Old 20th August 2008, 09:57 PM   (permalink)
Question Best way to generate -12V from +12V ?
Hi there,
I dont want to use the battery connection technique which means I would need 24V battery and I have 12V only. The + and -12V is to power an op-amp and I need the -12V to be generated from the +12V supply (battery wiring techique messes up how the op-amp sees my input signal anyway).
So I have 12V battery pack, is there a convenient IC out there which will help me out? I dont want to build somethig from 'scratch'. I have done some searches but nothing as of yet.
Thanks very much.
AceOfHearts is online now
Old 20th August 2008, 10:07 PM   (permalink)
You did not mention your current requirement. Digikey has a bunch of DC-DC converter modules. List was extensive. Here is one example.
http://search.digikey.com/scripts/Dk...=PT78NR112V-ND
Forget injuries, never forget kindnesses.
Mikebits is offline
Old 20th August 2008, 10:34 PM   (permalink)
http://focus.ti.com/docs/prod/folder...cp021212d.html for a DIP solution. It is unregulated but a simple resistor-zener regulator helps out. It will generate equal and opposite output voltages isolated from the input, so as your battery drops the output voltage will still stay the same on + and - output.
Remember, they are unregulated and noisy. You might try the dcp021215d version with linear regulators on the outputs to get very nice + and - regulated outputs.
speakerguy79 is offline
Old 20th August 2008, 10:56 PM   (permalink)
Originally Posted by AceOfHearts View Post
Hi there,
Thanks very much.
You may want to look at this link
http://www.electro-tech-online.com/g...es-opamps.html
k7elp60 is offline
Old 20th August 2008, 11:12 PM   (permalink)
You can also create a very nice 250ma virtual ground with a BUF634 and two bias resistors, if you are OK with +/-6V supplies.
Old 21st August 2008, 12:37 AM   (permalink)
Any opamp will work with a single supply voltage if its input is biased properly.
Look at my STICKY article.
audioguru is offline
Old 21st August 2008, 03:20 AM   (permalink)
You can create a charge pump using a 555 timer chip, resistors and caps.
"Remember, you're special.....just like everyone else."
rezer is offline
Old 21st August 2008, 04:11 AM   (permalink)
www.digikey.com has the NJU7662D for $1.67. This IC, a couple of capacitors and you'll have apx -12V unregulated which is good enough for the negative rail of an OpAmp. Another option is just to use a rail to rail OpAmp or the biasing technique Nigel mentioned. It depends on your circuit.
kchriste is offline
Old 21st August 2008, 12:21 PM   (permalink)
Please post the circuit, the chances are it can be modified to run off a single 12V supply.
Screen name: Aloone_Jonez
Hero999 is offline
Old 26th August 2008, 07:24 PM   (permalink)
Thanks very much every one. I will be ordering a -ve voltage generator soon.
Just incase someone knows a way around it,basically, its a non inverting amplifier with a gain of 3. The problem is, its not outputting 0V with an input of 0V. With input=0V it out puts 2 something volts.
Old 26th August 2008, 08:07 PM   (permalink)
Please provide more information.
Does the input voltage need to be less than 0V?
Does it amplify AC or is it just DC?
If it's a DC amplifier and the input doesn't need to go below 0V then use a single supply op-amp like the LM358 or MC33171.
Hero999 is offline
Old 26th August 2008, 09:56 PM   (permalink)
Thanks very much for the suggestion. Planning on getting one tommorrow.
is it possible to generate gps signals jkmadsci Micro Controllers 45 5th March 2008 12:38 AM
Help with pic to generate frequency blinkstar88 Micro Controllers 5 28th June 2007 06:17 PM
Generate an interrupt over I2C PicChristmas Micro Controllers 1 15th June 2005 09:11 AM
generate 20V from 3.6V battery vincentng General Electronics Chat 1 28th November 2003 09:17 PM
how to generate +5V\2ma from a -90V\1A floating dc\dc ...? bulerias General Electronics Chat 1 3rd January 2003 12:47 PM
