Old 6th July 2008, 02:33 PM   (permalink)
I recall seeing the gas inside the output tubes of my amplifier glowing purple.
Harmonics are distortion. Solid state amps have extremely low distortion, much less than tube amps. The tubes and the output transformer were non-linear. The output transformer provides poor damping of the resonances of speakers. Solid state amps provide excellent damping.
Old 6th July 2008, 03:34 PM   (permalink)
Originally Posted by Centretek View Post
Valve amps are inherently better sounding because they don't generate odd harmonics like semiconductor devices because of the difference in inter-electrode capacitance.
So 0.001% odd harmonic distortion from a transistor amp sounds worse than 10% even harmonic distortion from a valve amp? - I don't think so!
Old 6th July 2008, 03:48 PM   (permalink)
A single-ended tubes or transistors amp produces even harmonics distortion. When they are operated push-pull then the even harmonics cancel and the result is a form of compression of the higher currents which results in odd harmonics distortion.
The phase-shift in the output transformer of a tubes amp limits the amount of negative feedback that is used so the distortion is much higher than a transistors amp.
LED "Tube" UTMonkey Datasheet/Parts Requests 4 19th January 2008 05:51 AM
"Miracle Tube" produces more Energy than put in (Yes, another one...) Analog Chit-Chat 7 21st September 2007 12:58 AM
Changing "dark on" switch to "light on" NewUser General Electronics Chat 3 15th September 2007 03:29 AM
when shd i use a "call" and a "goto"? wh picboy Micro Controllers 22 9th March 2005 09:26 PM
What the "JK" means in "J-k flip-flop" windozeuser General Electronics Chat 28 18th October 2004 01:06 PM
