| I Need a normally closed relay (can be normally open if it has to be I guess) that can be switched by less then 1mA @ 11 volts (1.25mA 11.35v to be precise) and handle a load of 8mA @11v (7.5mA 11.35v to be precise). I'm pretty sure what I need is a solid state relay, but I can't seem to find anything. A Google search yields a few things but nothing concrete. Looking here http://www.vishay.com/solid-state-relays/ I found a few things that might work, but I don't understand half the specs on the data sheets. I've used regular relays for various things in the past but these go a bit over my head. Basically I'm trying to fool a 3 position magnetic induction sensor into thinking that position 3 is switched at the same time as position 2. Position 2 sends a constant 1.25mA @11v until it's switched (and turns off) and I want to use this to switch a relay which will provide the position 3 wire with the 8mA @11v as soon as position 2 is switched. My other concern is do SSRs have to have their current controlled (As in probably can't just give it any power source and ground it without burning out?) | |
__________________ Forget injuries, never forget kindnesses. Last edited by Mikebits; 11th August 2008 at 10:07 AM. | ||
| Use an analog switch (CD4066). Activation is at far less than 1mA and paralleling all four in a package you are on the safe side. (for output current) Analog switches are normally open. Use an inverter (transistor, BC547) for NC- normally closed operation. Supply voltage of 12V will be sufficient. SSRs and reed relays require 10mA for reliable operation. However you can't use an SSR anyway for this low current to switch. Boncuk
__________________ Proper Planning Prevents Piss Poor Performance Last edited by Boncuk; 11th August 2008 at 01:08 PM. | |
| There's a whole host of SSRs at that link that can be activated by 1mA or less... I just don't understand the rest of the specifications which is what I am asking about. For instance: http://www.vishay.com/docs/84724/vo1400ae.pdf Or: http://www.vishay.com/docs/83840/lh1549ab.pdf Boncuk I'll see if I can read up on what you suggested, but that's foreign to me. | |
| Do you need isolation between input and output? | |
| never seen relais that switched on 1ma try to steer it with a fet the BS170 or its sister BS250 would be able to switch that Robert-Jan | |
| Again: Quote:
| Seriously though I think you guys are assuming me to be more knowledgeable then I am. I really don't know half of what your saying or 80% of whats on the data sheets of the things you guys are suggesting (or how to use them). | |
| Hi technochild, most of the members here assume that such posts are done to do somebodies homework and therefor you have a small problem. I have never seen an SSR switching at 1mA. I had a serious computer breakdown (installing antivirus software which behaves worse than the worst virus I know of) Here is a screenshot I just managed to to. The circuit is drawn the way you want to switch: normally closed. Pressing S1 will open the switches. Boncuk
__________________ Forget injuries, never forget kindnesses. | ||
| Hi you can use a inverter port CD 40106 they are verry sensitive and the output is strong enough to steer a transistor see atached schematic Robert-Jan | |
I hate to ask but can someone just tell me what electronics piece I need and how to wire it based on what I said in the first post. The diagrams and stuff don't really help me because I don't know what they say. My electronics knowledge is very basic. Don't get me wrong though I've looked up all the data sheets of the pieces you guys suggested, and tried to research what I need to do but cant really understand it. | ||
| Relay Contact Current Question | 3v0 | General Electronics Chat | 7 | 28th April 2008 01:23 AM |
| current relay idea | bunghole | General Electronics Chat | 10 | 2nd February 2008 07:18 AM |
| RZ2G5 relay.. not enough current, solution plz. | sonaiko | General Electronics Chat | 8 | 25th June 2005 09:24 PM |
| 12v automotive relay current consumption, HOT | RaG | Electronic Projects Design/Ideas/Reviews | 7 | 18th March 2005 08:26 AM |
| Would this sound relay work ? | Swifty | General Electronics Chat | 7 | 29th December 2003 02:19 PM |
