| Hi, I have a schematic which calls for a bi-color diode. Here is what it looks like on paper: ![]() As you can see, the schematic only shows one line going to the LED from the zener diodes, and one line coming off the LED on the opposite side. My LED has, of course, 3 leads on it. So how do I hook up the LED: Both anodes to the lead coming from the zener diode and the cathode to the lead leaving the LED? Or some other configuration? Thanks in advance. Last edited by 0x00x0; 21st August 2008 at 03:21 PM. | |
A bi color led is just two leds (on red, one green) inside the same container. Three lead leds are made with a comon cathode and two independent anodes (or a common anode and independent cathodes) Two lead leds have both individual leds in parallel, but with opposing polarities: one lead is the red cathode and green anode, the other lead is the red anode and green cathode.
__________________ E Cerfoglio Buenos Aires Argentina | ||
| Thanks... Live and Learn | |
| Hi 0x00x0, Try this, it might even work ! on1aag. | |
| Awesome! I will give this a try and report the results.. | |
| Hmm, the only diodes i have are zeners.. I guess I will have to order the 2 pin bicolor LED after all.. | |
| Hi 0x00x0, Put the zeners in and use them as regular diodes. All zener voltages are higher than the forward voltage drop of a red or a green led. It should work equally well. on1aag. | |
| Zener diodes Vf are around 0.7V and do not exceed the voltage drop of LEDs. You can verify this by doing a simple diode check. But you can still use them in place of the 1N4148 diodes.
__________________ "Remember, you're special.....just like everyone else." | |
| Hi 0x00x0, They will do fine because the forward voltage drop of both leds is lower than the zener voltage. on1aag. Last edited by on1aag; 21st August 2008 at 06:00 PM. | |
| When you say "zener voltage" are you refering to the zeners in series with the LEDs or the ones used as a switch to direct current? I am assuming you are referring to the series diodes since the switching diodes, in this app, are used as regular diodes.
__________________ "Remember, you're special.....just like everyone else." Last edited by rezer; 21st August 2008 at 06:07 PM. | |
| Hi Rezer, I didn't mention the 18 volt zeners, I was referring to the 1N4148's. on1aag. | |
__________________ "Remember, you're special.....just like everyone else." Last edited by rezer; 21st August 2008 at 06:47 PM. | ||
| What sort of bi colour LEDs do you have? Some are just a red and green LED connected in reverse parallel, they have only two leads and you need to reverse the polarity to change the color.
| Zener Diode identification (color bands) | dalmation | Datasheet/Parts Requests | 10 | 16th October 2008 12:28 PM |
| Stereo Hookup | shocking find | General Electronics Chat | 4 | 12th January 2008 12:02 AM |
| LM317T Voltage regulator hookup question | evotec1 | Electronic Projects Design/Ideas/Reviews | 3 | 20th May 2007 12:43 AM |
| Diode Question. | bitem2k | General Electronics Chat | 13 | 3rd March 2007 10:20 AM |
| Diode Question | troy310589 | General Electronics Chat | 9 | 28th June 2006 02:08 PM |
