| Hey Is it possible to discharge a lead-acid battery, and then charge it up again the wrong way around(poles reversed)? I'm wondering because i just put a battery into a friends car, his old battery was shot, however, the pole marked plus, was actually minus, and the same for the pole marked minus. I'm guessing this battery is either a production fault, or the above mentioned has happened. The car was an old corolla, so not a lot of electronics to fry luckily.. I must say that I really don't think it seems likely that a factory made a battery the wrong way round, but you never know. Daniel | |
| Yes, it is entirely possible to do that.
__________________ --- The days of the digital watch are numbered. --- | |
| It would totally wreck the battery though.
| Yeah, that's what I thought. I'm just glad I didn't try it on a newer car with more fragile electronics. Daniel | |
| That is not what i'm saying. At least not what i'm trying to say. The old battery had the black lead connected to the minus pole, and the red lead to the positive pole. The battery was really tired, and wouldn't hold a charge very well, so we decided to change it out with one I had laying around in the garage. When i put the "new" battery in, I connected it the same way as the old one, but since someone has probably charged it with the polarities reversed, the pole marked with a plus was actually the negative terminal of the battery and vice versa. Things obviously didn't work very well like this. The car wouldn't start, the lights wouldn't come on etc, so I started measuring around to see what was happening. I switched the leads on the battery and now it works like a charm. But i guess it might wear out rather quickly Daniel Edit: Typo Last edited by Daniek; 20th July 2008 at 01:22 AM. | |
| That is strange. I wonder if it was a recycled battery. | |
| Check the alternator if it is charging. A reversed polarity battery with enough charge left in it, will fry the rectifier diodes.
__________________ There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. | |
| As kids we were illegally driving an old car on the road And we found the faster we went, the dimmer the lights got - we had put the battery on the wrong way round. The series wound starter motor still turned the correct way of course, and because it had a dynamo it didn't have any electronics to fry. | |
| | (permalink) | ||
| Yeah, very strange indeed. Don't really know where it came fram. I think my dad bought it a few yeas ago, but not sure if anyones ever used it. I wonder who would try to charge a battery the wrong way in the first place.. And i would think it would need to have been really deeply discharged, or else it would probably overload the charger? Quote:
| No 'electronics' involved, dynamo's produce DC directly, and the control boxes were just mechanical relays - in fact by pushing one of the relays manually (without the engine running) you could re-polarise the field coil of the dynamo and make it negative earth instead of positive earth. | |
| Positive earth is crap because it can result in corrosion problems.
| It's how all cars were at one time, negative earth came later - and required the introduction of car radios that could be switched to either. | |
| @Hero, Yeah, Ford was positive ground until 1956, relatively recent, so to speak. @Nigel, Ah, the days when you could start a car with a simple paper clip. At least you could tell whether the generator was working. My Honda died a couple of years ago from a bad alternator. No idiot lights, nothing. First thing that went was the speedometer, then only a few seconds later, the engine stopped cold in rush-hour traffic on a freeway. By "dynamo," is that a magneto ignition or generator in American? John | |
Interesting Ford changed from positive earth in 1956, the car in question was an old Ford, probably slightly predating that. | ||
| lead acid battery charging | dimper129 | General Electronics Chat | 3 | 14th April 2008 08:06 PM |
| Lead Acid battery charger | manojp01 | Electronic Projects Design/Ideas/Reviews | 5 | 29th January 2008 06:17 PM |
| Lead Acid Battery | dimper129 | General Electronics Chat | 3 | 18th September 2007 10:23 AM |
| Lead-acid battery zapper | d4d4ng | Electronic Projects Design/Ideas/Reviews | 17 | 24th July 2005 02:54 PM |
| Lead acid battery efficiency | Oznog | General Electronics Chat | 2 | 22nd September 2004 07:08 PM |
