Old 3rd July 2008, 06:37 AM   (permalink)
Default Schematic capture, design, etc?
I'm looking for a simple program just to draw up roughs schematics so
when I ask for assistance on a project I can show a schematic of what I'm doing. I don't need a simulator, I have one, but its schematic output sucks.
The other problem I have I tried using Eagle for this, but I can't find a lot of the circuits I use. For instance, I wanted to draw my motor controller but I cant find anything resembling a High/Low bridge driver chip to add to the circuit so that
people would know if I connected it correctly..
Ideas?
HellTriX is offline
Old 3rd July 2008, 06:49 AM   (permalink)
Ideas?
For general purpose use, the expresspcb [freeware] also comes with a schematic package. Google for expresspcb
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
You need to learn a package such as Eagle, it has a library editor where you can create your own symbols. This is something you must learn to do. Once you know how, it is no big deal. At my last job, we had a dept, that all they did was make library symbols for our CAD circuit software. Your lucky if your CAD package has basic TTL and CMOS symbols. Just grin and bear it, learn the symbol editor.
Mikebits is online now
Old 3rd July 2008, 07:00 AM   (permalink)
There is always going to be a few parts you can not find. Regardless of the package, you need to learn to make your own parts. Eagle has a fairly wide user base and often you can find the part you need on the web. But if you make it yourself, you can build the schematic part symbol to look exactly as you want.
There are several tutorials on building an Eagle part.
Ideas?
3v0 is offline
Old 3rd July 2008, 07:03 AM   (permalink)
To illustrate this point. In my schema program, I wanted a funky looking symbol, so I made it myself. As shown. Cool part here is you put your creative talent to work. Just be sure to define inputs, outputs, etc.
It was a foot pedal switch I believe.
File Type: gif symbol.gif (619 Bytes, 11 views)
Old 3rd July 2008, 07:59 AM   (permalink)
Wow so many replys in short time.
I just learned how to import libs into eagle. Didn't realize how many they had available on their web page too.
here is my first schematic using it:
Link Here
Tnx for the replys.
HellTriX is offline
Old 3rd July 2008, 08:04 AM   (permalink)
Looks like your learning, but you need to know when to terminate a wire. There should be connection dots where a wire terminates into another wire, also you have wires running through your components such as your diodes. But do not despair, these things can be corrected.
Old 3rd July 2008, 06:12 PM   (permalink)
Did I get carried away with dots? or is this about right?
HellTriX is offline
Old 3rd July 2008, 10:59 PM   (permalink)
I made some suggestions in the image below. See pic.
Old 4th July 2008, 01:49 AM   (permalink)
Thanks!
I will kill the angles. Won't use dots on all the parts
As for the diode, that was just one of the styles in eagle, the line through it was part of their image, guess it looks misleading. I will try to use a different style next time. Maybe something more standard. (I built it hurriedly so I just grabbed the first ones I saw hehe)
tnx again
HellTriX is offline
Old 4th July 2008, 03:35 AM   (permalink)
One thing I do not understand. I would think your schematic capture package would automatically put the connection dots as needed instead of you having to do it manually.
I have never used Eagle, so maybe that is the way it is. Is it possible that there is a config setting somewhere to set that. If not, then I would not like Eagle too much.
Maybe 3V0 can explain.
Old 4th July 2008, 04:49 AM   (permalink)
The dots indicate junctions. They are present where two wires meet but not where a wire meets a pin (circle). They are automatic as suggested by Mikebits.
You can also place a junction most anywhere by selecting it from the tool bar. Infrequently used.
You should not have a junction where a single wire meets a pin. Use the zoom tool to find the extra wire and delete it. If you have to delete the wanted wire too and redraw it.
If you are unsure if a wire is connected to a pin you can grab it and try to move it. If the wire does not move away from the pin it is connected.
When you are learning keep the wires vertical or horizontal. Do not use the right mouse button or the icons on the tool bar to draw angles or curves.
3v0 is offline
Old 4th July 2008, 05:10 AM   (permalink)
3V0, why did his wires not auto connect at the junctions in his first schematic that he posted. Could he have used a line tool meant to make text notes etc, instead of using a make connection tool?
Does the program have a (DRC) design rule checker?
I guess I should DL a copy.
Old 4th July 2008, 05:18 AM   (permalink)
Unless HellTriX zips up a copy of the eagle schematic file and attaches it to a post I can only guess at what he is doing. I should have suggested that.
The schematic editor has an ERC tool which checks for unconnected pins etc. The layout editor has a DRC tool which checks for layout rule violations.
Eagle just released a update.
3v0 is offline
Old 4th July 2008, 05:20 AM   (permalink)
I Just DL a copy and will try it out, I am sure it is like most. I noticed the website has a library section. Have you encountered many errors in the symbols from the user lib section?
Schematic Capture & PCB software DSGarcia General Electronics Chat 0 24th July 2007 05:09 PM
Good Program for Design Schematic? Tom McCurdy General Electronics Chat 10 10th December 2004 04:13 AM
Design a schematic get a FREE PCB !!!!!! TVP Micro Controllers 3 24th February 2004 11:44 AM
what is close capture? bogdanfirst Electronic Projects Design/Ideas/Reviews 1 1st April 2003 05:47 PM
pcb design source(cd ) single layer schematic & layout d vijaya General Electronics Chat 2 6th February 2003 04:45 PM
