Old 4th July 2008, 12:04 PM   (permalink)
Default Substitute for 2N2222
I have seen many circuits using the 2N2222 transistor (correct me if it isn't one). one of them uses it to control electrical appliances. It says it can be substituted by a BC148. So I just wanted to know can the BC148 be used as a general substitute for 2N2222 or is it just the case in this one?
Here's the schematic
http://www.electronic-circuits-diagr...rsimages/1.gif
Any help would be appreciated.
Thanks in advance
Help me enlarge my army, Click Here!
ashfaqueahmadbari is offline   Reply With Quote
Old 4th July 2008, 12:43 PM   (permalink)
Thanks in advance
You can get both datasheets from DatasheetArchive :: Free Datasheet Search Engine :: Electronic Components
and compare the specification.
Check the Ic's max rating, 100mA BC148 and 600mA for the 2N2222
Old 4th July 2008, 01:10 PM   (permalink)
The 2N2222 can be replaced without problems by the BC337. The 2N2222 has a TO18A package (similar to TO92, but metal can) and the BC337 has a TO92 package. That one can handle up to 800mA.
Boncuk is offline   Reply With Quote
Old 4th July 2008, 02:21 PM   (permalink)
@ashfaqueahmadbari
You may use 2N3904
Regards,
Sarma.
mvs sarma is offline   Reply With Quote
Old 4th July 2008, 11:57 PM   (permalink)
The BC148 was used 44 years ago. I have some. It has discontinued about 34 years ago.
The latest one is the BC548 in a TO-92 case.
The 2N3904 is the same but its collector and emitter are reversed.
Use a 2N4401 if you want the same high output current of an old 2N2222.
Old 6th July 2008, 11:28 AM   (permalink)
Im a big fan of the 2N4401!
Also, just incase your ever wondering, the 2N4403 is a good pnp solution with similar specs
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline   Reply With Quote
Old 7th July 2008, 02:29 AM   (permalink)
You may use 2N3904
In the OP's circuit this is true because it only needs to pass 60 mA. However the 2N3904 is not a universal replacement for 2N2222 because of a lower current rating.
mneary is offline   Reply With Quote
Old 7th July 2008, 03:14 AM   (permalink)
If you need to drive lots of current, use a ZTX649, but I would not reccomend it as it is very expensive.
Krumlink is offline   Reply With Quote
Old 7th July 2008, 09:18 AM   (permalink)
It also has a slightly lower GBWP but this isn't important here.
Screen name: Aloone_Jonez
Old 7th July 2008, 09:28 AM   (permalink)
I wonder where you live? If you cannot find 2N series there then you never cannot find a BC148 series out there.
The BC148 is very old as Audio mentioned but 2N series is commonly available.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is online now   Reply With Quote
Old 7th July 2008, 02:05 PM   (permalink)
They may be commonly available where you are, but BC series transistors are commonly available in Europe, which is where they come from - far easier than non-European 2N series.
Old 7th July 2008, 06:21 PM   (permalink)
BC 148/158 were also manufactured in India and now a days, we get BC547/BC557 and BC548/BC558- in local make as well as Philips, in TO92 case.
the 2N2222 and likes are also made In India and from Taiwan.
Industrial usage, they prefer metal can and for commercial, TO92.
Regards,
Sarma.
Old 8th July 2008, 04:12 AM   (permalink)
Nothing to worry where the transistors came from.Job,price & availability is more important.
2N series more common than some BC series (BC148) including OP has "seen many circuits using the 2N2222 transistor"
Gayan
My Website
Old 18th July 2008, 12:52 PM   (permalink)
That's not an IC, it's an opto-coupler. Just thought i'd let you know.
Old 18th July 2008, 10:19 PM   (permalink)
It's a transistor!
2N2222 Output Characteristic Harros Datasheet/Parts Requests 1 8th March 2008 02:08 AM
Possible to Replace 2N7000 with 2N2907/2N2222? Krumlink Electronic Projects Design/Ideas/Reviews 16 4th January 2008 07:05 PM
2n2222 watzmann General Electronics Chat 14 18th December 2007 01:20 AM
What is best BC547 or 2N2222? Suraj143 Micro Controllers 9 1st November 2007 07:37 AM
An optoisolator replacement for 2n2222 William At MyBlueRoom General Electronics Chat 2 14th May 2006 04:51 AM
