I was asked in a PM about lead spacing on IC's. They are too wide from the factory. Prior to getting this tool I used to press them against the table top to make them fit. Fuzzy image shows what you need to see. Not sorry deal with it
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 3rd July 2008 at 06:38 PM. |
I use long nose pliers to bend em one side at a time. Not very pretty though.
NO, that picture isn't me so don't bother asking if we can be friends. |
I used to lever them them into place one side at a time... I also used to pull them out of my finger on occasion lol..
Other useful tools.. I have always found that a good size lump of "Blu-Tak" (about the size of a golf ball) makes for a most useful extra pair of hands when dealing with small circuit boards or as a secure place to put smaller items such as screws and other small easy to lose items when doing repairs. A small bead of it on the end of a pencil ( or anything else close at hand) also makes for an improvised "pick & place" tool when dealing with surface mount devices.
It may seem like a good idea at the time , but never stir your cold coffee with a soldering iron. Last edited by The Mad Professor; 3rd July 2008 at 07:12 PM. |
You got a P/N on that guy? I also use the table-bending method on DIP packages.
Why do they spread the leads like that? I notice my jumper wire kit for my breadboard does the same thing on the wires. Is it done to DIP packages for automatic insertion or retention reasons before wave soldering? That's the only thing I could think of. The $5 cutters available at Techni-Tool and at variety of other vendors are indispensable as lead cutters. I think they also get branded as Xcelite and several others I can't remember. They're all about $5 and make excellent lead cutters. Mouser sells red plastic lead benders for axial resistors, diodes, etc. A must-have if you do a lot of breadboard work as you can get exact bends on all .1" spacings, and a right angle bend on the lead helps in sticking a probe clip on the lead. The Soldapult DS017 is the only solder pump extractor worth owning. OKi sells the same thing branded as their own, as does a third company I can't remember. Fry's carries them as does practically any online vendor. A pair of Pakistani EROP-AASA tweezers from Digikey are excellent fine tweezers for only $3 a pair. You can get the Italian made version from Mouser for $8 if you are placing an order there. Any blunted tweezers are great for putting in/pulling out jumper wires on breadboards, especially the single links. I use a pair I took out of the medicine cabinet that were next to the fingernail trimmers. A set of six small phillips and small straight screwdrivers are indispensable. Available at lots of vendors. Multi-turn cermet pots are nice to have on hand to get a particular resistance value if you don't have that value of resistor laying around. I like the Bourns 3296 series, but that are expensive. I have maybe a half dozen in various values. An old toaster oven makes a great reflow oven if you find yourself having to use a leadless (QFN, DFN) package (or one with a heatsink pad on the bottom). |
tweezers? I use curved tip hemostats. They work a lot better for me and you can lock them closed if you want. The curved tip allows for better control of SOICs and other SM components.
For general bending and prodding of wires and leads, I have a tool that is like a straight double ended dental pick but fatter. One end is just pointed while the other has a slot that goes down the middle (bisecting the tip lengthwise for about 200 mils). Its great for making precise bends in wires, TH leads, and generally manipulating wires on a breadboard. I think it cost me $.99. I've never seen it again in stores. I use a panavise all the time. |
(permalink) | |||
I have a gold colored metal solder sucker I found in a abandoned toolbox at work. I do not have a clue who made it but it has such a powerful spring that it make a loud noise and jumps when you trigger it. None of my students want to use it. They prefer the mild mannered plastic one from Radio Shack.
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) |
I've never met a plain solder sucker that I liked. There's a powered one from radio shack that does fairly well on large solder joints. The tip is heated and melts the solder, then you release the bulb and it sucks it up.
I still hold out hope for a solder station with a desoldering pump, but having never tried one, I can't say for certain. That being said, I just tried the best desoldering braid I've ever used last week from a company called Chemtronics. Unfortunately, it was at a client site and I only wrote down the company name not knowing they sell 8 different types. It had this really tight weave that kept it from unraveling yet still sucked the solder right up. Helpful tip on desoldering braid: It goes bad. The flux evaporates over time and I've bought more than one spool from discount surplus places that were pretty damned bad right out of the package. However, you can generally bring them back to life by squirting on a tiny bit of liquid flux or even rubbing on a little bit of gel-type flux. |
Here's a handy tool. Heat resistant, cheap, easily adapted. The one on the left has grooves to hold servo wire while soldering to header connectors. The one on the right is used to hold all sort of things in place while soldering.
John |
Abolish the deciBel ! |
I'm about to buy a rework station, but I am leaning towards iron + tweezers since I am going to try and make myself stick to SMT devices as much as possible. Removing SMT resistors and caps is a terrible pain. The only through-hole devices I plan on using are things like molex connectors, power resistors, relays, etc. Anything really expensive (uC's, DAC's, modern stuff) will be SMT and I think I might get a hot air station for that. |
And hemostats? Really? What packages are they useful for? I can't imagine not having my Erem tweezers, especially for chip resistors and SOT-23 type stuff.
I have hemostats, but don't use them very often for PCB, because they are usually a magnetic alloy and become easily magnetized. Some parts (like capacitors) will stick to them. John
Hemostats are handy for desoldering components. Just clamp onto a lead, turn the board
over,apply heat, and the weight of the hemostats usually pull the component free.
gerty |
I have always found this tool useful for my most troublesome problems.
And for very big problems use this one:
| AVR Tools GCC compiler help? | HarveyH42 | Micro Controllers | 12 | 5th November 2007 10:24 PM |
| Handy PIC MultiCalc link I found recently | blueroomelectronics | Micro Controllers | 5 | 26th April 2007 01:58 AM |
| Handy Free Datasheet Site | rmn_tech | Datasheet/Parts Requests | 1 | 23rd August 2006 02:34 PM |
| TOOLS FOR THE JOB | ODIN'S DEN | General Electronics Chat | 3 | 6th September 2005 07:40 PM |
| know about testing tools | arun_dexter | General Electronics Chat | 1 | 15th May 2005 06:55 AM |
