| I started reading about diode switching capabilities. I don't think I undertand. Based on some diagrams and text is the following circuit correct? (I probably draw the diode upside down???) Is there some point (control voltage) at which the diode will conduct and there will be 5v at the red dot? (refer to the attach diagram) Trying to learn the basics. Help will be appreciated. Thanks a lot. | |
| The voltage in is going to ground so it won't work as shown. If you remove the ground from the input then it depends upon the load at the red dot. If it's just a high impedance voltmeter and the diode is silicon, then the voltmeter will read +5V with an input of about +5.6V. A silicon diode has about a 0.6 to 0.7V drop in the forward direction for low currents.
__________________ Carl | |
At less than +5.6V there will be no +5V at the red dots? Thanks, | ||
__________________ Forget injuries, never forget kindnesses. | |
| Voltage at the red dot with no load should measure the input voltage minus the drop across the diode, which is around .7 volts. Example: Vin - Vdrop = Vout or 5 - .7 = 4.3 no load.
__________________ All those who believe in psycho kinesis, raise my hand. | |
| Because there is no load at the output of the diode, you should measure the input voltage at the output. what you have here is an open circuit with no return path. If you use a resistor at the output, then you would measure around .7V if it's a silicon diode. | |
| The datasheet for the 1N4148 silicon diode shows that its forward voltage is only about 0.2V at a current of 0.5uA which is a 10M meter input with 5V across it. The forward voltage is 0.37V at 10uA, 0.6V at 100uA, 0.625V at 1mA and 0.73V at 10mA. at 100ma the forward voltage is a little over 0.9V and at 800mA it is almost 1.5V. The forward voltage reduces a little when the temperature of the diode increases.
| Typically you would use a resistor that would not exceed the max rating for the part. The 1N4148 (1N914) is rated up to 200mA continuous current. A circuit designed to draw 3-5mA is a good target. This will give a Vf of up to 700mV across the diode. Reese | |
| Simple Battery Power switch with diode? | dbtoutfit | Electronic Projects Design/Ideas/Reviews | 12 | 5th February 2008 10:45 AM |
| switch on a led depending on the switch state (using picbasic and pic16f877) | pouchito | Micro Controllers | 8 | 8th June 2007 09:09 AM |
| Computer Diode,Hivoltage Diode...? | p1120 | Electronic Projects Design/Ideas/Reviews | 2 | 7th September 2006 10:31 PM |
| difference between a normal diode and a schottky diode | jin29_neci | General Electronics Chat | 18 | 14th September 2005 07:21 PM |
| Stun gun switch and diode 914 | klangen_86 | General Electronics Chat | 3 | 29th September 2003 10:36 AM |
