Old 14th July 2008, 04:41 AM   #1
Default How sensitive are high sensitive relays?
I know small electric motors (for example one of the ones you get at radio shack for 5 bucks) will generate power when spun by there shaft from an outside source. Are there any relays that are sensitive enough so that they could be hooked up to the motor and than trip the relay when the motor spins at a low rpm?
avajoe is offline
Old 14th July 2008, 04:52 AM   #2
I doubt it. An electric motor must be spinned fast to make enough voltage and current to (power) activate a relay.
audioguru is offline
Old 14th July 2008, 05:40 AM   #3
Depends on the motor, relay and finger strength. You can get some pretty sensitive relays. How does 3V@17ma or 1.5V@33ma sound:
http://www.mew.co.jp/ac/e_download/c...ch_eng_txs.pdf
kchriste is offline
Old 14th July 2008, 05:43 AM   #4
Smile
Hi.
From the relays I have and used, the most sensitive is the Teltone M-949-01; works with 20mA.
If your spinning motor can generate such at the speed you spin it, it will work.
It is not easy to find lately; seen it at some surplus stores years ago.
Miguel
Abolish the deciBel !
Externet is offline
Old 14th July 2008, 11:57 AM   #5
I suggest trying a small unipolar stepping motor, e.g. a floppy disk drive stepper for the read/write head. Without any external circuitry in can drive an LED with just a little twist on the shaft. Using rectifier diodes and connecting the outputs parallel you should get reasonable current to activate at least a reed relay.
Boncuk
Boncuk is offline
Old 17th July 2008, 09:22 PM   #6
Boncuk
thats a good idea thanks, Im trying to come up with an old drive to take apart and test it
avajoe is offline
Old 17th July 2008, 11:13 PM   #7
... and try a reed relay if you want to switch any device. They are normally rated 12mA, which is below the current used for miniature relays (20mA and more)
Boncuk
Boncuk is offline
Old 18th July 2008, 06:26 AM   #8
Mind you if such a relay were fed from a Darlington or modest gain BJT it would trigger a 'sensitive relay' on micro amps. Use a resistor/capacitor low pass filter and you can prevent oscillation and provide moderate latching times.
straight answer, har har."
Sceadwian is offline
high, relays, sensitive
Is PIC more sensitive on the EMI? boncker Micro Controllers 2 25th April 2006 10:02 PM
sensitive preamp paulyt5966 General Electronics Chat 2 15th September 2005 01:14 AM
Sensitive CMOS Elektor General Electronics Chat 5 18th August 2005 09:56 PM
light-sensitive tv gun thiaguetz Micro Controllers 1 22nd March 2005 06:08 AM
Pressure Sensitive Pad LApprenti Sorcier Electronic Projects Design/Ideas/Reviews 5 6th July 2004 02:11 PM
