internal signals? Thanks for all your help btw. Larry | |
| [quote=Larry4911;339764] Quote:
What frequency do you think the A/V signal is operating at..? not 20MHz. The TV-H and TV-V are for for scope sync, from the TV Horizontal or Vertical sync.
| Thanks for that Eric. Right, next thing on the shopping list - Waveform monitor. No, only kidding. Damn, that is one hell of a complex waveform isn't it? Larry | |
| But the TV-H and V helped me to understand the signal better. They are in fact used to pick out the horizontal and vertical sync bits of the composite signal. Thanks again. Larry | |
That really sounds interesting! I will try to get sum info on this Muhammad89
__________________ When you Teach, You Learn Twice! | ||
I succeeded to find sum infrmation about the Waveform monitor and it is posted in here http://www.electro-tech-online.com/s...864#post339864 Muhammad89
Its a good idea to try to display different types of waveforms, it will help you understand and get the best from your scope. Manuals are helpful, but there is nothing like 'hands on' experience when using a scope. ALWAYS stay within the scopes input voltage ranges.!!!! Dont fool around with trying mains inputs to the scope amps. You have checked the X scan calibration, I would also check the Y calibration, some scopes have a 'ref square wave'. Get decent probes for the scope *1 and *10 attenuation. Happy scoping..
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 23rd August 2008 at 08:06 AM. | ||
| Quick question | Firnagzen | Electronic Projects Design/Ideas/Reviews | 2 | 24th May 2008 02:49 PM |
| Just a quick question for most of you! | iONic | Electronic Projects Design/Ideas/Reviews | 15 | 10th November 2007 04:45 AM |
| quick pcb question | andrew2022 | General Electronics Chat | 1 | 13th June 2004 07:55 PM |
| quick question - pd | Kane2oo2 | General Electronics Chat | 4 | 15th March 2004 09:55 PM |
| Quick Question | Cyclone | General Electronics Chat | 4 | 30th March 2003 09:20 PM |
