audioguru ,Try a few hundred of them and pick the most sensitive one.
i think this is not a good engineering soultion |
I'm also amazed to hear how poor the Atmel is. |
Nigel, how its different between sourcing current and sinking , is that not happens in the same transistor output pin ? In other words, why at VOH it sources so little current at uA and VOL ( sink) it sinks 1.3 mA .. ?
I wonder also about blinking an LED . According to the specs it only sink 1.3mA or so so i cant interface even an LED to it ?? or we read the specs wrong ? Last edited by ahmedragia21; 9th July 2008 at 11:49 AM. Reason: none |
(permalink) | ||
However, I had to go looking at data sheets after reading this thread. Yes, it looks like most of the 8051 -52 atmel chips don't give much for drive, but some of the smaller x2051 x4051 can sink 10 mA, and can source peanuts, like the OP's chip. To be fair, though, the AVR is much better, and close to the pic sink or source 20 mA per pin. Some AVRs provide up to 400 mA total, but most are like the pic: 200 mA total. I had a hard time finding what I wanted in the Atmel data sheets, and much prefer Microchip data sheets. (Some posters were recently whining about microchip data sheets, I think they should give these a go!) |
The PIC is made with high speed Cmos the same as in 74HCxx logic ICs. An output has a max allowed sink or source current of 25mA and can fry the IC with a typical unlimited current of about 60mA.
Maybe the Amtel is made with antique MOS.
Uncle $crooge |
Do you have access to a 2N7000? You can use one as a level shifter, or buffer, to drive either the TIP120 or the IRF540.
A logic N-mosfet turns on fully at 5V?
So why not use one of those? |
I've a question , regarding to the datasheet it cant source more than 60uA , is this means i should use a transistor which its base has a min for e.g 120uA to saturate ?
Roff, sorry we dont have this transistor at the egyptian market Last edited by ahmedragia21; 9th July 2008 at 06:05 PM. |
No, you need a transistor that saturates with a base current of only 60uA.Then the transistor's output current is only 1.2mA. It can drive a transistor that saturates with an output current of 24mA that can drive a darlington transistor.
Uncle $crooge |
Read my previous posts. I already suggested that. He says he doesn't have access to the one I suggested. It is likely that he will not have access to any you could suggest.
Since 89S52 is a CMOS part, its outputs should swing rail-to-rail with no load (the datasheet says 0.9*Vcc @ 10uA source current). The sink capability is 1.6mA at 0.45V, so you should be able to use a PNP as as a buffer. See below.
http://www.irf.com/product-info/data...ta/irf540n.pdf
What ever happened to VN10K's. I always found them to make great switches.
Ahmedragia21, how many of these are you going to build? A good engineering solution is not required for a one-off. If you are going into manufacturing, then your concern is valid. However, if you are going into manufacturing, you shouldn't be concerned about your inability to find a local source.
| Help with transistor as switch | sabotaged | General Electronics Chat | 7 | 10th March 2008 04:16 AM |
| Transistor Switch | Digger7 | Electronic Projects Design/Ideas/Reviews | 14 | 7th June 2007 03:12 PM |
| Transistor Switch.... | NJ Roadmap | General Electronics Chat | 9 | 21st April 2007 12:37 PM |
| Using a transistor as a switch | Mike18 | Electronic Projects Design/Ideas/Reviews | 3 | 28th February 2004 12:22 PM |
| Transistor switch | hantto | General Electronics Chat | 6 | 26th April 2003 01:53 AM |
