The poor high-side drive isn't unique to Atmel, it's a 'feature' of the 8051 family. So the Atmel 8051 clones are true to the family's features.
The Atmel AVR family does it right. Symmetrical drives like the PIC. |
Thanks for all the replies .
Roff , why you made a voltage driver using the 10k and the 200 ohm , after calculating the output voltage ,it will be approx 4.9 V , what's the wise for that ? |
The AT89Cx051 chips can sink 20mA. |
The 200 ohm resistor R2 applies a base current of 18mA to the darlington to make sure it saturates.
Uncle $crooge |
I was using the presumably worst-case numbers mentioned previously: Vbe=2.5V@Ic=3A, and setting forced beta=250. 3A/250=12mA (5V-2.5V)/12mA~200 ohms. Last edited by Roff; 10th July 2008 at 02:46 AM. |
what's the purpose of R1 in the darlington ? and what is its use in Roff's circuit ?
It is good engineering practice to provide a path for collector-base leakage current, and to discharge base capacitance, providing more rapid turn-off of the Darlington pair when the base current drive is removed.
I've two questions 1st but that scheme will make a voltage divider when the PNP is on , hence there will be a 4.9V on the base of the TIP121 correct ? but how the current will be calculated ?
2nd one is how a uC like 89S52 source and sink two different currents using only one output pin , is it not a simple transistor ? |
(permalink) | ||
Ib=(5-0.1-1.3)/200=18mA, which will ensure saturation of the TIP120. This is more than the 12mA required, but as I explained previously, was chosen assuming the worst case Vbe(on) is 2.5V, as specified in the datasheet. Regarding your second question, the 89S52 is a CMOS part, so it has a push-pull output stage. The N-channel pulldown transistor obviously (to me) is a much larger geometry device than the P-channel pullup (the "push" transistor). Larger geometry devices have more drive capability (lower on resistance). A second factor is that, for equal-sized devices, N-channel parts have about twice the drive capability of P-channel. This is why it can sink much more current than it can source. You never answered this question, which I asked previously: Quote:
Roff, for your question i didnt understand it completley ,im not going to manfucture this product , its just a graduation project and yea we dont have local sources for most electronics parts in the egyptian market .
Roff , how did you calculate the base resistor (3.9K) ?
i think it should be 2.25/1.6mA =1.4Kohm |
The 89S52 can sink 1.6mA. You are not required to run it at that current. The 2N3906 collector current is about 18mA. It is a high beta transistor, and will easily saturate with the ≈1mA of base drive provided by the 3.9k. It will also work with 1.4k, but you will just be wasting power.
thanks , i got this question in my , how the 89S52 sinks current like 1.6mA at 0.4VCC and it should output VOL is zero volt then at the base resistor there should be zero volt so that the PNP turns on , if this is true then how did you estimate your base resistor , you assumed that the base voltage is 0.4VCC should it be 0 volt ?
thanks |
I just assumed the resistor has about 4V across it
how did you assume that and there's a zero volt in the base im so confused |
| Help with transistor as switch | sabotaged | General Electronics Chat | 7 | 10th March 2008 04:16 AM |
| Transistor Switch | Digger7 | Electronic Projects Design/Ideas/Reviews | 14 | 7th June 2007 03:12 PM |
| Transistor Switch.... | NJ Roadmap | General Electronics Chat | 9 | 21st April 2007 12:37 PM |
| Using a transistor as a switch | Mike18 | Electronic Projects Design/Ideas/Reviews | 3 | 28th February 2004 12:22 PM |
| Transistor switch | hantto | General Electronics Chat | 6 | 26th April 2003 01:53 AM |
