| trying to wire an old electric motor on a toledo threader. has 4 wires that test with continuity between 2 pairs. motor has six brushes and operates forward and reverse. we have a 3 pole double throw switch to operate this with jumpers across posts. this motor does not have a cap or cent. switch. any idea how to wire or where to find a diagram. thanks for any help. | |
| But why would it have six brushes when you'd normally only expect three on a three phase motor?
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez Last edited by Hero999; 9th August 2008 at 07:08 PM. | |
| 3 phase motors with brushes are not common devices, and there are all sorts of ways of wiring them up. PPINC didn't say anything about 3 phase. The only thing he mentioned that was a multiple of 3 was the brushes. What is the voltage of the motor? How are the 6 brushes arranged? Any other information and a photo would be a big help. | |
| The motor is 115 volts and can be operated ac or dc. The current use for the motor is on a pipe threader. the switch configuration is as follows. 1 2 3 4 5 6 7 8 9 There is a jumper from 1 to 8, from 2 to 7, and from 3 to 9. There is evidence of wires being hooked up to 1,2,3,4,5,6 but no wires to 7,8,9. Also the six brushes are arranged around the case evenly spaced with 3 brushes used by each pair of wires from the motor. Thank you for the replies. Last edited by ppinc; 10th August 2008 at 12:40 AM. | |
| | (permalink) | |||
| It looks like it is a series-wound motor. That is just about the only type of motor that will run on AC or DC. The 6 brushes probably indicate that it is a 6 pole motor to increase torque but at less speed. (Car stater motors are often 4 pole. Most other brushed motors are two pole) I don't quite understand:- Quote:
You should wire the windings in series, with the reversing switch reversing just one of the windings. Quote:
Line connects to 6 3 connects to one end of first pair 2 connects to other end of first pair 1 connects to neutral 4 and 5 connect to the other pair. If the motor direction does not match the switch label, swap the wires on 4 and 5. Don't move the jumpers. It might be worth testing it with no load on a 12V battery, with a 20 A fuse. There is a danger of electric shock, getting fingers caught or massive overcurrent if things go wrong. | ||||
| DIVER300 you are probably correct as to the position of the brushes in one pair of wires. So if this is the case, which pair would be in series first. I have tested for ohms between each pair and found one pair with about .4 ohms and the other with about .8 ohms. Thank you for all the help. | |
| I'll take that as a question. The answer is that it doesn't matter which comes first in a series circuit. With low resistances like that, you may get a lot of current if things go wrong, so try starting with a car battery or with a big light bulb in series as well. | |
| Wired up the motor as recomended by DIVER300 and it seems to be working fine. Thank you for all the help. | |
| motors, switches, wiring |
| stepper motor or Torque motor | yagtoby | Electronic Projects Design/Ideas/Reviews | 1 | 14th June 2008 05:29 PM |
| dc motor controller for treadmill motor | wistlepig1 | Electronic Projects Design/Ideas/Reviews | 8 | 20th April 2007 11:11 PM |
| DC motor, Servo Motor or Step Motor ? | wcz | Electronic Projects Design/Ideas/Reviews | 1 | 29th June 2005 02:41 PM |
| Motor Characteristics Graph + controlling motor | lil'gal | Robotics Chat | 2 | 29th September 2004 01:30 PM |
| Motor controller for a e-motor/generator Combo | dreamtoys | Electronic Projects Design/Ideas/Reviews | 1 | 4th October 2003 12:42 AM |
