Old 12th August 2008, 04:51 AM   (permalink)
Default Here is the circuit..... What is the motor?
I found this circuit and wanted to know what stepper motor I could use with it.. I do not know what motor(type) I am looking for. Thanks for any direction.
The thought is in the question; The information is in the anwser.
b_reagle is offline
Old 12th August 2008, 05:02 AM   (permalink)
unipolar stepper
But you'll need drivers if the motor requires more than about 5 mA.
mneary is offline
Old 12th August 2008, 05:12 AM   (permalink)
As I am sure most would. Would NPN transistors suffice as drivers?
Thank you.
b_reagle is offline
Old 12th August 2008, 05:17 AM   (permalink)
Wow. Kinda pricey... Any suggestions on whare to find a used(salvaged) one? Any key features?
Thanks again.
b_reagle is offline
Old 12th August 2008, 05:23 AM   (permalink)
Would this work??
http://www.recycledgoods.com/itemdet...roductID=26530
b_reagle is offline
Old 12th August 2008, 05:48 AM   (permalink)
Although a unipolar requires a less complex circuit than a bipolar, it also is slower than its bipolar cousin, requires more windings of wire for same power as bipolar hence "Pricey"
Forget the simple circuit, look into some H-bridge driver chips and use a bipolar step motor.
Forget injuries, never forget kindnesses.
Mikebits is offline
Old 12th August 2008, 05:54 AM   (permalink)
Speed is not real a issue is it. 1/2 turn in 1/2 sec.??
b_reagle is offline
Old 12th August 2008, 06:01 AM   (permalink)
When I very first started electronic's my instructor always said to use the K.I.S.S. rule.
b_reagle is offline
Old 12th August 2008, 06:02 AM   (permalink)
Not really, but I would think price is. Bipolars are much more common and can be had at much more moderate cost
Mikebits is offline
Old 12th August 2008, 06:06 AM   (permalink)
But the circuitry is more $$?
b_reagle is offline
Old 12th August 2008, 06:16 AM   (permalink)
Yes, of course. Yours will be more $$ when finished. That bit of circuit can not drive a stepper motor!
Use the outputs to control a stepper motor driver. There is no stepper motor which can be connected directly to the logic.
You can save $$ not connecting any motor to that circuit. The chips will fry right away.
Boncuk
Boncuk is offline
Old 12th August 2008, 06:21 AM   (permalink)
I would have used transistors for drivers, but I will have to do more research on the matter. Do you have any links that would be helpful?
b_reagle is offline
Old 12th August 2008, 08:56 AM   (permalink)
Google "full H-bridges"
Boncuk
Boncuk is offline
Old 12th August 2008, 02:55 PM   (permalink)
Is there no H-bridge driver chip that operates at 3vdc(min)?
b_reagle is offline
Old 12th August 2008, 04:52 PM   (permalink)
Would this circuit work with 3 vdc?
b_reagle is offline
Need help with timer circuit for AC motor TechSarge Electronic Projects Design/Ideas/Reviews 5 19th July 2008 12:58 AM
PWM circuit for a dc motor burnsy007 General Electronics Chat 1 10th May 2007 09:36 PM
Motor control circuit crunch53 Electronic Projects Design/Ideas/Reviews 3 12th November 2005 05:02 PM
control circuit to motor circuit does it matter what wire i? troyandash Robotics Chat 2 21st May 2004 12:26 PM
Motor Drive Circuit Kingpin094 General Electronics Chat 8 1st April 2004 02:55 AM
