I'm starting an altimeter project. Right now I'm using a 7segx3 display, but in the future I want to display the altitude using a needle, just like the mechanical types. I'm using one of the motorola pressure sensors and a PIC (still don't know if the pic's ADC will do or if I will need a better ADC). The fundamental question is: How digital information can be displayed through an analog needle? I'm looking for a solution that is easy to implement (few parts), cheap and reliable. Cheers |
through the digital information your ADC has processed use your PIC's pulse width modulation to control a servo that rotates the needle to that certain degree it should display on the meter, maybe?
only thing you will have to purchase (since you already are going to have a PIC+ADC or PIC only) would be a sub-micro servo - since i imagine you wont have too much space behind your meter, else you can go for a cheaper but larger servo.
transistance is futile... Last edited by transistance; 16th July 2008 at 02:41 PM. |
I had originally thought about a stepper motor that is sized like the motors that spin CD's on a CD reader, but I thought it would be too much of a hassle.
The servo would be very simple, as I've interfaced with those a lot in the past, but the size aspect is concerning. Another concern is how smooth the movements are. I don't know if they will be smooth with a servo. |
If you use a PIC that has a hardware PWM module (eg. a 16f628) then you can easily vary the pulse width ratio of an output.
This can be smoothed by a capacitor if required to create a varying voltage which could be measured by an analogue voltmeter meter. Info on configuring pwm is here: http://www.piclist.com/tecHREF/microchip/pwm.htm There is an interesting open source project that uses analogue meters and PWM for showing various information at: http://www.sharebrained.com/chronulator/ It uses a different make of microcontroller, so would need a bit of conversion. |
on another thought: how does those gauges in modern sportbikes (I have an 04'gixxer 600) work? I bet the RPM/speed is encoded to a sort of MCU then displayed on the instrument cluster. How that works?
A servo will have a very smooth motion since it has numerous amounts of gears in it. The problem with the servo is how responsive it is going to be, yet you would have the same or larger amount of response issue with a stepper motor in my opinion. When it comes to size, do not worry about it. There are unbelievably tiny servos that are commercially available now.
transistance is futile... Last edited by transistance; 16th July 2008 at 02:54 PM. |
(permalink) | ||
Why not just use a few op-amps to do the scaling and offset and drive the analogue meter directly? JimB
Experience is directly proportional to the value of the equipment ruined. |
Yes, ratiometric per input voltage.
The point is: which analogue meter? |
Ken
"To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) |
The mechanical altimeters I'm used to and trying to replicate are the skydiving ones (yes, I'm one of them). They have 360 degrees motion. Calibrate zero ft with a dial and most of them to as high as 12000ft, but they will read 1000ft at 13000ft for example. So, if I use a servo, I'll need to modify it in order to rotate more than 180 degrees... but that introduces other problems (it is not a servo anymore) |
I know there are hacks out there for 360º "continuous" rotation of R/C servos. I did a quick Google and came up with these:
http://www.servocity.com/html/hs-785...rotations.html But the 3.5 revolutions for 200 steps of "servo control" results in 6.3º per step...only 57 steps for one rotation...not to good for an altimeter display http://www.kaper.us/basics/Bas_360_R.html Methods 1 and 2 would actually give you 360º rotation, and the resolution would only go from ~1º/step to ~1.2º/step...not bad. Ken
"To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) Last edited by KMoffett; 16th July 2008 at 06:35 PM. |
Nobody to comment on what's behind the RPM gauge on my bike? Can't I use something similar to that?
It looks like a 270º analog meter...but that's a guess. Seems like those are only common outside the USA or in automotive displays.
Ken
(permalink) | ||
The problem with these are that they have very deep cans behind the meter face. From what I see of skydiving altimeters, they are very flat. Would this be a problem padu?
Ken
| Digitally adjusting gain | 2camjohn | Micro Controllers | 22 | 10th June 2008 05:47 PM |
| Digitally counting | yankos243 | General Electronics Chat | 3 | 7th February 2008 04:32 AM |
| True RMS measurement digitally with PIC | atferrari | Micro Controllers | 6 | 25th April 2006 10:16 PM |
| Digitally turned FM reciever. | shanr | General Electronics Chat | 3 | 17th September 2004 04:10 AM |
| Control Digitally? | King of Camelot | General Electronics Chat | 5 | 4th August 2003 01:00 AM |
