Old 4th August 2008, 12:28 AM   (permalink)
Default Small Transformer
hi everybody ...
for many electronic applications, we need a DC supply ... and we often need an internal power supply rather than powering the project by batteries ...
for small size applications, where the area is an important factor, the transformer of the power supply is really a big problem ...
the transformer i used in my current project has the dimensions of 7*3.5*4 cm which are very very big dimensions with respect to my circuit dimensions ...
I am asking if there is a special type of transformers that is smaller in size or if there is another technology that can discard the Big transformer ...??
please help and thanks in advance
afesheir
Know more about Muhammed (PBUH). That is better than insulting him:http://www.rasoulallah.net/
afesheir is offline
Old 4th August 2008, 01:19 AM   (permalink)
Build an isolated SMPS.For low power at high frequencies these can be small. Rohm has non-isolated pre-built low power SMPS.
I would recommend an isolated supply,but another alternative is use capacitive reactance and a zener see here.
http://uk.geocities.com/ronj_1217/tless.html
Oblong is offline
Old 4th August 2008, 01:33 AM   (permalink)
You can use a switching power supply (Like the one in a computer) which is smaller than the traditional power supply of equivalent power. They work by rectifying the AC and then chopping it at 200Khz or so to drive a much smaller transformer (The higher the frequency, the smaller the transformer can be).
http://computer.howstuffworks.com/power-supply1.htm
kchriste is offline
Old 4th August 2008, 01:51 AM   (permalink)
You can get little AC/DC modules in small packages. Here is a link to such a device provided by DK in a previous post.
http://www.v-infinity.com/dklist_ac_dc%20conv.asp
Forget injuries, never forget kindnesses.
Mikebits is online now
Old 4th August 2008, 02:24 AM   (permalink)
For small DC projects that I need to run off the mains, I always use a wall plug adapter(plugpack supply), this is many times safer as the mains voltage is confined to the wall transformer & the circuit usually needs only a 78xx regulator & a few caps, very small PCB area needed.
This also gives flexability to your project as it can be run off battey as well, be it car battery or whatever.
tonigau is offline
Old 4th August 2008, 04:06 PM   (permalink)
A wall plug is normally best for most applications, if you need a bipolar supply then go for a wall plug with an AC output and use a voltage doubler.
For more power laptop powers supplies are better, even if you need to put another switching regulator on the output.
Large transformers are normally only needed for things like audio amplifiers.
I still like to use a small transformer to build internal power supply but that's only because I've got lots of them in my junkbox.
Screen name: Aloone_Jonez
Hero999 is offline
Old 4th August 2008, 11:26 PM   (permalink)
hi everybody ...
afesheir
This Circuit can be Modified to operate Small Projects.
http://www3.telus.net/chemelec/Proje...er/110-chg.htm
CAUTION, SHOCK HAZZARD, it is NOT Isolated from the AC Line, So it is Not Suitable for some projects.
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 4th August 2008, 11:41 PM   (permalink)
CAUTION, SHOCK HAZZARD, it is NOT Isolated from the AC Line, So it is Not Suitable for MOST projects.
Corrected.
A 2.2µF mains capacitor is nearly the size of a small transformer. The only use this circuit is for is something with an MCU or CMOS logic like a timer. 100mA is a bit optimistic, it'll be more like 86mA once you take into accound for the 14V drop of the load and rectifier, then there's the issue of the capacitor bein on the lower end of its tollerance range.
Hero999 is offline
Old 15th August 2008, 09:59 AM   (permalink)
first of all, sorry for my late reply but i had my internet connection disconnected the last days ..
thanks to all .. but i couldn't understand the idea of the transformerless power supply ..!!!!!!!!
thanks agaon to all of u ..
afesheir
afesheir is offline
Old 15th August 2008, 02:42 PM   (permalink)
I have heard this many times, but i'm stil curious why SMPS not appropriate for audio amplifiers ?
There are two major products that came out of Berkeley: LSD and BSD. We don't believe this to be a coincidence. —Jeremy S. Anderson
sniper007 is offline
Old 15th August 2008, 04:45 PM   (permalink)
It is, many PA amplifiers (and a few HiFi amplifiers) use them - but SMPSU's aren't cheap, and can make the unit more expensive. You also have the problems of the RFI they produce, so you need good screening and filtering.
It's far, far, easier to throw a conventional PSU together, a transformer, a bridge rectifier, and a couple of electrolytics - job done, and it doesn't kill itself at the slightest provocation.
Old 16th August 2008, 12:15 AM   (permalink)
Is that ture these days?
I thought large SMPes are cheaper than huge transformers and filter capacitors.
Hero999 is offline
Old 16th August 2008, 10:26 AM   (permalink)
Is that true these days?
It can be, depending how good the PSU needs to be - it's a LOT more complicated, and bear in mind you're not talking about a regulated conventional supply. A large toroid made in China won't be very much money.
Old 16th August 2008, 10:07 PM   (permalink)
we need a DC supply
What max voltage & max current and max power? Does the V & I need to be adjustable?
Does it need to be isolated from the AC line? Are you working at 50 Hz?
Continuous or intermittent use?
Willbe is offline
small help plz HKS Electronic Projects Design/Ideas/Reviews 1 16th October 2007 05:56 PM
Big and small - Old and new atferrari Chit-Chat 3 15th May 2007 06:23 PM
Small LCD netbug Micro Controllers 5 1st March 2006 05:19 PM
A small bit of help please... scameron66 General Electronics Chat 1 14th April 2005 03:23 AM
Need a small bit of help. Stinkey Electronic Projects Design/Ideas/Reviews 4 11th December 2003 07:04 PM
