| Want to control HVAC fans using an Omega temperature controller to activate solid state relays for a 240 volt fan.Every solid state relay seller I,ve found only offers (SPST)single pole,single throw.or 3 phase relays.Although I could switch the 240 volt fan using a SPST relay I think it would violate code.All help would be appreciated.DonaldL | |
| Would DPST suffice? You can use two SPST, one on each leg and control both from the same source. Each should be rated for the full voltage to cover any differences in switching speed. | |
SSR's at 240AC which can handle large loads get quite costly.
__________________ Forget injuries, never forget kindnesses. | ||
| Mechanical relays are larger and will take up extra space in my enclosure.I know that if 3 phase SSR's are avalable then someone must make a double-pole double -throw equivalent.I will Google Newark.Thanks for the advice.Don | |
| Don't forget SSRs tend to need large heatsinks to meet their current ratings that may make them as big or bigger than EMRs.
__________________ NO, that picture isn't me so don't bother asking if we can be friends. Last edited by dknguyen; 15th August 2008 at 10:00 PM. | |
| Folks;Idanielrosa posted good advice.What I needed is a double pole/single throw SSR for switching to 240 high voltage residential.A dpdt switch would be an on/off/on switch most often used to control motors for forward/off/reverse.But I am still having problems finding a DPST SSR.A mechanical relay is most likely the best way to go. DonaldL | |
| Solid State Relay | ahmedragia21 | General Electronics Chat | 8 | 1st July 2008 01:09 AM |
| Solid State Relay | madcitysw | General Electronics Chat | 19 | 30th April 2008 10:33 PM |
| Solid State Relays and PWM | eric303 | General Electronics Chat | 1 | 9th September 2006 07:42 PM |
| solid state relay | mhtavallaie | Electronic Projects Design/Ideas/Reviews | 3 | 15th February 2005 01:01 PM |
| Solid State Relay Help | bryan | Electronic Projects Design/Ideas/Reviews | 2 | 25th June 2003 09:17 AM |
