Old 20th July 2008, 07:52 PM   #1
Default Wired up a phase shift oscillator but I dont think im getting a sinusoidal wave
I hooked it up to a speaker but the speaker just makes some noise, flexes up and stays up, then shutters a little and repeats, no sound wave it seems. It should be at 900hz I have a dual + - 9 volt battery supply. Pin 1 is empty as it is just offset. Pin 2 has incoming from pin 6 and is bridged over the OP amp to pin 6 also. Pin 3 is grounded. Pin 4 has - input. Pin 5 is empty. Pin 6 is the output going to res cap res cap res cap res then back to pin 2, 3 resistors are grounded. Pin 7 has the + input. Pin 8 is empty. I wired the speaker after the end resistor before it goes to pin 2 from pin 6, so it should have a full phase shift. Any ideas?
Qaiphyx is offline
Old 20th July 2008, 08:00 PM   #2
Would the type of capacitor make any difference? The caps are from a few weeks ago and I think they might be electrolytic if that makes any difference?
Qaiphyx is offline
Old 20th July 2008, 08:01 PM   #3
How about posting the schematic and we might have some idea of what you are talking about?
if I know the answer.
Hero999 is offline
Old 20th July 2008, 08:06 PM   #4
Ive been using this.
http://hyperphysics.phy-astr.gsu.edu...c/oscphas.html
Qaiphyx is offline
Old 20th July 2008, 08:13 PM   #5
Just waiting for the mods to approve the post. I use the schematic from hyperphysics of the phase shift oscillator.
here
http : // hyperphysics . phy-astr . gsu.edu / hbase / electronic / oscphas . html
to speed things up.
Qaiphyx is offline
Old 20th July 2008, 08:36 PM   #6
Why did you add the spaces?
Here's the link without the spaces.
You do know that this circuit can't drive an 8Ω speaker, you need a buffer amplifier like the LM386.
Hero999 is offline
Old 20th July 2008, 08:38 PM   #7
The impediance of my speaker is 4Ω. LM386?
The forum wont allow me to post links with out approval since im a new member.
Qaiphyx is offline
Old 20th July 2008, 08:39 PM   #8
The impediance of my speaker is 4Ω, will it push that or is that worse? lol. LM386?
Qaiphyx is offline
Old 20th July 2008, 08:53 PM   #9
I can try to buffer it with the other op amp that I have but do you think this is definitely the problem? Eventially I will be buffering it.
Qaiphyx is offline
Old 20th July 2008, 09:08 PM   #10
Adding another op-amp won't help since the minimum impedance most op-amps can drive is 2k, some can drive 600R but even that's 150 times too high.
Making the speaker 4Ω makes things worse, an LM386 can't drive that, you need to either use an 8Ω or a higher power amplifier IC like the TDA2003.
Hero999 is offline
Old 20th July 2008, 09:13 PM   #11
Hmm I guess it must be working then. I guess ill just have to get another speaker then for frequency testing.
Thanks alot for you help!
Also for this circuit, is it possible to make a + - power supply like I have with my 2 9 volt batteries with just one battery?
Qaiphyx is offline
Old 20th July 2008, 09:33 PM   #12
You can run this circuit off a single supply with some simple modifications.
Wired up a phase shift oscillator but I dont think im getting a sinusoidal wave-single-supply-phase-shift.gif
Hero999 is offline
Old 21st July 2008, 12:39 AM   #13
That circuit does not take into account the biasing of the output due to the connection to ground of the rightmost R. Neither takes into account the AC loading of the phase shift network by R1.
Below is a circuit that deals with both these problems, and also has a soft limiting circuit to avoid the waveform clipping that will otherwise occur. Simulation shows 3rd harmonic distortion of ≈-43dB.
Wired up a phase shift oscillator but I dont think im getting a sinusoidal wave-phase-shift-oscillator.png
Ron
Roff is online now
Old 21st July 2008, 01:59 AM   #14
Will it still push a frequency with out these changes? These are good changes, I will have to use them. My first goal is to get it working first. Then Ill perfect it
Qaiphyx is offline
Old 21st July 2008, 02:15 AM   #15
If you want to use Hero999's circuit, I would modify it as below.
Wired up a phase shift oscillator but I dont think im getting a sinusoidal wave-heros-pso-modified.png
Ron
Roff is online now
oscillator, phase, shift, sinusoidal, wave, wired
Phase shift - Phase Angle windozeuser General Electronics Chat 20 20th March 2009 10:39 AM
How Can I detect the phase shift between two sinusoidal signals Abdullah2121 Electronic Projects Design/Ideas/Reviews 13 1st April 2008 04:37 AM
TL071 phase shift oscillator shirazmacuff Electronic Projects Design/Ideas/Reviews 4 25th December 2007 04:59 AM
digital phase shift Maryam General Electronics Chat 2 16th September 2004 10:07 AM
Converting 5V sinusoidal to 3.3V sinusoidal wave twinkleBell General Electronics Chat 9 31st January 2004 12:42 AM
