Old 21st August 2008, 06:09 PM   (permalink)
Smile Socket DIL inquiration
hi there
Is it important to use the Sockets pins to hold a kind of IC chips on a board, what is the purpose of using them and what happens if the IC is soldered with no socket pins ?.
Muhammad89 is offline
Old 21st August 2008, 06:21 PM   (permalink)
Originally Posted by Muhammad89 View Post
hi there
Sockets make the IC removable. They can be used when you want to use a static or heat sensitive component and don't want the soldering iron near it. They are good for hobbyists, and on rare occasion used by manufacturers.
If the IC is soldered on the board without a socket it will be difficult to remove, that's all.
BeeBop is online now
Old 21st August 2008, 06:23 PM   (permalink)
my real thanks for the explanation
Old 21st August 2008, 06:29 PM   (permalink)
hi again
I have done a project of traffic lights that is basically depending on electrical Contactors,and electronic timers that are powered with 220v supply and I am really hoping to accomplish the same idea, however, want to use the thyristors instead of the Contactors, and low dc power timers that are near to be operated at 9, or 12 v dc instead of the 220v ac electronic timers.
And I want a suggetion of the type and serial number of he parts I need for the circuit as well as a brief explanation of how that is likely to be done.
thanks
Muhammad89
Old 21st August 2008, 06:46 PM   (permalink)
Originally Posted by rezer View Post
Do you mean triacs and not thyristors. Thyristors are used for detecting temperature changes.
althought I really meant thyristors, what you are talking about sounds new to me because for all I know that SCR Thyristors can be used as swtiches. So why are you saying Triacs instead of thyristors? that sounds like Thyristors is the wrong part for this application. And if talking about Triacs, they are to the most part 2 Thyristors, back to back, which provides a pulse in both instances the negative and the positive which can be exploited when want to get an output of an AC like pulse . what do you commnet on what I said ?
No.
An SCR and a TRIAC are thyristors. Look in Google about it.
A thermistor is a resistor that changes its value when its temperature changes.
audioguru is offline
Old 21st August 2008, 06:52 PM   (permalink)
Originally Posted by audioguru View Post
No.
So that backs up what i was saying that Thyristors can be used in a traffic lights circuit as switches with the aid of for example the NE555 timer chip
Old 21st August 2008, 07:21 PM   (permalink)
Sorry about the brain fart. You are correct in your statement. You wrote thyristors, I read thermistors (even wrote thyrsistors). It feels like a Monday.
"Remember, you're special.....just like everyone else."
rezer is offline
Old 21st August 2008, 07:31 PM   (permalink)
hi again
now after you realized your mistake, do you think you can help with this application>? Do you have any suggestions ?
Muhammad89
Old 21st August 2008, 07:41 PM   (permalink)
Can you provide a schematic for your system that uses the contactors?
Please also include the load requirements for your traffic lights.
rezer is offline
Old 21st August 2008, 07:52 PM   (permalink)
okay Exp Rezer
I will try to get that on a Word file.Because I still have the schematic on rough paper. by the way, Do you know any free trail software for schematic electrical diagrams, you know, that contains the very basic symbols such as the timer, the push button as well as the contactor?
Muhammad89
Is this the traffic light circuit you are referring to at this thread?
http://www.electro-tech-online.com/g...g-circuit.html
rezer is offline
Old 21st August 2008, 08:00 PM   (permalink)
okay Exp Rezer
Muhammad89
You might try Express PCB. They are a quick turn pcb fab house. I believe theirs is free-ware.
Also, I have used MultiSim from National Instruments. You can download a trial version for 30 days (cost around $40.00 if you decide to purchase). There are tons of free CAD software out there also. Just google it.
rezer is offline
Old 21st August 2008, 08:12 PM   (permalink)
HI again
This is a previously accomplished circuit that needs a kind of potentiometers numberes 7140 or something like so and I am determined to build up my own with the use of Thyristors as switches and if comes to crush will try to use the Ne555 timer chip to switch between the 3 colors of the traffic lights. you will surely uderstand this in much details when I send you the electrically operated traffic lights circuits which holds to the most part the same idea.
Muhammad1989
Old 21st August 2008, 11:09 PM   (permalink)
a thyristor is usually used in AC circuits. In a DC circuit it never turns off. In an AC circuit it turns off each time the voltage passes through 0V.
In a DC circuit the thyristor needs to have its current blocked for it to turn off. You can block its current by shorting it for a moment then it turns off.
Aerial Socket peter5355 Chit-Chat 7 22nd February 2008 02:15 AM
LCD Socket? UTMonkey Datasheet/Parts Requests 4 28th October 2007 11:39 PM
BGA Socket nvprospector Micro Controllers 0 31st October 2005 10:26 PM
SMT socket zachtheterrible General Electronics Chat 5 12th July 2005 04:24 PM
MMC socket mikemikemike Datasheet/Parts Requests 1 20th October 2003 07:03 AM
