Old 22nd July 2008, 03:23 AM   (permalink)
Question Transformer questions
ok 2 simple questions:
1. Why do some transformers such as those universal ones cause "humming" in say a pocket radio when they are the power supply?
2. My clock radio's transformer bit the dust. I'm wondering, how hard is it to rewind the transformer? Is it something that pretty much a newbie could do?
Thats all for today... Thanks!
Thanks!
--Juan
juan123 is offline
Old 22nd July 2008, 04:08 AM   (permalink)
1- Because the DC is not smoothed enough by the filtering circuit, or it is underrated.
2- The transformer can be replaced by transplanting one of those inside a 'universal' power supplies but the cause of burning must be repaired first; or the bad transformer can be eliminated and feed the radio by adding a power jack and an external universal supply.
Abolish the deciBel !
Externet is offline
Old 22nd July 2008, 04:12 AM   (permalink)
You could rewind the transformer if you wanted but it'd probably be easier to just to yank a working one out of a similar device, they generally speaking are 12 volt transformers though you need to determine the voltage before you do anything. Difficulty is pretty much across the board depending on what if any potting compound was used for the windings (some of them are downright messy) To properly copy the old transformer you have to determine the wire gauge of the primary and secondary, and the number of turns in each. What you're really trying to do is match the DC resistance, total number of turns and turns ratio as closely as possible. If your transformer is toast though that might be a problem as you're not going to be able to determine all of those. I'd match it with a transformer that's roughly the same size rated at 12 volts and see what happens.
straight answer, har har."
Sceadwian is offline
Old 22nd July 2008, 04:14 AM   (permalink)
The hum from 'cheap' power supplies can generally be reduced or eliminated by using large filter capacitors on the output leads. If you have the space large chokes feeding a large capacitor can really smooth things out.
Transformer Help peter5355 General Electronics Chat 6 13th March 2008 02:27 PM
Winding a transformer (picture included) - Questions FusionITR General Electronics Chat 30 14th August 2006 07:41 PM
Transformer help... elec123 General Electronics Chat 1 16th April 2006 10:56 PM
Transformer Questions.... FredFlintstone General Electronics Chat 2 7th April 2006 06:08 AM
Transformer Questions moody07747 General Electronics Chat 6 24th May 2005 12:01 AM
