Old 11th July 2008, 05:28 PM   (permalink)
Default Input impedance, amplifier
Hi!
I would like to know if i have one ordinary audio amplifier and if i change volume (gain) at this amplifier is this influence to input impedance ?
so if i have 10% louder or 80% is impedance change ?
I hope so that you understand me what i mean.
There are two major products that came out of Berkeley: LSD and BSD. We don't believe this to be a coincidence. —Jeremy S. Anderson
sniper007 is offline
Old 11th July 2008, 08:39 PM   (permalink)
Generally the input impedance is fixed and is not affected by the volume control.
Carl
crutschow is offline
Old 11th July 2008, 08:41 PM   (permalink)
Originally Posted by sniper007 View Post
Hi!
No, because you offer no context - there's no such thing as an "ordinary audio amplifier" - post the circuit you're refering to and we can discuss that.
Old 11th July 2008, 08:46 PM   (permalink)
On an operational amplifier the input impedance will change with the set gain. A unity gain operational amplifier gives a near infinite input impedance.
Raise the feedback resistor to obtain some gain and input impedance decreases.
On other types of amplifiers, it may not be the case.
Miguel
Abolish the deciBel !
Externet is offline
Old 11th July 2008, 08:52 PM   (permalink)
Miguel
I suggest you try reading your opamp theory again, input impedance is set by the input resistor on both inverting and non-inverting amplifiers - nothing to do with gain.
Old 11th July 2008, 08:55 PM   (permalink)
OK, look
I'm going on sea and i don't know if i can safety connect my IPOD nano to external computer speakers like this one http://www.maincomp.com/uploads/CB-80401.gif which has amplifier integrated.
Old 11th July 2008, 10:36 PM   (permalink)
The output of the ipod will probably drive the computer speakers perfectly.
But the computer speakers are small and will not have any bass nor much power.
There is nothing that is unsafe. The ipod has a low output impedance that has mA of current and the computer speakers have an amplifier with a high input impedance that draws only uA of current.
But check the input sensitivity of the computer speakers to see if the output level from the ipod is high enough.
audioguru is offline
Old 12th July 2008, 12:16 AM   (permalink)
OK tnx all alot
Audioguru please tell me what does this Input Sensitivity mean ?
I found specification for my hi-fi amplifier:
Input Sensitivity/Impedance
CD/DVD, etc. ............................................... 150 mV/47 khm:
PHONO .................................................. ...... 2.5 mV/47 khm:
Output Level
REC OUT .................................................. . 150 mV/1.6 khm:
Headphone Output ............................................. 0.25V/680hm:
Old 12th July 2008, 01:09 AM   (permalink)
The input sensitivity of your hi-fi amplifier is an input of 150mV RMS for full output when its volume control is maximum. Its input impedance is 47k ohms.
Your ipod probably has an output of at least 250mV RMS so it will drive your amplifier to full output on loud music peaks with the volume control turned down a little.
The computer speakers also probably have the same input sensitivity.
Old 12th July 2008, 09:55 AM   (permalink)
OK, I found another explanation, is it correct?
higher sensitivites mean lower levels of input signal the voltage levels and power are most often rms values, higher sensitivies mean that the amp can be driven from sources with lower level
I don't understand what is bold. If amp have higher sensitivies (input signal can be higher consequently input level can be higher no lower ? )
Old 12th July 2008, 10:15 AM   (permalink)
Its a badly written explanation [ the bold section]
Its trying to say, the amplifier has a higher gain.
Do you follow OK.?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 12th July 2008, 01:46 PM   (permalink)
OK, understand
Old Today, 06:27 AM   (permalink)
I think summary of ur says is:
Amplifier input impedance doesn't depend on the source
elecom is offline
Input Impedance Matching DigiTan General Electronics Chat 7 1st February 2008 08:48 PM
lowering impedance on a class D amplifier amplifierfreak Electronic Projects Design/Ideas/Reviews 5 27th June 2007 08:56 PM
PIC analog input impedance question Futterama General Electronics Chat 8 24th February 2006 11:56 AM
Using pc as a signal generator - input impedance query Megamox General Electronics Chat 5 17th November 2005 05:56 AM
Comparator behavior with High Impedance input Splinemodel General Electronics Chat 1 28th August 2003 06:51 PM
