how do i open a crystal and still be able to use it outside of its case?
I read that the crystals with HC49U packages are resistance welded together. This is a sort of curiousity question cause i want to experiment with the bare crystal for a project. |
A Dremel tool and a very steady hand.
could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." |
"How do i open a HC49U crystal case?" << Very carefully
Agree, your best bet would be a Dremel with a fine cutting disk. |
Crystal..gifThere appears to be a slight lip at the base that has been resistance welded. I would try metal snips or diagonal cutters to remove the lip and fracture the weld. Abrasive cuttoff will no doubt open it, but I would be concerned that vibration and contamination from sparks or abrasive dust might damage the crystal.
John |
I had and may still have a large collection of older crystals in holders that can be opened easily. Some of my pals have lapped the crystals or marked on with graphite to alter the frequency. If you lived close by I'd give you some - if I still have them. They were given to me - in 6 to 8 mHz range.
stevez |
I don't live close by but thanks for the offer.
i'll see if i can cut out the bottom with a dremel. |
Five minutes work with a junior hacksaw and the case is open.
The hard parts are: Holding the crystal firmly in a vice without crushing the can. Making sure that the hacksaw does not pull the crystal out of the can and onto the floor. (As happened on my first attempt, smashing the quartz). JimB
Experience is directly proportional to the value of the equipment ruined. |
wow, nice work!
ever try pulling a crystal out of a quartz cylinder? (the kind for wrist watch crystals) |
Thank you.
| Switch through case ? | 3v0 | General Electronics Chat | 6 | 28th May 2007 11:59 AM |
| Where can I buy this case (db9 gender) | William At MyBlueRoom | General Electronics Chat | 3 | 3rd July 2006 08:26 AM |
| PCB Headers (pc case style) | Adam | General Electronics Chat | 4 | 14th April 2006 01:29 PM |
| Case Modding | tansis | General Electronics Chat | 0 | 23rd June 2004 09:19 PM |
| how to do case select in ASM?? | belinda_sg | Micro Controllers | 3 | 19th February 2004 10:17 PM |
