Old 5th July 2008, 01:08 AM   (permalink)
Default A decent tube amp? "Worldwide 300B Builders"
Creatron Inc now sells vacuum tubes and the owner Lawrence carries was looking for a good tube amp / preamp to make into kit form. Tubes are NOT my forte but I was Googling and came across this site. Some really nice looking project photos.
http://www.iol.ie/~waltonaudio/worldbuilders.html
Bill
Smart Kits build Smart People
Old 5th July 2008, 02:18 AM   (permalink)
I made a Heathkit tube amp in about 1961. It sounded good when new then got bad.
I took it to a Macintosh Amplifier Clinic and they showed 12% distortion at only half its rated power. I replaced its output TOOBS and had it retested and it was powerful with low distortion. The distortion retuned in a few months.
TOOBS WEAR OUT!
My tube amplifier was Hi-Fi. It didn;t have the high second harmonic distortion of guitar amps.
You can buy very expensive amps with glowing tubes on top. The tubes are for show and are not part of the amp's circuit.
Old 5th July 2008, 02:23 AM   (permalink)
Yeah it seems as though tubes have been revived as Rock guitarist seem to prefer the sound of a good tube amp. I saw a site where the PA tubes sold for like $300. per amp in a pushpull configuration.
Fender GT6550 Tube Tubes at Music123.
Mikebits is offline   Reply With Quote
Old 5th July 2008, 02:28 AM   (permalink)
Don't they still use tubes for radio transmitters?
speakerguy79 is offline   Reply With Quote
Old 5th July 2008, 02:43 AM   (permalink)
Prey tell, why would they? Semiconductors can produce mucho power these days, without the high fail rates of tube devices.
I suppose some old Ham types might just build one to be nostalgic.
Old 5th July 2008, 03:09 AM   (permalink)
There are some huge vacuum tubes made for radio transmitters. Semiconductors can't stand 100kW and more with thousands of volts with hundreds of amps at RF.
Old 5th July 2008, 03:34 AM   (permalink)
3v0
Back in the late 80's I heard talk about an amp that HP engineers had developed for their personal use. The plans were passed from division to division. It was said to to better then anything you could buy but I do not have a clue where to go to find them.
3v0 is offline   Reply With Quote
Old 5th July 2008, 04:18 AM   (permalink)
Well I must confess I was thinking 1KW type transmitters. I really never thought about larger ones. Back in my Navy days, we had a 40KW magnetron that was water cooled. Quite a large setup.
Old 5th July 2008, 07:19 AM   (permalink)
200 KW solid state.
http://www.broadcast.harris.com/prod...edia/dx200.pdf
Old 5th July 2008, 09:09 AM   (permalink)
I agree with the rest, I come from the valve/tube days, and it makes me laugh what people will pay for high distortion, high noise, and poor bandwidth these days
Where valvew amps are usful is guitar amps, because many guitarists are looking for that specific highly distorted sound - but far more actually use transistor amps, and even the valve amp fans often use transistor amps in the recording studio.
What you must NEVER do is run a transistor amp into clipping, as they sound really horrible.
Old 5th July 2008, 03:57 PM   (permalink)
They also fall over themselves to get Allen Bradley carbon comp resistors. The one thing I don't want is something that a) dries out and b) has "voltage coefficients of [insert anything]".
Old 5th July 2008, 04:24 PM   (permalink)
There are some decent solid state amps that can distort just fine.
Clipping opamps sound like crap.
If you aren't afraid of life then you aren't paying close enough attention.
CynicalMan is offline   Reply With Quote
Old 5th July 2008, 04:56 PM   (permalink)
Plus excess noise from any dc current (unlike pure metal resistors which only have thermal noise).
Carl
crutschow is offline   Reply With Quote
Old 5th July 2008, 05:49 PM   (permalink)
They would have to be specifically designed to clip, more an overdrive circuit than clipping the amplifier - it's usually done with clipping diodes in the preamp, and not by driving the output stage past the power rails!
Old 6th July 2008, 02:01 PM   (permalink)
Valve amps are inherently better sounding because they don't generate odd harmonics like semiconductor devices because of the difference in inter-electrode capacitance.
As a youngster we made guitar amps with 120W RMS outputs from 6DQ6 s in push-pull.
These tubes were used in BW TV sets for the horizontal outputs.
If your valve amp kept degrading tubes then their heaters were being run to hot. Some valves had the cathode material coated onto the heater wires and it got depleted by excessive heat. The heater voltage should be 6.3V AC and NEVER higher than 7 Volts.
The anode plates of an audio valve should NEVER glow.
A conclusion, is the point reached when you stop thinking.
Centretek is offline   Reply With Quote
LED "Tube" UTMonkey Datasheet/Parts Requests 4 19th January 2008 05:51 AM
"Miracle Tube" produces more Energy than put in (Yes, another one...) Analog Chit-Chat 7 21st September 2007 12:58 AM
Changing "dark on" switch to "light on" NewUser General Electronics Chat 3 15th September 2007 03:29 AM
when shd i use a "call" and a "goto"? wh picboy Micro Controllers 22 9th March 2005 09:26 PM
What the "JK" means in "J-k flip-flop" windozeuser General Electronics Chat 28 18th October 2004 01:06 PM
