| I am in the process of laying out a new PCB for the Mondo Superprobe. I have been attaching the tip/needle to the PCB by soldering it to a 10x20mm foil area on the board. Will this corrupt readings? I am thinking that the foil would act less like a capacitor if there were no ground plain on the other side of the board. Is that good enough or do you think I should epoxy the needle to the board and do away with the 10x20mm foil? EDIT: I have added png's of the top and bottom. This is my first attempt at this layout and there will be problems so do not try to build from it. I will be increasing isolate.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 25th July 2008 at 10:31 PM. | |
| Capacitance is a few pF. Shouldn't make a big difference. I would minimize the area of the probe mount pad, but keep the ground plane under it. To reduce stray signals on the probe node, however, I would move the probe trace to the red layer and extend the blue ground plane all the way under the whole length of the probe signal. You might have to reduce the separation rules from 'signal' to 'dimension' to get the continuity. I would also move the power line on the red layer upwards, so you can get a continuous ground trace on the red layer inside of pins 1 thru 8. | |
| On second thought, better than moving the probe line to the red layer, just make sure that the ground plane in red is complete on the outside of the resistors. This can be done by relaxing the signal to dimension rule. | |
| Thanks. I was able to move the resistors closer to the processor and with a bit of work I now have everything you mentioned and a non broken ground around the edge of both layers.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | |
| hi 3v0, Is fitting a single pin socket on the pcb an option.? It would be then possible to plug in various types of pin probes, with tips to suit the job in hand.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
But it would have to be a decent socket. Not sure the needle would fit without ruining the socket contacts etc etc..
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | ||
I find the tips with the square recess that just fits an ic leg ideal for ic probing, none slip.!
This is a great tool for what it is. Some day.... I would like to build a better version. Go to a larger PIC to get more pins to work with. Better LC. Do something about the voltage measurement limitation. Switch to a LCD with text instead of the cryptic 7 seg words. The long probe in the attachment it the version that I have been using for over a year. The one in the box is the first prototype for the one I am working on. It is a SS board but I have switched to DS because I needed to move the display and switches to the bottom.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 26th July 2008 at 02:14 PM. | ||
| I havent tried it myself, but I would have thought some of those surgical hypo needles, with the threaded end, come in different diameters and are pointed.
| One would have to try them. The Needle I am using works well enough for now. You posted while I was editing my previous post. I added a image that will give you some idea of the scale. The prototype does not have a needle mounted.
| Seen the image. I looked at this tester when it came up on the forum a few weeeks ago, interesting spec. Sadly I have no requirement for it.
| Self Capacitance | codan | General Electronics Chat | 2 | 1st May 2008 06:12 PM |
| capacitance meter related question | whiz115 | General Electronics Chat | 17 | 8th April 2008 11:48 AM |
| Capacitance Question | abbarue | General Electronics Chat | 30 | 12th October 2007 10:55 PM |
| capacitance | abawan | Electronic Projects Design/Ideas/Reviews | 12 | 4th July 2007 10:22 PM |
| novice capacitance question? | alanzhao | General Electronics Chat | 7 | 20th February 2004 11:23 AM |
