Fresh ICs have leads that are bent at an angle that makes its impossible to insert in a IC base or PCB. One needs to bend them together to be able to use them. I have done it several times using my hands or forceps. But I am wondering if there is any standard or atleast recommended way to bend these. Thanks in advance,
__________________ Its not the Practice that makes a man perfect. Its the Man who makes the practice perfect ----- Pradeep K. Shima ----- | |
I just push each side against a flat surface until it looks about right. There are tools made for this purpose, but really not needed.
__________________ Pay it forward. | |
| | #3 | |
I guess if I was trying to optimize the firmness of the seating, I would skip that step, and instead insert one side of the IC into the socket very slightly, then press the legs on the other side with a flat object until I could get them into the socket holes. Once the IC was square to the socket I'd press it carefully into place. The only reason I'd do this instead of deforming the legs outright (e.g. shaping them by pressing against a tabletop) is so that the legs would have more of a tendency to spring out against the contacts in the socket, hopefully holding it in place more firmly. Note that I almost always do the tabletop-bending thing, and I have never had a problem with an IC falling out of a socket. And I'm no engineer so I am not sure if the extra measures above would even be worth the effort. ![]() Torben
__________________ Curiosity was framed. Ignorance killed the cat. | ||
| | #4 | ||
What do the tools look like ? any names I can search for ?
__________________ Its not the Practice that makes a man perfect. Its the Man who makes the practice perfect ----- Pradeep K. Shima ----- | |||
| | #5 | |
Please don't mistake me--I certainly don't advocate this method for production. It just seems to work for me as a hobbyist, and with the ICs I've used, it seems that the legs tend to break off before any internal damage is caused in the IC.Torben
| | #6 | |
http://www.jonard.com/jonard-ecommer...B72560D91.jvm1
__________________ Pay it forward. Last edited by Mikebits; 19th August 2008 at 10:28 AM. | ||
| | #7 |
The tool that aligns DIP pins is quite simple. It is just a fixed block that sets the distance between rows of pins. On each side of it another block that pushes the pins against the first. You could fake it with 3 blocks. The center one would have to be the right width. Press the chip onto the first block and hold in place. Then press the other two block onto the pin to align them. EDIT: This is one of the tools that you can do without. But once you have it you will find yourself using it because it does a good job and is quick, easy.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 19th August 2008 at 11:22 AM. | |
| | #8 |
I use the tabletop method lol
| | #9 |
Yeah I dont intend to buy the tool myself either. Was just curious to know whats the right way. Thanks for the link Mike. Now I am curious why the IC manufacturers produce them in a shape that doesnt fit IC bases/PCBs as such. The datasheet specifies the angles and all very accurately so they must be having a good reason I guess.
| | #10 | |
__________________ Pay it forward. | ||
| | #11 |
| That qualifies as a good reason . It also gives me reason to beleive someone holds a patent to the 'tabletop method'. Lets hide and pray till someone sues us for infringing it.
| | #12 |
I am guessing: If the pins were correctly spaced insertion machines would have a difficult time holding on to the parts. By making them wider there will be spring pressure between the pin and the machine during insertion.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
| | #13 |
One thing to be aware of with the table top method is the possibility of ESD damge to the part if it's a sensitive part. (Small, high speed MOS devices are the most sensitive). Wood is probably ok but certain types of plastic can carry a lot of static charge.
__________________ Carl Curmudgeon Elektroniker | |
| | #14 |
There is a useful tool called "Pin-Ausrichter". It's usable for standard IC with pins rows spaced 7.62mm and double spaced rows of 15.24mm spacing. It is very helpful if you grab an IC out of the junkbox and want to reuse it. The pins are also out of alignment after pulling an IC off the socket sometimes. Normally those pins are bent in any direction and bending them on a table top won't take care of those bent inside. To treat such an IC just bend all pins outside at only approaximate angles. Then insert into the Pin-Ausrichter and press the outer grip firmly. All pins will be more or less angled 90 degress depending on the pressure you apply. The tool is available at http://www.conrad.de. Order number is 168203-62, priced EURO 6.10 (including sales tax) Here is a picture Boncuk
| | #15 |
That is the same tool I have. It aligns the pins in a row but does not adjust the spacing between adjacent pins. Still very handy to have. You can easily live without one but it is a useful tool.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 19th August 2008 at 11:25 PM. | |
| bend, leads |
| Pic Input Leads | richard.c | Micro Controllers | 0 | 19th January 2008 11:14 AM |
| Wire Leads | Be_O_Be | General Electronics Chat | 2 | 1st December 2007 12:57 PM |
| Stepper and It's 4 Leads | watzmann | General Electronics Chat | 3 | 24th August 2005 04:38 PM |
| Please help, if you know about audio leads + mics | Qwaz | General Electronics Chat | 2 | 20th February 2005 03:41 AM |
| hmm too many leads on a transformer? | daviddoria | General Electronics Chat | 14 | 21st April 2004 04:47 AM |
