Old 11th July 2008, 02:52 AM   (permalink)
Default Need Help with latching alarm?
I purchased a door alarm that has one of those magnetic switches that attaches to a door and the door frame.
When I close the door, the alarm does not stay on because the magnet is activating the reed switch.
How can I modify it so the alarm stays on (for a pre-determined time or not) after the door has been shut?
I was thinking of using a 555 but not sure how to wire it up.
Thanks.
Nicksan is offline
Old 11th July 2008, 03:06 AM   (permalink)
is it the intention that the alarm goes off when the door goes open and the activated divice stays on for a while
or is it the intention to have the alarm going off when the door gets closed and the activated device stays on for a while
what is the time lengt you looking for ??
Robert-Jan
rjvh is offline
Old 11th July 2008, 03:16 AM   (permalink)
Yes, I would like for the alarm to stay on for a while after the door is opened and after the door is closed, Maybe for five or ten minutes.
The problem with the design of the alarm as it is now is, When the door opens, the alarms sounds off but all you have to do is close the door to stop the alarm because the magnet opens the reed switch on the alarm.
Nicksan is offline
Old 11th July 2008, 03:35 AM   (permalink)
if you need 5 till 10 minutes than i would use a 4060 timer ic instead of a 555
i will post you a shematic today but I am very busy at my work now so it could take a while
Robert-Jan
rjvh is offline
Old 11th July 2008, 03:56 AM   (permalink)
Ok quicker than i did foresee
I forgot to draw 1 diode and that's the one over the relais
i do advise you to down load also the data sheet from the 4060 as you can find out the diferent times on diferent outputs
you also can play with the capasitors conected on pin 9 and of course the resistors on pin 10
the resistor on pin 11 i would not make it smaler than 1 Mhm:
sucses with building it
Robert-Jan
rjvh is offline
Old 11th July 2008, 04:10 AM   (permalink)
Thanks for the schematic. Would it be possible to downgrade the voltage required to something around 3 to 6 volts, because thats around what the alarm uses and I have no idea how to make 16 to 20 other than compiling a bulky mess of D or AA cells?
Nicksan is offline
Old 11th July 2008, 04:54 AM   (permalink)
5 a 6 volt is fine (instead of the 7812 use the 7805) but it will effect the timing so you have to tweek a bit with the outputs or capacitors/resistors
also your relais should be a 5v one
you can make a power supply feeding from the net
transformer, bridge rectifier , capacitor feed it in the 7805 and there you go
not that complicated
Robert-Jan
i
rjvh is offline
bi-stable latching relay? wsemajb General Electronics Chat 10 4th June 2008 12:32 AM
Latching ic, is there such a thing? shaneshane1 General Electronics Chat 22 24th November 2007 01:06 AM
What is a latching relay vers a non latching relay MrDEB Electronic Projects Design/Ideas/Reviews 7 22nd November 2007 02:44 PM
latching/non-latching momentary switch?? goatboy Electronic Projects Design/Ideas/Reviews 4 5th September 2006 03:05 AM
latching circuit goodpickles Electronic Projects Design/Ideas/Reviews 3 8th February 2005 01:56 PM
