Old 7th August 2008, 10:29 AM   (permalink)
Originally Posted by Stu2008uk View Post
mine got a bit of uprating, the old 305 wasn't quick enough cant have kitt without a bit of speed, its running a 5.7 350 Pontiac block thats been uprated to 400 horsepower.
Do like the 95's they look very sleek and im looking into one as a daily driver.
Thanks for the assistance its most appreciated.
Stu
Mine has had some reliablity issues lately. Last visit to the mech cost me 5 grand as my coolent leaked into the heads. If I did not have a motorcycle I would be taking the bus a lot. lol
400 HP, wow that is sweet
Forget injuries, never forget kindnesses.
Mikebits is online now
Old 7th August 2008, 10:46 AM   (permalink)
ouch thats a nasty bill!
All the engine work was undertaken by myself cause i know what mechanics are like for bills lol!
Stu
Stu2008uk is offline
Old 7th August 2008, 10:52 AM   (permalink)
Ok wait here, I got my cam, Let me show you mine I am going to shoot a few pics.
Old 7th August 2008, 11:02 AM   (permalink)
Ok, here is mine...
Old 7th August 2008, 11:18 AM   (permalink)
Since you seem to have a gearhead background, can I assume you can fab parts from metal? This is only relevant to plan A, as I still see this as the simplest solution. I will send you a schematic soon of plan A. Plan B to come later.
Old 7th August 2008, 11:36 AM   (permalink)
They do like to cram those ls1's in there don't they!
Yes i should be able to fabricate some metal parts if needs be.
Ive a breadboard to test circuits on just need to get the correct components.
Stu
Old 7th August 2008, 11:40 AM   (permalink)
Sure do. I use to be somewhat of a gearhead myself, but this car has humbled me
Well, I am off to bed for now... Talk to you later okiday
Old 7th August 2008, 11:45 AM   (permalink)
O.k. mike take care, you'll get the car sorted, anythings possible
Stu
Old 7th August 2008, 11:56 AM   (permalink)
Hi Stu,
If you want to keep your LED Pedal design simple, how about using a couple of LM3914 LED Bargraph Drivers?? The voltage from a variable resistor swing from 0-5V , lights up 10 LED's exactly how you want..
jimmythefool is offline
Old 7th August 2008, 04:10 PM   (permalink)
Also....
you can use it in 'Dot mode' with just 1 LED moving back and forth
Old 7th August 2008, 04:33 PM   (permalink)
any chance you could lay that out on a breadboard, think i do have a LM3914 in my kit of bits, I'm a novice when it comes to reading the diagrams though
ideally im looking to light up 14 leds per side.
cheers
Stu
Old 7th August 2008, 08:35 PM   (permalink)
Originally Posted by jimmythefool View Post
Hi Stu,
That is exactly what I was thinking...
Old 7th August 2008, 09:06 PM   (permalink)
Thanks Mike
I was beginning to think it was a bad idea!
Stu,
Have a look at this link, it might help. Unfortunately it only runs 10 LEDs, although you can cascade them to make 20
If pin 9 is not connected (default), it will be in Dot-Mode. Connect pin 9 to pin 3 (+ on power supply) for Bargraph
http://www.cpemma.co.uk/bargraph.html
Regards
Jim
Old 8th August 2008, 01:26 AM   (permalink)
Okay, as promised, here is a circuit I drew up. I may have made a few errors as nobody is perfect I am sure if I did, it will be pointed out. Anyways, I attached the schematics and sorry, it took two pages to fit everything. The jumper block is to set between Dot mode and Bar mode. The nets with labels simply means tie those point together. Hope that helps...
Old 8th August 2008, 01:42 AM   (permalink)
Ack, I already spotted one error. Pin 9 of U2 should be U2mode. My printer is out so it is hard to catch everything from the monitor
I will correct the error later as well as check it over one more time...
Here is data sheet link for 3914
http://www.national.com/mpf/LM/LM3914.html
Guitar pedal Op Amp switching Dr_Satan Electronic Projects Design/Ideas/Reviews 2 19th May 2008 01:24 AM
Foot pedal switch ? killivolt Electronic Projects Design/Ideas/Reviews 1 17th March 2008 09:50 PM
Guitar Pedal Board PS kill_switch Electronic Projects Design/Ideas/Reviews 3 1st December 2007 10:58 AM
Bass Pedal YAMAHA BP2 em2006 Datasheet/Parts Requests 1 28th December 2006 10:08 PM
Keyboard sustain pedal Dan East General Electronics Chat 8 17th July 2006 07:38 PM
