Old 9th July 2008, 06:09 PM   (permalink)
Default remote control sending unit power source
Hello
I have made an IR sender / receiver unit, and want to know the best way to power the sending unit.
Currently its using a PIC12F675 which is 5 volt logic, and this obviously needs to be powered by battery, id rather not have a 9V battery as there big and heavy, but two AAA's only make 3 volt.
is there any good way for getting from 3 to 5 volts? or any other things you could suggest to resolve this issue?
Many thanks
Dominic.
DMW is offline
Old 9th July 2008, 06:31 PM   (permalink)
you could try a 3 volt to 5 volt DC-DC converter.
you can get a bunch of results on google for making these
or i used to skin my 9volts inside are six indiviual cells smaller then AAA, i dunno if that is recommended or not. you could remove 2 of the cells and get 6 volts.
joshua17ss2 is offline
Old 9th July 2008, 06:35 PM   (permalink)
From the 12F675 datasheet; "Wide operating voltage range - 2.0V to 5.5V"
House0Fwax is offline
Old 9th July 2008, 10:18 PM   (permalink)
Really, oh fantastic, sorry i really should of noticed that
thank you very much!
DMW is offline
Old 9th July 2008, 10:23 PM   (permalink)
Brainfart, never mind
Mikebits is online now
Old 9th July 2008, 10:30 PM   (permalink)
Unhappy
well all the circuitry is, is a pic 12F675, an IR LED and driving transistor
the IR LED is driven at 100ma at 62.5% duty cycle [30ma average] and thats it
when the PIC is not in use i plan on putting it to sleep which is 1nA @ 2V
operating current will be while it transmits the signal which is for around 18ms plus some calculation time call it 22ms with operational current 100uA @ 1mhz [im running it at 4mhz, 1mhz instruction cycle so roughly 400uA?].
so when sending IR data its around 400uA PIC + 30mA IR LED + 3mA transistor Base = 33.4 mA
and when in standby 2nA call it.
so not much
DMW is offline
Old 9th July 2008, 10:37 PM   (permalink)
so not much
Argh, you read my post before my edit. For those saying huh? I had asked about IR power needs, then realized my post was a dumb question, then retracted my statment. Sorry for the confusion.
Old 9th July 2008, 10:40 PM   (permalink)
Personally speaking, I'm not good with maths. Though from what you have said, I'd just try the unit with a 3v supply and see how long it lasted etc.
That said, I have seen many examples of 'keyring' remotes that use a microcontroller ( of one kind or another ) and are powered by the good old 2032 3v cell.
lol dont worry, its not as stupid question as my original
Edit:
Thanks HoW, ill keep that in mind as then it will be even smaller, although my experience is that; that style of battery is very expensive [e.g. cheaper to buy a new watch than replace the battery]
DMW is offline
Old 10th July 2008, 12:32 AM   (permalink)
I saw some 3V lithium battery cells at the Dollar Store. Only a few were leaking.
Guess where they are made.
audioguru is offline
Remote thermostat, AC unit is running all the time mramos1 Electronic Projects Design/Ideas/Reviews 4 3rd June 2008 08:56 AM
control unit driver srimannarayanakarthik Electronic Projects Design/Ideas/Reviews 4 6th March 2008 12:40 PM
Remote control Power Wheel MARINE1142 Electronic Projects Design/Ideas/Reviews 2 11th February 2008 10:14 PM
RF remote control power drain johnsmith123 General Electronics Chat 9 27th December 2007 04:35 AM
Power Distribution Unit 0 Unit? shermaine General Electronics Chat 4 15th June 2005 07:59 AM
