| Hello, first post for me. I've looked everywhere, and have found nothing. ![]() Ok, so the theory goes... the relay is closed, charges the capacitor, and removes the potential across the relay, opening it. the capacitor discharges at a speed controlled by the pot, until its low enough to trigger the relay, the process is repeated. the coil would see a sawtooth wave, with both positive and negative swing (because of the resistor to ground), with the speed controlled by the pot. I know that any relay would burnout quickly, and for even low frequency waves I would need to use something else. but would this work in theory? the goal of this is to produce a variable horizontal sweep for an oscilloscope. I have ripped apart an old CRT monitor, because I can't afford a real scope I know the wave slope wont be straight, but I don't think it will matter, as long as its consistent. Thanks for taking the time to read this. | |
| It looks overly complicated. Try this simple circuit using two op-amps. http://www.interq.or.jp/japan/se-inoue/e_ckt17.htm | |
| how would that all fit together? I'm trying to learn about op amps in order to build the circuit suggested by Reese, and then to amplify the output with a couple of power transistors I've ripped from a broken PA. but due to time and money constraints I've been extremely slow progressing so far... to be honest, I'm a little confused about the current and voltage I need to draw, I think that my CheapDMM is playing games with me. | |
When the voltage built up across the capacitor reaches approximately 65vdc the neon fires and discharges the cap to some low voltage. Then the cycle begins again. It couldn't be simpler. Theoretically the cap discharges infinite current so you might want to put a small resistor in series with the neon to protect it. Or you could use a unijunction transistor circuit, if they still make unijunctions. Or a diac instead of the neon bulb. What are your DMM symptoms? Usually they are pretty hardy but there are several ways to get weird readings. | ||
But, if you mean my parts list, the neon goes across the capacitor, and this parallel assembly is in series with a resistor and the source DC voltage. When the voltage built up across the capacitor reaches approximately 65vdc the neon fires and discharges the cap to some low voltage. Then the cycle begins again. It couldn't be simpler. Theoretically the cap discharges infinite current so you might want to put a small resistor in series with the neon to protect it. Or you could use a unijunction transistor circuit, if they still make unijunctions. Or a diac instead of the neon bulb. What are your DMM symptoms? Usually they are pretty hardy but there are several ways to get weird readings. | ||
| Remember a Unijunction Transistor? Or a PUT (programmable unijunction transistor? They made pretty good sawtooth waveforms a long time ago.
| What frequency do you require? Does it matter? You could use a reverse bias oscillator. ![]() http://www.uashem.com/pageid-186.html
| How do Cable Tone Generator/Tracers work? | johankj | Electronic Projects Design/Ideas/Reviews | 33 | 28th January 2008 01:49 PM |
| 555 sawtooth generator | 4electros | General Electronics Chat | 1 | 12th June 2006 02:55 AM |
| Sawtooth Generator | Nick_L | Electronic Projects Design/Ideas/Reviews | 5 | 23rd October 2005 07:36 PM |
| 100KHZ Sawtooth Generator crcuit? | imgemini | Electronic Projects Design/Ideas/Reviews | 17 | 16th November 2004 12:24 AM |
| Crude assembly counter | Mark Lazarides | Micro Controllers | 5 | 28th February 2004 08:22 PM |
