| Notices |
| | (permalink (permalink)) |
| My problem is this. I have four 12v transformers working and they cause bad humming on an unrelated electronic device that I am using. The four transformers are 24 inches from the device that I am using. But the interesting thing about my problem is that if I remove two transformers, that is to say, if I pull two of them from the single surge protector/power tap that I have all four plugged into, the humming stops completely. If I add a third, the humming returns. If I plug a third transformer into a receptacle across the room, the humming returns. Can anyone please tell me WHY there is this two transfomer limit? I really need to have all four transformers working and my electronic device as well. Thank you. | |
| Welcome Germaniohm, to electro-tech-online. Imagine each transformer having load of different power factor. The currents flowing will be at different phase angles. This causes the additional ripple that you hear, as I suppose. Please try adding a 2µF capacitor/400V ( in case of 230V supply) across each transformer. They would try to compensate for the Power Factor.
| MVS SARMA: Thank You. Do you mean: 1.Locate the primary (positive conductor) on said 12v transformer. 2.Sever the primary conductor and strip the insulation off the newly cut ends. 3.Solder the 2microfarads/400AC capacitor onto the primary conductor ends (according to polarity if there is one) 4.Tape the newly soldered wires with pvc tape to reinsulate the pimary conductor/2microfarads-400AC capacitor splice? Thank You | |
| Far too many unknowns here to make any diagnosis or suggested cure. How big are the transformers, what is their power rating? What is the electronic device which is humming? In what way does it hum? Does it have a loudspeaker which hums, or does it just make a noise? What is the power supply to this place? Is it on the end of a long overloaded cable? JimB
| I would say buy one 12 volt transformer that can supply power to the same devices as the current bank of four would be better. Adding more components to the existing setup is at best a stop gap measure, you're better off taking a broad look at exactly what you're trying to do and simplifying it as much as possible. So the first question I have to ask is why 4 12 volt transformers instead of one? If you need to have different devices on at seperate times run swithches after the transformer.
You may try to increase the distance between the power and audio transformers (magnetic field decays with the square of the distance, so sometimes even a small distance increase - a couple of feet or half a meter - reduces the hum to unnoticeable levels). Other thngs you may try: >>> Enclose the isolation transformer in a steel enclosure to act as a "magnetic shield" - it ay even be an used food can, just be sure it is steel and not aluminium) >>> Verify that the audio signal travels along screened cables, and that the screen is connected to ground at only one point (the ideal setup is a cable with a twisted pair for signal and return - even if the retirn wire is grounded - surrounded by a grounded screen.
__________________ E Cerfoglio Buenos Aires Argentina | ||
If each of your transformers outputs 12 VDC @ 500 mA you may use a 12VDC 2A one to power your four cameras.
| This could be caused by many things but if its a PFC issue then you will need to do the math to fix it. Most devices need to go through radiated emmissions testing before going on sale so radiated noise is 'fairly' unlikely especially if its just a power supply 2 feet away. Try a filtered multi-plug adaptor since I guess its conducted emmissions. Alternatively (as mentioned above) try to shield the device to determine whether the interference is radiated or conducted. S.
__________________ advert removed by moderator. | |
Ground** is a relative term, if you have a 2 wire system your ground may be your computer case - you may connect the cable screens to the outer conductor of the RCA (or phone) plugs, or else to one of the screws that close the PC's case. ** (EDIT) I'm speaking of a signal ground, not a safety ground. A safety ground must comply to your local codes.
__________________ E Cerfoglio Buenos Aires Argentina Last edited by ecerfoglio; 18th July 2008 at 11:27 PM. | ||
| Mystery Part | Nuer Tek | Datasheet/Parts Requests | 12 | 20th April 2008 01:35 AM |
| A Mystery of Life | NightFalcon90909 | General Electronics Chat | 10 | 7th March 2008 08:32 PM |
| Help Identifying Mystery IC | RabbitResearch | Datasheet/Parts Requests | 2 | 27th May 2007 04:24 AM |
| Mystery Connector? | lavenatti | General Electronics Chat | 2 | 14th January 2005 01:18 PM |
| Mystery Graphics LCD | Dave the Embalmer | General Electronics Chat | 1 | 12th March 2003 11:13 PM |
