| Hi Muhammad89, just to emphasize audioguru's statement about thyristors: They behave like a self-latching relay applying DC. Removing or inverting the gate voltage they still conduct. I don't suggest usage of thyristors for that reason. You might power the traffic lights using appropriate transistors. You will also have to remove the supply voltage and/or short the thyristor. For schematic and PCB software you might also download Eagle at http://www.cadsoft.de. The light version is free with limitiations of the max. board size of 3.15X3.15" and one sheet in the schematic editor. Boncuk
| HI bonk Uk, What if a timer is used in the circuit, such as 555 timer chip, that is just to keep the shorting of the thyristor to go automatically after a proper period of time and make the changing over between the three lights go smoothly? | |
| If you must use a circuit to short the thyristors then the circuit can drive the LEDs and the thyristors are not needed.
In this kind of application I want to consider the usage of the Thyristor much than the Timer, how much do you think of the possibility of using the thyristors alone in such circuit ? Muhammad89
__________________ When you Teach, You Learn Twice! | ||
| The circuit is not in this thread. A triac is used in an AC light dimmer. It turns itself off each half-cycle so it needs to be turned on again over and over if you want lights to remain on. An SCR is half-wave so it lights light bulbs dimmly with AC. It turns itself off each cycle so it also needs to be turned on again over and over if you want lights to remain on. An SCR is used in a DC alarm system. It stays turned on after it is triggered for a moment. Transistoirs or Mosfets turn on DC traffic lights and are driven by a sequencer circuit.
Muhammad89
| A CD4017 is a sequencer circuit. It has one output go high one after the other. A traffic light is driven by a sequencer circuit because the colours light one after the other in a sequence.
here it is http://www.kpsec.freeuk.com/projects/trafficlight.htm what do you comment? Muhammad89
| The project is used for toys. The diodes form OR gates so the green LED is turned on for twice as long as the amber LED. The amber LED is turned on for only two clock periods. If it used SCRs then the lights would be on all the time (unless you short the SCR to turn it off).
| Aerial Socket | peter5355 | Chit-Chat | 7 | 22nd February 2008 02:15 AM |
| LCD Socket? | UTMonkey | Datasheet/Parts Requests | 4 | 28th October 2007 11:39 PM |
| BGA Socket | nvprospector | Micro Controllers | 0 | 31st October 2005 10:26 PM |
| SMT socket | zachtheterrible | General Electronics Chat | 5 | 12th July 2005 04:24 PM |
| MMC socket | mikemikemike | Datasheet/Parts Requests | 1 | 20th October 2003 07:03 AM |
