| Hello! I've been doing experiments with supercapacitor. I'm trying to integrate it to help prolong battery runtime. I tried some scenarios like connecting the Supercap directly in parallel with the battery with no added components/circuit. The thing is it didn't help the battery at all rather it degrades it even more. After reading some articles i've found out that the in-rush current may have been the cause of my problem. Now, im planning to add some components that would somehow limit the current draw from the battery using only simple components like resistor/transistor/mosfet/etc.. and at the same time charge the supercap fast. Ive seen some chips for supercap chargers but my budget is limited so I opt to use simple components if its possible. From my experiments, (correct me if im wrong) i have noticed that the higher the current supplied to the supercap the faster it charges. So im planning to use darlington pair so that i can input small amount of current(therefore preserving the battery) and provide an ampified current at the output(thus, charge the Supercap fast). Is my idea somehow effective or im not making any sense at all? I do appreciate any suggestions you want to share. This is my first time handling supercap and i dont have that much experience with electronics either. Im using two AA rechargeable batteries(1.2V, 2100mAH) and 1 SuperCap (2.5V, 33F). My Load will take about 200mA-500mA. Im also planning to replace the SUperCAp with smaller value (0.1F, 2.5V) because it's taking too much time to charge this 33F supercap. Thank you in advance! | |
Here's some more reading on the topic, though: http://www.batteryuniversity.com/partone-8.htm As I understand it, supercaps are not generally used to prolong battery life, but rather are used to provide enough power to get a device through a short power outage. Perhaps if you explained what your actual project is we could provide more help. Many times people come to the site looking for help with a part of a project, when the best answer would be to solve the problem using another method entirely. Torben
__________________ Curiosity was framed. Ignorance killed the cat. | ||
| I got your point on the darlington issue. ive been experimenting on it for days now and ive observed the same thing you just said. I thought darlington was use to amplify weak currents(my mistake). Anyway, waht im trying to do is to compare battery runtime between two circuits. one with battery only and the other a battery parallel with supercap. both have the same LOAD. I was expecting the circuit with supercap will last longer but the opposite happpens. I am concerned that my supercap (33F) is too big to charge for an AA 1.5V batteries(2pcs). In-rush current may be the issue. | |
| here is what im going to do next: 1. replace supercap with 3F 2. use load which draws about 600mA Im hoping the 3F supercap wont take too much time to charge if i place current limiting resistor to limit in-rush current. Also, i will try not to continously attach the load to the supercap to allow it to be charged by the battery. i will try to time it and pulse the circuit. I guess this time the 600mA pulsed circuit will hurt the battery only circuit and will benefit the battery w/ supercap circuit. waht do u think? | |
If you are charging the SCap via a switching or linear controller, what final voltage do you expect the SCap to be charged to, using 2 * 1.2VBty in series.? Morning Torben.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 24th July 2008 at 07:57 AM. | ||
| Supercaps tend to have quite a high leakage current so having one permanently across the battery terminals will cause a higher drain than not having one on the circuit at all. | |
| If you are charging the super cap from the same batteries that's running your circuit, you will not get any benifit. All that it's doing is moving energy from one storage device to another, with some losses.
__________________ How To Ask Questions The Smart Way | |
| Morning Eric! One thing I am wondering about: wouldn't the cap and battery both have to be perfect to even achieve unity here? The circuit's total charge will not be increased; some is just shifted into the caps. And I would think that the faster discharge of the cap would reduce the apparent life of the battery, since a lot of current is used to charge the cap but that charge is put back into the circuit much faster than the battery would have. Torben Edit: Ninja'd by Boomslang.
__________________ Curiosity was framed. Ignorance killed the cat. Last edited by Torben; 24th July 2008 at 08:23 AM. Reason: Typo fix. | |
I agree the losses would be as boomslang and picasm states. The formala Q= CV .. where Q = I * t, so t= [C * V]/I should give the OP the charge time. BTW, you don't get Ninja'd with a Boomslang,,, they bite and then goodnite.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 24th July 2008 at 08:31 AM. | ||
| | (permalink) | ||
Torben
__________________ Curiosity was framed. Ignorance killed the cat. | |||
__________________ How To Ask Questions The Smart Way | ||
If I read you right this is a 600mA PULSED load?? You will get worse battery life with the supercap in circuit because the supercap will allow greater current into the load when pulsed, and will then place additional drain on the battery to recharge the cap after each pulse. With the battery only in circuit, when a pulse occurs the battery's high internal impedance will mean the load recives less current during the pulse as the battery voltage will temporarily "sag". So with the supercap your load will recieve more total current on average, and the battery will drain faster. If you want to improve the experiment then use a "constant current" pulsed load that will draw very similar average current regardless of whether the supercap is in circuit. If your goal is to reduce battery consumption then add a series resistor of the highest value possible that still allows the load to "function" each time, or better still an appropriate inductor if size and costs allow. | ||
| well, here is what ive read: 1. batteries drain/deteriorate faster with loads that draws high currents.(ex. camera flash) what im trying to do is replicate this with LEDS in parallel which would equal to about 600mA or higher. When i said pulsed i mean like the camera flash wherein there is a time gap between the next shot. Il try to charge the supercap during those time gap. and when i connect the LEDs, only the supercap will handle all the current drawn by the LEDs. also, i will place a current limiting resistor when charging the supercap to limit the in rush current. With the battery alone, the battery will handle all the current draw which i hope will drain it fast. Last edited by tattee; 24th July 2008 at 09:44 AM. Reason: not yet finished | |
How are you going to control the duration and current of the discharge pulse.? What colour are the LED's.? Did you see from the Q = C*V formula, how long its going to take to charge the SCap 33F, using two AA's.?
| i havent figured out what i will be using to pulse the circuit.. maybe a 555 timer would do. do you have any suggestion? Im not using the 33F anymore.. i am planning to replace it with the 3F from nesscap. I think it will be easier and faster to charge. Btw, thank you for all who replied. i appreciate all your inputs! keep it coming.. | |
| Need help with charging calculations. | Nicksan | Electronic Theory | 8 | 29th August 2008 08:50 PM |
| Supercapacitor Sizing | eld101 | Electronic Projects Design/Ideas/Reviews | 9 | 1st May 2008 10:38 PM |
| In car SLA charging | joecool85 | General Electronics Chat | 14 | 19th September 2006 12:53 AM |
| battery charging. | manz | Electronic Projects Design/Ideas/Reviews | 9 | 8th July 2006 03:04 PM |
| Battery Charging | Kingpin094 | General Electronics Chat | 3 | 11th July 2004 04:44 PM |
