Old 19th July 2008, 05:04 PM   (permalink)
Default Capacitor bypass of diodes in bridge rectifiers
I have see on several audio projects that people will bypass the diodes in a bridge rectifier (discrete diodes or monolithic part) with small .1-.01uF parts. Is this for RF shunting or what purpose do they serve? Thanks!
speakerguy79 is offline
Old 19th July 2008, 05:34 PM   (permalink)
THey might also be used for EMI since a lot of diodes have snap recovery and the capacitor might help soften this. Kind of like a capacitive snubber.
What part of the circuit is the bridge rectifier part of?
NO, that picture isn't me so don't bother asking if we can be friends.
dknguyen is offline
Old 19th July 2008, 05:39 PM   (permalink)
They reduce HF noise caused by the reverse recovery current being switched off when the current carriers in the diodes are depleted.
The fast switching times of this current edge produces HF noise, the capacitor acts as short to the HF noise and prevents it from causing interference with the powered system.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 19th July 2008, 05:58 PM   (permalink)
What's an appropriate size? Just any .1 or .01uF cap, or should I size it based on the speed of the diode? This is for the main power supply bridge rectifier. Thanks guys
Old 19th July 2008, 06:05 PM   (permalink)
It would depend upon the psu's usage, eg: if it was powering an audio system I would use 100nF.
For a bog standard application I would either use 10nF or none at all.!
Whats the size of the reservoir cap.?
Eric
PIC tutorials:
Old 19th July 2008, 06:06 PM   (permalink)
I've seen them before, not on schematics but on the PCB of a ready-made piece of kit.
I assumed they were for RF bypass, so just use 10nF to 100nF and it doesn't matter what type, cheap and nasty ceramics are fine.
Screen name: Aloone_Jonez
Hero999 is offline
Old 19th July 2008, 06:33 PM   (permalink)
Totally variable, active crossover circuits to power amplifier supplies.
Old 19th July 2008, 07:00 PM   (permalink)
The reason for asking, is that in some DIY psu projects, the builder uses a huge value capacitor just after the bridge,
thinking it will kill any noise.
The problem is the very high recharge current that flows for a very short time thru the transformer and rectifiers,
this can cause interference in the powered application.
Eric
PIC tutorials:
Old 19th July 2008, 07:46 PM   (permalink)
I've always been told that they are to prevent mains spikes killing the rectifier diodes - I must admit I've never fitted them in anything I've ever made, but I always use well over rated diodes.
Nigel Goodwin is online now
Protection diodes for H-Bridge MOSFETS speakerguy79 Datasheet/Parts Requests 16 22nd July 2008 02:53 AM
DC Blocking and Bypass Capacitor Values LiquidOrb24 General Electronics Chat 3 2nd June 2008 04:39 PM
How to spec flyback diodes for H-bridge DamoRC General Electronics Chat 5 15th May 2008 04:54 AM
Bypass capacitor? ChArLyZzZ Electronic Projects Design/Ideas/Reviews 3 26th August 2005 05:58 PM
Bypass Capacitor sets the gain and AC walters General Electronics Chat 12 21st August 2005 06:24 PM
