No but others have found errors. Unless a part is rarely used I think people would report problems. Maybe I have been lucky.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | ||
| Using latest Eagle. Shoot, I ran into the same issue. I looked into the settings, I have auto junction set to on. I placed 3 devices on the page, connected two pins from device A to device B, then tried to connect a pin from device C to the wire from A to B and no visible junction dot. I then right clicked wire at device C, clicked on properties and named the net as Fred. Then I checked attributes of wire A to B, it also had the net name Fred, so I know they are connected, but no dot is seen. So how do I make that darn dot visible? | |
| Ok, here is a test schematic. I just used the wire cmd, no dot. ??? | |
I looked for options to auto junction dots but couldn't find anything. I did zip up the schematic but guess its not required now. Side note: I use Windows Vista Ultimate 64bit edition in case there may be a bug while in this OS. Last edited by HellTriX; 4th July 2008 at 08:18 AM. | ||
| Do not draw wires. Use the net command and draw nets. Icon three down from T (for Text).
| Awh! K there we go Thanks! | |
| I agree. There is a similar problem in the board editor. Most people who learn the system via trial and error will stumble into these things. It is best to start with a tutorial.
| Thanks 3V0, you da man Function Adds wires (tracks) to a drawing. Well that explains it... | |
| I suggest you ignore it. Both in the schematic editor and in the board editor. Use the net command to draw wires on the schematic and route to places the traces in the board layout.
| But..but... It is just bugging me, I have to know. There must be a reason But you are right. Ignore it may be best thing. But still... | |
I would like to figure out a way to add VSS and VDD layers witout buying the $500 package. Not that I need it. I just want to play
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 5th July 2008 at 01:36 AM. | ||
| Schematic Capture & PCB software | DSGarcia | General Electronics Chat | 0 | 24th July 2007 06:09 PM |
| Good Program for Design Schematic? | Tom McCurdy | General Electronics Chat | 10 | 10th December 2004 05:14 AM |
| Design a schematic get a FREE PCB !!!!!! | TVP | Micro Controllers | 3 | 24th February 2004 12:44 PM |
| what is close capture? | bogdanfirst | Electronic Projects Design/Ideas/Reviews | 1 | 1st April 2003 06:48 PM |
| pcb design source(cd ) single layer schematic & layout d | vijaya | General Electronics Chat | 2 | 6th February 2003 05:46 PM |
