Old 18th August 2008, 12:25 AM   (permalink)
Default Help pleaseeeeee
Hello kind people, I need some help/information on a few things.
I need an adjustable timer relay for a 12v system, so that when i close the doors on my car and press the lock button the relay will put power to the windows so that they close. So in theory the relay will have 5 pins, 12v+, a ground, one to disable the relay, one where the trigger wire will connect and an output that will stay live for around 10 seconds.
Thanks in advance.
Christon1987 is offline
Old 18th August 2008, 12:55 AM   (permalink)
I would use a (one-shot) monostable multi-vibrator. A 74hc123 would be a good choice.
Space Varmint is offline
Old 18th August 2008, 01:06 AM   (permalink)
Thanks, but i need something that doesn't require soldering or PCB's.
i have attached a picture of what i need, the two boxes to the left are what i need. Is there a way that i can control the time with these?
Where can i get these relays from?
Also what parts would i need to create this circuit, in simple terms?
http://www.lsicsi.com/pdfs/Data_Sheets/LS7220.pdf
Old 18th August 2008, 01:31 AM   (permalink)
You don't even have the relays? Man, you got some research on your hands. Try Digikey.com. A one shot is probably the simplest way to do it. It's just a 14 pin chip with a capacitor & a resistor. No biggy. Go to Radio Shack and pick up some proto-board and hand wire it.
Old 18th August 2008, 01:57 AM   (permalink)
What sort of resistors and capacitors will i need?
I'm sorry for sounding dumb. The only electrical things i've done before is wiring a few alarm systems in cars. So you may have to bare with me a little bit.
Also can anybody help me with the LS7220 Circuit. What exactly will i need to build it? I have an LS7220 ordered and a keypad.
Old 18th August 2008, 03:32 AM   (permalink)
I think you should have ordered a pre-built car alarm.
Can you post a link to the Keypad you ordered? I suspect it may be the wrong type as most are in a matrix configuration.
kchriste is offline
Old 18th August 2008, 04:28 AM   (permalink)
Just down load any of these data sheets. http://www.datasheetcatalog.org/cgi-...&action=Search
You should be able to find the other part there too.
