Old 21st August 2008, 04:59 PM   (permalink)
Originally Posted by blackbunny View Post
yeah i do have common cathode, so u mean just switch the diode around in that diagram?
dark current is insignificant, other things like risetime etc are also insignificant from my knowledge.
Bandwidth/risetime requirements depend on the application. You didn't actually tell us what you plan to do with this, so we can't determine bandwidth requirements. The choice of op amps, diode biasing, feedback resistance, etc., all depend on bandwidth requirements.
Ron
Roff is online now
Old 22nd August 2008, 01:17 AM   (permalink)
all i simply want is to have this diode amplified with separate channels, output some voltage that i can connect to the three adc pins on my avr chip to do something with it.
blackbunny is offline
Old 22nd August 2008, 02:02 AM   (permalink)
The 3 amplifier circuit does not look like it will work. All three diodes are in parallel. What effects one branch will effect all branches. If this is what you want, just use one op-amp. It will do the same thing.
Why not use 3 seperate photo diodes with seperate op-amps?
"Remember, you're special.....just like everyone else."
rezer is offline
Old 22nd August 2008, 02:34 AM   (permalink)
What power supply voltage(s) do you have available? Do you have a preferred op amp? It needs to have FET inputs.
Ron
Roff is online now
Old 22nd August 2008, 02:37 AM   (permalink)
so what would be an appropriate amplifier circuit for this sensor?
datasheet
The datasheet says it is common anode.
Ron
Roff is online now
They are not in parallel.
Ron
Roff is online now
Old 22nd August 2008, 03:16 AM   (permalink)
The schematic blachbunny posted showing 3 amps does show the diodes to be in parallel.
rezer is offline
Old 22nd August 2008, 03:54 AM   (permalink)
Notice he said,
u mean something like this?
That was his idea of how they should be connected. The datasheet he linked to clearly says the three diodes have a common anode connection, with the cathodes on separate pins.
Ron
Roff is online now
Old 22nd August 2008, 03:59 AM   (permalink)
I indicated what I was talking about. I wasn't speaking about the datasheet. But no problem.
rezer is offline
Old 22nd August 2008, 04:10 AM   (permalink)
Sorry for the misunderstanding.
Ron
Roff is online now
Old 22nd August 2008, 06:32 AM   (permalink)
just usb bus power
Old 22nd August 2008, 05:06 PM   (permalink)
I misinterpreted the datasheet. The part is common cathode, as you stated.
Are you going to use AVCC, or the internal 1.1V reference, for the A/D?
Ron
Roff is online now
Old 23rd August 2008, 12:40 AM   (permalink)
avcc will be at 5v
Old 23rd August 2008, 04:44 AM   (permalink)
OK, here's a place to start. You will have to play with the feedback resistor and capacitor. I have a feeling the resistor value may need to be in the megohms.
CAVEAT: I have never used the ATmega88, the LTC6082, or your photodiode.
But it's better than what you have now.
Ron
Roff is online now
Old 14th November 2008, 06:02 PM   (permalink)
Hello!
I'm working on a similar project. The components I'm using are as follows:
Photodiode
OpAmp
The results I'm getting with the solution posted here are sorta like on off (Any light at all and the output goes low. With no light the output goes high. Very hard to reach a happy medium). I have a feeling it has to do with the resistor and capacitor in the feedback?
I'm wondering how I should go about selecting the proper resistor/capacitor combination?
Thanks in advance!
canoo is offline
Photodiode ahmedragia21 Robotics Chat 8 1st March 2008 06:09 PM
What exactly is a photodiode? Souper man Electronic Projects Design/Ideas/Reviews 7 12th May 2007 10:16 PM
photodiode!!!!!! abojako General Electronics Chat 5 20th February 2005 04:57 PM
photodiode UnD3aD Robotics Chat 11 10th February 2005 09:13 PM
photodiode fogus General Electronics Chat 6 28th June 2003 12:44 AM
