Notices
Old 20th July 2008, 06:57 AM   (permalink (permalink))
First of all half-wave is not a less efficient configuration in terms of actual power used (if one neglects transformer losses), so you are wrong when you say "company XYZ CEO could care less if your power bill goes up" it would not versus full-wave because VA in = VA out as discussed many times (notwithstanding transformer losses).
You are mistaken. A half-wave only uses half the power put in and this is a loss of half the power that is provided. The fact is two cycles AC in and only use one cycle is inefficient.
In any case (as discussed above a number of times) the main thrust of my post is neither transformer calculations or half wave calculations it's bi-phase, which is neither a bridge nor a half-wave.
What for Pete's sake is a bi-phase rectifier? Never heard of it. Please explain. Do you have a diagram to enlighten me with?
Only thing I can think of is you are talking about a full-wave.
Mikebits is online now
Old 20th July 2008, 07:10 AM   (permalink (permalink))
Look up rectifier on Wikipedia, and look for the second of the full-wave rectifier circuits (third of the nice green AC half cycle drawings). I believe this is what the OP is targeting...
Corey
Rapp's Law of Inanimate Reproduction:
"If you take something apart and put it back together enough times, you'll eventually have two of them."
saturn1bguy is offline
Old 20th July 2008, 07:23 AM   (permalink (permalink))
Ok, Don't we call that a Full-wave?
Old 20th July 2008, 07:28 AM   (permalink (permalink))
Yes, it's full wave, but there are two full-wave schemes, the bridge and the ?? (that's where we stumble into "bi-phase").
Corey
Old 20th July 2008, 07:31 AM   (permalink (permalink))
Nope you are wrong again!
The 50% of the time the input sine-wave is not providing output power, said power is not (as you call it) "put in" at all.....it is in fact simply not used!
Again, there is no (as you call it) "loss of half the power", notwithstanding transformer losses!
VA in must equal VA out as discussed many times already, notwithstanding transformer losses. You do not understand how a transformer works vis-a-vis power transfer through mutual inductance.
Chumly is offline
Old 20th July 2008, 07:39 AM   (permalink (permalink))
------------Edit------------
I got a little hot under the collar, but cooler head prevailed and I retract my original input.
Old 20th July 2008, 07:55 AM   (permalink (permalink))
Originally Posted by Chumly View Post
Could you expand a bit more on the acronyms and other terms you are using (and the math too) so I can be sure of what you are talking about please?
Sure:
A) "Requires a slightly beefier transformer build (Pt/Pd of 1.5 vs. 1.23)" means the ratio of input power to output power. This is specified for all five standard rectification schemes, from half-wave to 3-phase bridge. For your "bi-phase" circuit it's 1.5, meaning if you want 100VA out, your transformer input will be 150VA (or 123VA transformer input for the full-wave bridge). And since there are standardized transformer core sizes specified in VA, you go up a size or two for the "bi-phase." (A half-wave circuit requires 310VA in for 100VA output, the worst of the bunch).
B) "Requires higher voltage diodes (Vrrm/Vrms of 3.12 vs. 1.56)" means the ratio of diode peak inverse voltage rating (e.g. 50V for a 1N4001) to the secondary output voltage in volts RMS. For example, a 25.2VCT transformer secondary, Vrms = 12.6V, which means the rectifier must sport a Vrrm of 39V (or 20V for the full-wave bridge).
C) "Superior in one way: Irms/Iout of 0.78 vs. 1.11 for a bridge (or 1.11 vs. 1.57 with filter capacitor)" means the ratio of AC output current in amps RMS from the transformer secondary to the DC output current through the load (resistively and capacitively, respectively). For example, for 1A DC load current through a resistor, the "bi-phase" circuit pumps in 780mA RMS from the transformer (or 1.11A RMS using a bridge).
Corey
Old 20th July 2008, 10:38 AM   (permalink (permalink))
Nope, that's a four diode, dual-DC-supply using a center tap transformer, that's not a bi-phase circuit as described (a two rectifier configuration with the secondary of the power transformer having a center tap).
Maybe dual bi-phase, but that's not what I'm referencing, if you read my text carefully I spec two rectifiers and a center tap. I suggest you check out the history of tubes in this context for background on the original rationale of reducing the number of rectifier tubes. But in modern solid state such a configuration is iffy for the reasons given. You're welcome to show otherwise with actual modern popular solid state DC power supply examples.
Yes exactly, a DUAL BI-PHASE circuit.
I cant help but think that your argument is but a storm in a tea cup.
Just because a technique is old, it does not mean that it is totally obsolete and should be ignored.
