+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 22 of 22
Thread: How to bend IC leads
  1. #16
    Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent Torben Excellent
    Join Date
    Oct 2006
    Location
    B.C., Canada
    Posts
    2,469
    Yep, that looks like a lot more fun than the needle-nose-pliers-and-swearing method I usually use when the pins are really bent up.
    Torben
    Curiosity was framed. Ignorance killed the cat.
  2. #17
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,455
    Quote Originally Posted by Torben View Post
    Yep, that looks like a lot more fun than the needle-nose-pliers-and-swearing method I usually use when the pins are really bent up. Torben
    Use this tool in combination with an IC-inserter. That way you won't have to bend the pins at a 90 degree angle (little pressure only), use the IC-inserter and "plug" the IC into the socket.
    The tension will hold an IC even under high g-loads.
    Hans
  3. #18
    Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent
    Join Date
    Oct 2006
    Location
    Colombo
    Posts
    1,664
    Blog Entries
    1
    Actually a good question.
    I was suffering with the same problem.For one or two IC's the hand & the support of a flat surface is ok.
    But think if you have 100 ICs how do you do?
    That tool is really needed.
  4. #19
    pkshima Good pkshima Good
    Join Date
    Jan 2003
    Location
    New Delhi, India
    Posts
    328
    I once used a bench wise to do the trick
    I never did it again because it 'felt' like being cruel to electronics
    Its not the Practice that makes a man perfect. Its the Man who makes the practice perfect
    ----- Pradeep K. Shima -----
  5. #20
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,455
    Quote Originally Posted by Gayan Soyza View Post
    But think if you have 100 ICs how do you do? That tool is really needed.
    Don't you have employees for that kind of job?
  6. #21
    zathras Newbie
    Join Date
    Jul 2008
    Posts
    2
    We have a fancy block of aluminium at work with a raised centre section to suit the width of the 0.3" IC.
    Close on each side of the raised section is a ball bearing which will press the pins inwards as the IC is pushed past along the raised section.
    If you flip it over, the other side has a wider ridge to suit 0.6" spaced IC's with another pair of bearings.
    It really works well, quick and easy to use, the beauty being it just sits on the desk, no fumbling about picking up a handtool for each IC.
    Can't recall where we got it from, it was many years ago when we used to use a hell of a lot of EPROMs.
    Ray
  7. #22
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,814
    Frequently I would insert one row of the IC into the board, then push sideways on it till the other pins lined up. Sometimes the pins were too stiff and it was back to the needle nose and swearing.
    Using the original part configuration meant they always stayed in the board.
+ Reply to Thread
Page 2 of 2
First 1 2
  1. Pic Input Leads
    By richard.c in forum Micro Controllers
    Latest: 19th January 2008, 10:14 AM
  2. Wire Leads
    By Be_O_Be in forum General Electronics Chat
    Latest: 1st December 2007, 11:57 AM
  3. Stepper and It's 4 Leads
    By watzmann in forum General Electronics Chat
    Latest: 24th August 2005, 03:38 PM
  4. Please help, if you know about audio leads + mics
    By Qwaz in forum General Electronics Chat
    Latest: 20th February 2005, 02:41 AM
  5. hmm too many leads on a transformer?
    By daviddoria in forum General Electronics Chat
    Latest: 21st April 2004, 03:47 AM
Tags for this Thread
