+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 21
Thread: Newbie Question about resistors,transistors?
  1. #1
    AaronOregon Newbie
    Join Date
    Aug 2008
    Posts
    9
    Default Newbie Question about resistors,transistors?
    I am very active on other hobby forums, but this one is new to me. Forgive me for my ignorance, but I am working on a project here and need your help. If you have a normally "closed" switch that has 24ac volts going to it, and when the switch becomes "open" it jumps to 27ac volts, what would I need to make that 3 volt change trip a normally "open" momentary switch to activate something else? A friend told me I would need like a solid-state resistor. Is this right? It is for a circuit board so it can't be big and mechanical. Anyone that replies would be doing me a huge favor if you could possibly answer my question along with a URL to go to for this item. Thanks in advance for any help you can offer!
    Aaron
  2. #2
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,456
    Hi Aaron,
    where do you get the 27VAC?
    A small schematic showing where you measure 27VAC would be helpful.
    Boncuk
  3. #3
    AaronOregon Newbie
    Join Date
    Aug 2008
    Posts
    9
    Don't have a schematic. The 27VAC is measured at the same point the 24VAC is read at on the board, when the circuit is opened. I need something that can read that 3VAC change and send current to close a momentary switch. Thanks for the reply.
    Aaron
  4. #4
    Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent
    Join Date
    May 2008
    Location
    San Diego, Ca
    Posts
    3,917
    Blog Entries
    2
    Sounds like the measurement is between a loaded supply and a unloaded supply. If you just want to detect when switch is off, use the switch contacts.
    Pay it forward.
    www.geoepicenter.com
  5. #5
    Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent
    Join Date
    Oct 2006
    Location
    B.C., Canada
    Posts
    2,469
    Quote Originally Posted by AaronOregon View Post
    Aaron
    Hi Aaron,
    Can you at least draw a diagram of the problem? If you don't know schematic symbols then just draw it out as you understand it. It might help us picture what's going on a little better.
    Torben
    Curiosity was framed. Ignorance killed the cat.
  6. #6
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,821
    Blog Entries
    13
    Aaron
    The 27Vac state, I suspect is because the load has been disconnected by the switch, its an 'off load' state.?
    As soon as you start loading the 27Vac with a detector circuit that 3Vac difference could be much smaller.
    This means the detector must very lightly load the 27Vac line.
    Do you mean supply current thru a switch contact or just close a momentary contact.?
    Hi Torben, Mike .
  7. #7
    AllVol Good AllVol Good AllVol Good
    Join Date
    Nov 2005
    Location
    Tennesee, USA
    Posts
    957
    Quote Originally Posted by ericgibbs View Post
    Hi Torben, Mike .
    Eric, it sounds like he is using a switch to control a relay or other inductor, and is seeing the back emf as a result of the switch opening.
    If that is the case, what he is pseudo-measuring might be the meter needle jump.
    Creationists have a world of evidence
  8. #8
    Willbe Good Willbe Good Willbe Good
    Join Date
    Aug 2008
    Location
    MD
    Posts
    1,238
    It sounds like you need to rectify the 24vac, filter it, and feed it into an IC comparator that senses the increase in voltage, and the comp drives a relay.
    1.4 x 24vac = ~34 vdc, 27vac = ~38 vdc, so the comparator reference voltage should be about 36 vdc.
    How fast do you want this circuit to respond?
    If the comp output needs to be a pulse, you'll need to add a one-shot.
    However, it sounds easier to just sense the voltage across the switch contacts, which goes from zero to 27 vac, and work with that.
  9. #9
    AaronOregon Newbie
    Join Date
    Aug 2008
    Posts
    9
    I own an automotive shop. What I am trying to do is take a standard Genie garage door opener that opens the bay door and wire a wireless chime "into" the already there, IR Safe-T-Beams across the bottom of the door so I know when customers walk through. On the back of the Genie opener are three screws: Top one = wall button, Middle one = common, Bottom one = IR wires. The IR beams of course come in from each side of the door and the red wires go to the bottom screw and the white wires go to the common screw. The voltage to the bottom screw is 24.2vac until the IR beam is broken "or open" which then jumps the voltage to 27.2vac. I want that 3vac rise, to trigger the wireless momentary switch to chime the bell. Guys, I appreciate the responses.
    Aaron
  10. #10
    Join Date
    Aug 2008
    Location
    MD
    Posts
    1,238
    Yes.
    It'd be good if you knew how much current flows through the wires when the voltage is at the low value.
    I assume the voltage rise is due to the poor regulation of a 24vac xformer.
    Without getting into the guts of the opener, for ~ $20 in parts from www.Hosfelt.com or other suppliers you can build/assemble/test a custom-designed circuit by me or others that will sense this voltage change and provide you with relay contacts that close in order to turn on an audible or visual indicator of some kind.
    Depending on your skill level you can build/assemble/test this in a day, so if you pay yourself 10 tax-free dollars per hour for these kinds of projects this will cost you ~$100.
    If the output of this comparator circuit needs to interface to an existing chime or wireless momentary switch, please provide info on these items.
    You may also want to consider buying a motion detector; that way there is no design, build & test time involved.
  11. #11
    AaronOregon Newbie
    Join Date
    Aug 2008
    Posts
    9
    I considered a motion detector, but I'm worried about a motion detector because the farther the span is, the wider the area it detects. So if I have 15 foot doors by the time it reaches the other side it will detect 15 feet wide or more and be going off all the time with guys working in the shop. I need more of a line or a beam that it breaks to go off.
    Aaron
  12. #12
    kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    Which model do you have?
    http://www.geniecompany.com/GenieCompany.aspx?cid=322
  13. #13
    AaronOregon Newbie
    Join Date
    Aug 2008
    Posts
    9
    PMX500 ProMax
  14. #14
    Join Date
    Aug 2008
    Location
    MD
    Posts
    1,238
    ...I'm thinking now that the 24v to 27v change is too small, that normal line voltage variations will swamp out the "signal".
    ...There might be some way to rectify and peak-detect the 24vac, giving ~34vdc, then feed this signal through a series capacitor into a comparator so that when the beam is interrupted you get a 3vdc drop or rise.
    ...Slow line voltage variations wouldn't register but an abrupt drop in voltage would trigger a comparator.
    ...This seems messy and I'm not sure the response time would be fast enough.
    ...Monitoring the current change that causes the xformer voltage to drop and rise is probably better.
  15. #15
    AaronOregon Newbie
    Join Date
    Aug 2008
    Posts
    9
    Quote Originally Posted by Willbe View Post
    So what is the best way to do this Willbe? I really appreciate your involvement!
    Aaron
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. Newbie Question on NPN Transistors
    By arrow in forum General Electronics Chat
    Latest: 27th July 2006, 03:15 AM
  2. Question about transistors
    By mrbanana in forum General Electronics Chat
    Latest: 15th May 2006, 07:09 PM
  3. Question about LEDs and resistors.
    By tribaloverkill in forum Electronic Projects Design/Ideas/Reviews
    Latest: 1st November 2004, 04:55 AM
  4. a question about transistors
    By samcheetah in forum General Electronics Chat
    Latest: 4th May 2004, 05:26 AM
  5. newbie, relays, transistors.
    By waltonlobot in forum General Electronics Chat
    Latest: 3rd May 2003, 01:30 AM
Tags for this Thread