And yes I am familiar with old valve circuits, I started with them in the early 1960s.
JimB is offline
Old 20th July 2008, 02:00 PM   (permalink (permalink))
Nope, I’m sorry to say. No filtration of any kind has been referenced and you have not described a bi-phase configuration. It's all there if you read my posts carefully, and do the needed research.
Would you please clarify the following acronyms with full word definitions:
CT you mean?
28VCT you mean?
Cheers!
CT means centertapped
28VCT means 28 volts centertapped or 14 volts each side of centertap.
If I replace the filter capacitor in my description with a resistor it is the exact circuit of the second full wave rectifier in your reference on wikipedia.
I still maintain it is a valid configuration in use today. I also believe it is a efficient type of power supply, and it can be more efficient than the full wave bridge circuit as there is one less diode voltage drop.
k7elp60 is offline
Old 20th July 2008, 02:25 PM   (permalink (permalink))
I agree, I also use the CT, bi-phase connection in some projects.
Ref:
http://books.google.co.uk/books?id=w...um=9&ct=result
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 21st July 2008, 01:48 PM   (permalink (permalink))
To further edify:
The main point of the thread however is bi-phase, it's in that context I posted, I just threw the other stuff in there as it was no more work to post, it has some commonalty and I must teach it as well.
You see I am a teacher, and bi-phase comprises a substantive amount of the mandatory course material as it relates to power electronics.......but it would appear bi-phase (as it relates to power electronics at the least) only has a place in tube rectifier circuits.
I am not teaching vintage audio, guitar amps, nor tubes at all nor are they referred to at all in the power electronics section of my course.
I am teaching apprentice electricians actually, so power electronics is applicable to the learning but I don't see how an emphasis on bi-phase is of any net benefit when time is short and there is much material to cover.
I suspect this ongoing emphasis on bi-phase in the power electronics course material (and on the exam) is an antiquated holdover from the halcyon days of big industrial tube DC power!
Some uses of the "bi-phase" rectifier:
>>> When the voltage drop across each diode is big (with respect to the output voltage): Inside a PC (personal computer) power supply, the "main" supply (5v or 3.3v) output stage has a small transformer (operating at a high freccuency) with a center tapped secondary, and tho diodes in a bi-phase configuration.
>>> When you need a DC supply and an AC supply that have a common "ground"
>>> Dual (+/-) supplies. They may be seen as two bi-phase rectifiers that use the same transformer or as a bridge with a grounded center tap.
>>> And, of course, vintage circuits and "antiquated holdovers" in new designs made by people that have learned in the "old days" and still use that configuration.
E Cerfoglio
Buenos Aires
Argentina
ecerfoglio is online now
Old 21st July 2008, 02:13 PM   (permalink (permalink))
A bi-phase rectifier is a form of fullwave rectifier becuase the power is being used from both sides of the AC cycle - it's silly arguing about it.
Screen name: Aloone_Jonez
Hero999 is offline
Old 24th August 2008, 06:45 AM   (permalink (permalink))
Only 50% of the secondary of the power transformer is used at a given instant, thus it is not the same as other full-wave rectifier schemes.
Chumly is offline
Old 24th August 2008, 10:18 AM   (permalink (permalink))
Default bridges
first of all with a tube full half wave rectification you loose about 90 volts across the tube. 5u4 and so on. half wave you get the half the rectification as a pulsating DC needs big caps to smooth out the ripple full wave as in CT trasformers you will get half the voltage available. with a bridge rectifier and the same transformer you will get twice the voltage. current available will be the same as kva. You like to know more?
neon is offline
Old 24th August 2008, 10:24 AM   (permalink (permalink))
That's nonsense 100% of the secondary power is used and more importantly 100% of the primary power is used, i.e both positive and negative cycles are used which by definition full wave rectification.
You could use a 100VA transformer with a bi-phase resctifier and still happily take 100W from the output because although each side of the centre tap on secondary is passing double the current the duty cycle is halved so it's alright.
Hero999 is offline
junction rectification bad_phonics_monkey General Electronics Chat 4 30th November 2007 12:37 PM
Effiecent rectification and regulation of stepper motor generators? HarveyH42 Alternative Energy 11 10th July 2007 01:59 PM
Help...How to generate a quadrature signal (cos wave and sine wave)? hykwei Electronic Projects Design/Ideas/Reviews 2 9th May 2007 04:52 PM
Does PWM DC = half-wave AC ? liquidics General Electronics Chat 5 2nd March 2006 06:40 PM
Question about AC rectification Glyph General Electronics Chat 2 2nd July 2004 06:01 AM
