| I studied power supply circuits in the 60's and so I'm more familiar with the terms "half wave", "full wave", and "full wave bridge" as used in the ARRL Radio Amateurs Handbooks. This "bi-phase" term seems a bit cryptic in the context of rectification schemes (in my opinion). Mike Last edited by Mike, K8LH; 24th August 2008 at 12:45 PM. | |
hi Mike, It originally started when the OP asked about the bi-phase rectifier. I posted this link earlier. http://books.google.co.uk/books?id=w...um=9&ct=result
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 24th August 2008 at 12:59 PM. | ||
It's got a center tap secondary and only two diodes. Only 50% of the secondary of the power transformer is used at a given instant, thus if you have a 1000 VA power transformer you can only have a 500 VA (notwithstanding losses) DC power supply. You are forgetting the fact that you can't exceed the current rating of the secondary given VA in must equal VA out. Do the math and check a given transformer's ratings and see for yourself that this can easily be the case. The current rating of the secondary is not simply a function of the duty cycle. Why? Because of the fact that you need to assess the current squared, magnetic saturation, impulse heat dissipation, the resistive thermal coefficient of the windings etc. Remember double the current for 1/2 the time is twice the heat (at the very least). Q: What is the current rating of a conductor based on? A: Its ability to dissipate heat. Q: It's ability to dissipate heat is based on? A: The thermal resilience of the insulation. Q: If you have a 1000 VA transformer rated at 240 / 120 and the secondary is center tapped what would you expect the maximum secondary current to be? A: 1000 / 120 = 8.33 amps Q: Can you then take out double the current for 50% of the time? Why not? You are taking out double the watts for 1/2 the time right? So it should not overheat right? And isn't the current carrying capacity of the conductor limited by the thermal resilience of the insulation? A: No you can't because if we assume an internal impedance of the secondary of 1 ohm, then at the rated secondary current of 8.33 amps we would expect the secondary to dissipate 8.33 x 8.33 x 1 = 69.4 watts over time. However if we then say we are going to double the current for half the time we get 16.66 x 16.66 x 1 = 277.56 watts / 2 = 139.77 watts over time. Now you have twice the maximum rated wattage dissipation of the secondary of the transformer! Last edited by Chumly; 24th August 2008 at 05:50 PM. | ||
| Possibly OT but maybe not as this thread seems to be going circular. I was always fascinated by the attached rectifier circuit. I first ran across it in the ARRL handbook and they did have some kind of name for it. It basically allowed one to generate two different voltage (for both plate and screen voltages) levels from one transformer secondary winding. So in reference to this thread what words would best describe this rectifier circuit? Possibly full wave, center tapped bridge? Or possible it fits the bi-phase term many of us are struggling with here Lefty
__________________ Measurement changes behavior Last edited by Leftyretro; 24th August 2008 at 07:13 PM. | |
| hi, In the early days when using glass tubes/valves it was cheaper and easier to connect a centre tapped transformer to a dual glass tube rectifier in order to get fullwave rectification, it was called bi-phase rectification. To get fullwave would have required at least two/four dual glass tube rectifiers. Now we use a semiconductor FWB...
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
Well not exactly the same circuit. The common split supply uses the center tap to establish the common (ground) reference and generates two equal but opposite polarities, where this supply uses one half of the bridge diode to establish the common reference and generates two different voltage levels but at the same polarity. Surly it deserves a unique name Lefty
__________________ Measurement changes behavior | ||
Exactly the same circuit, just using a different reference point. | ||
However it will not saturate even if run at 100W (although it will overheat if run continiously) because the flux generated by the secondary will still be 100VAs worth. However bi-phase, still is full wave rectification because power is being used from both the positive and negative cycles of the mains supply. If it were half wave rectification then the transformer core would saturate if run at 70.1% of the rated power and overheat. Last edited by Hero999; 24th August 2008 at 09:04 PM. | ||
Lefty
| Abusive post deleted, such posts are NOT permitted here. Moderator. Last edited by Nigel Goodwin; 25th August 2008 at 11:54 AM. | |
| You have been reported to the moderator for personal attacks An ad hominem argument consists of replying by attacking the poster. The process of proving or disproving the claim is thereby subverted, an ad hominem works to change the subject and attempt to discredit the poster. | |
Just admit you made a mistake as I have done.
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez | ||
| junction rectification | bad_phonics_monkey | General Electronics Chat | 4 | 30th November 2007 01:37 PM |
| Effiecent rectification and regulation of stepper motor generators? | HarveyH42 | Alternative Energy | 11 | 10th July 2007 02:59 PM |
| Help...How to generate a quadrature signal (cos wave and sine wave)? | hykwei | Electronic Projects Design/Ideas/Reviews | 2 | 9th May 2007 05:52 PM |
| Does PWM DC = half-wave AC ? | liquidics | General Electronics Chat | 5 | 2nd March 2006 07:41 PM |
| Question about AC rectification | Glyph | General Electronics Chat | 2 | 2nd July 2004 07:02 AM |
