| Hey guys, I am currently building a laser projector using 20K galvonometers. The problem I have, is I need to have a ILDA interface. Using a slightly modified sound card is a very cheap and easy way to do so, so i'm going to attempt it. Basically, the galvo's require a 5V +/- signal into their amps. Using just +5v will work too, but the pattern would be smaller, as the potential is less. Does anyone know how I can amplify the output of a standard USB sound card to 5V? It needs to be as noise free as possible, otherwise I could get interference in the output, and at a speed of 20K, it shows up badly. Any help appreciated
__________________ The 3 laws of science.... 1. If it smells bad, It's chemistry. 2. If it's mushy, It's biology. 3. If it doesn't work, It's physics. www.laserpointerforums.com A forum for disscusion of lasers and laser shows! www.laserchat.org IRC chat for laser and electronic related stuff. Last edited by things; 8th July 2008 at 02:15 PM. | |
| BTW, I realise I wouldnt get TTL yet, but once I can figure out the 5v amp, then TTL modulation will be easy. Thanks
__________________ The 3 laws of science.... 1. If it smells bad, It's chemistry. 2. If it's mushy, It's biology. 3. If it doesn't work, It's physics. www.laserpointerforums.com A forum for disscusion of lasers and laser shows! www.laserchat.org IRC chat for laser and electronic related stuff. | |
| You need simply add an audio amplifier that is capable of putting out 2 watts or more. Have any old stereo amplifiers lying around? Any old junker receiver would be able to do the job.
__________________ RadioRon | |
| Agree with using an old junk receiver. Easiest way by far. Question though: Why does he need 2 watts of output? Last edited by speakerguy79; 8th July 2008 at 10:54 PM. | |
| He doesn't need 2 watts, but he wants a voltage swing of +/- 5 volts peak. If the amp were designed to produce barely just this amount, it would do so into 8 ohms. 5 volts peak is 3.54 Volts rms. The amount of power delivered into 8 ohms with 3.54 Vrms is 1.56 watts. I just rounded up to 2 watts for convenience. Since most audio amps deliver voltage to any load presented, with a source resistance that is typically very low, then an amp rated at 1.56 watts or more will deliver +/- 5 volts into any resistance of 8 ohms or more.
| Oh OK. If he builds a simple op amp amplifier, he shouldn't need more than a mA of current though, should he? | |
| What RadioRon is trying to say is that any cheap powered PC speakers should do it just fine, as long as it can handle 2 watts output into 8ohm speakers. Why build a circuit when you don't have to?
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 9th July 2008 at 06:04 AM. | |
| I found this circuit for driving a Galvo. Gordon McComb's Gadgeteers Goldmine ... - Google Book Search | |
| That's a real common circuit for headphone amps - a push/pull emitter follower transistor pair enclosed in the feedback loop of the opamp. That schematic is the simplest version. The performance/fidelity can be increased by biasing the transistors with diode/resistor pairs (D1, D2, R5, R6 with 100uF caps just to stabilize the voltage across the diodes) and putting in emitter resistors: ![]() It also blocks amplification of DC by putting an electrolytic in the feedback network. This only does 1.5W into 8 ohms off 15V supplies, but some beefier transistors would probably help. If he only needs voltage gain then this is moot. I don't know what it takes to drive a galvo. Last edited by speakerguy79; 9th July 2008 at 06:03 PM. | |
| This does not answer any of your questions, but since your into lasers, I thoght I would share a little project I built with a laser. Simply a laser tube, power supply and 3 motors with mirrors mounted. Regular mirrors do not work. You need the kind used in laser stuff (I can't remember the name). | |
| That sounds about right. They were also made from silver I think. The rear coated mirrors simply do not work. Too much diffraction in the glass. Laser light ends up looking like fuzz. Kinda expensive too. Last edited by Mikebits; 10th July 2008 at 02:16 AM. | |
| Need Help Amplifying Voltage/Signal | LiquidOrb24 | General Electronics Chat | 5 | 30th January 2007 10:38 PM |
| Help in volt amplifying | renaissances21 | Electronic Projects Design/Ideas/Reviews | 3 | 25th September 2005 08:32 PM |
| Amplifying DC Supply | rahul986 | Electronic Projects Design/Ideas/Reviews | 1 | 8th July 2004 07:56 PM |
| Amplifying Voltage from a Photovoltaic cell | rahul986 | Electronic Projects Design/Ideas/Reviews | 1 | 7th July 2004 06:06 PM |
| Help with an amplifying circuit! | dimensionfx | General Electronics Chat | 4 | 5th February 2004 05:16 AM |
