There are frequent threads about "what common parts should I have". I would like to add this to the list as one that should be mentioned.
It's a simple IC function generator that can produce sine, square, and triangle waves with variable amplitude and can operate from single or dual supplies. I have confirmed operation from 0.2Hz all the way up to 1MHz depending on R/C combinations. All it takes is a few resistors, a potentiometer or two, and some small caps (10uF and less). It has built in functionality for FM and AM modulation of its output with a few more components added. My only gripe is that the square wave rise time is huge (400ns) compared to its fall time (40ns). I'm guessing this is because of the weak (10K) pullup resistor on the square wave output pin. I tried putting in a 1K and it didn't like it, and I haven't tried any intermediate values. I also noticed a little bit of jitter, but my test setup didn't use any of the stabilizing components (like the bypass cap on pin 3). But for under $5 in parts, it is a very useful addition to anyone's toolkit. |
I don't think EXAR has made the XR2206 for many years but a few places still have some.
Since you didn't use the recommended stabilizing parts then you are asking for trouble.
Uncle $crooge |
The only important one I deleted was the bypass cap on the voltage divider that sets the DC output rail, and a Vcc decoupling cap (I just had a low ESR electrolytic from power to ground, so no real bypassing >1MHz). It functioned perfectly fine, though I plan to add them on my next board (this was a 'how does this thingy work' first run).
Edited to add: Exar still lists it on their site, and the data sheet was updated Feb of '08. I hope it's still in production. http://www.exar.com/Common/Content/P...aspx?ID=XR2206 Last edited by speakerguy79; 16th July 2008 at 02:50 AM. |
The part still looks current in the Exar data base.
http://www.exar.com/Common/Content/P...aspx?ID=XR2206 |
Also, further reading of the data sheet confirms the difference in rise/fall time of the square wave (listed as 250ns/50ns respectively, where I was getting 400ns/40ns).
PS: My edit beat you by 1 minute Last edited by speakerguy79; 16th July 2008 at 02:54 AM. |
Digikey and Newark are the largest American and Canadian electronics parts suppliers and they do not even list the XR2206 anymore.
Uncle $crooge Last edited by audioguru; 16th July 2008 at 03:04 AM. |
Digikey doesn't carry Exar. Future and Jameco have them in stock, but manufacture date is in question. The ones I have from Future have a manufacture code F0747 but I can't find how to decode that.
I emailed Exar about its production status and hope to get a reply back. Last edited by speakerguy79; 16th July 2008 at 03:16 AM. |
I think 747 is the 47th week of 2007. Near the end of November about 7.5 months ago.
Or maybe the 47th month of 1997. 1987? 1977? It is a very old IC.
Uncle $crooge |
This is just a joke, no offence intended... |
[quote=Mikebits;327818]Old is not always a bad thing, afterall we do still value your opinion
QUOTE] Gee, thanks Mike, that me makes me feel so much better... Regards
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 16th July 2008 at 06:54 AM. |
Eric, as you know, I hold you in the highest regards and I still await your first blog
Many years ago, I used the Intersil ICL8038 function generator IC.
I have never seen the EXAR one.
Uncle $crooge |
I used a 20-turn trimpot that allows me to tune the frequency with a decent resolution. Since the square wave output is open collector I placed another switch to select the high level between Vdd (=15 V) and +5 V (TTL-compatible) generated by a voltage regulator. Last edited by eng1; 16th July 2008 at 06:35 PM. |
If all else fails, I have a bunch of the Older ones. New and unused.
I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec |
| XR2206 Signal Generator | ronchiejames | Electronic Projects Design/Ideas/Reviews | 11 | 22nd May 2008 10:16 PM |
| Name that part | Sceadwian | General Electronics Chat | 9 | 2nd March 2007 10:11 PM |
| Anyone know what this part is | mramos1 | General Electronics Chat | 9 | 2nd January 2007 04:28 AM |
| help xr2206 | japl | Micro Controllers | 1 | 6th November 2004 09:14 AM |
| is this the right part? | Kane2oo2 | General Electronics Chat | 4 | 8th March 2004 07:02 AM |
