Old 3rd July 2008, 08:46 PM   (permalink)
Default Temp Sending units for engines
I have an engine that has water temp, hydraulic temp, lube oil temp and trans temp. These are all installed with sending units that have been matched to the gauges. I want to hook up a PLC with a HMI to read these levels. Do I have to have seperate thermalcouples or rtds or can I use one signal for two inputs?
aarotech is offline   Reply With Quote
Old 3rd July 2008, 09:08 PM   (permalink)
You'd have to separate them since they use require different circuitry and processing anyways if you were connecting the TC and RTDs directly.
But, you say sending unit. What's a sending unit? Something that processes the sensor readings and sends out a digital signal? You could share them if they used a serial protocal that allowed for networking/addressing.
NO, that picture isn't me so don't bother asking if we can be friends.
Old 3rd July 2008, 09:37 PM   (permalink)
Default Impedance matching
These meters and the Temperature sending unit are impedance matched at the factory.
Old 3rd July 2008, 09:54 PM   (permalink)
What does a sending unit *do*?
Old 4th July 2008, 12:48 AM   (permalink)
A sending unit is the sensor that monitors temp, pressure,etc..
They usually are a varying resistance for gauges ,or a set of contacts for a indicator light.
I'm no authority but I think if you try to tie the gauges to the plc via sending units, neither will work properly.
gerty
gerty is offline   Reply With Quote
Old 4th July 2008, 01:02 AM   (permalink)
Hi.
You should be able to read the existing sending units with your second PLC-whatever circuit paralleled to them if its input channels resistances are high enough (like 1mΩ?)
Miguel
Abolish the deciBel !
Externet is offline   Reply With Quote
Old 4th July 2008, 05:39 AM   (permalink)
3v0
I think each automaker may have different specs for their sending units (sensors). You need to search for info specific to the make and maybe model of car you are working with.
This page is about temperature and fuel tank sensors.
If you want to get better help here you need to tell us exactly what you are working with.
3v0 is offline   Reply With Quote
Can I parallel up two of the same UPS units? jjj Electronic Projects Design/Ideas/Reviews 3 29th March 2008 01:54 PM
UV Exposure units Trevor Rymell General Electronics Chat 7 29th November 2005 01:41 PM
2 headset units for usb chefach Electronic Projects Design/Ideas/Reviews 4 7th November 2005 07:43 PM
digital fuel control unit for aircraft gas turbine engines jere Electronic Projects Design/Ideas/Reviews 6 18th June 2005 06:37 AM
GPS Engines Scarr General Electronics Chat 4 23rd September 2004 12:17 PM
