OK, so I got my new DPO3000 scope.
On DC and AC coupling, full bandwidth mode, probes shorted tip to ground clip, I get 20mv to 40mv pk-pk sinusoidal noise around 80-100MHz, all channels, all probes. It seems to vary as I move a probe around, as if acting like an antenna. If I GND couple a channel, it totally disappears, absolutely no noise. We do have a problem with a nearby radio station or other broadcast that really messes up our channel 12 reception on cable TV (USA, NTSC). We have some regular coax feeds to some TV's and those suck, and then we have some super shielded coax in the newer part of the house and those TV's are better but still very noise picture on channel 12. Could my channel 12 problem be the same thing the scope is seeing? I was disappointed to see this much noise on all channels, all probes unless I am GND coupled (and then it totally disappears). I might have to trek across town and plug it in and do the same test. Any help is appreciated! |
Or you could fire it up inside a steel shed and see what happens.
NO, that picture isn't me so don't bother asking if we can be friends. |
Sounds like you may be picking up an FM station which operate in the 88MHz to 108MHz region. The scope probe is apparently acting as an antenna. Do you see a signal with no probe connected to the scope?
Try connecting a length of plain wire to the scope input. Does the scope signal increase? If so that also indicates it's being picked up as an antenna. Channel 12 is at 205MHz but you could be seeing a harmonic of the 100MHz signal in you TV. The only legal ways to get rid of the interference are to wrap your house in a faraday shield or move. Cutting the cable to the tower is frowned on by the legal authorities.
Carl |
My bad, ignore previous 80-100MHz comment. I was counting roughly two cycles per time division and thought I had it on 20ns/div but it was actually 10ns/div. The memory storage length was also set too long so the DPO part wasn't looking quite like an analog scope would (sort of persistence-y). The persistence-y look helps see the sinusoidal nature.
So instead of guessing I actually turned on the frequency measurement and knocked the mem length down to 10kpts. The frequency measurement bounces around a little but sure enough it centered somewhere just above 200MHz - CATV channel 12 is 204MHz and that's our noisy channel. There is some broadband noise when the input is turned on but no probe connected. Please see attached screen shot for what is going on... I had to zip it because the board won't accept TIF files. CH1 is GND coupled shorted probe, 2 is no probe connected DC coupled, 3 is AC coupled shorted probe, 4 is DC coupled shorted probe. Triggering on CH3 but 4 is pretty plainly the same signal. Last edited by speakerguy79; 2nd July 2008 at 07:24 PM. |
Confirmed on a local web forum that the transmitting tower two blocks from me is broadcasting Channel 12.
Also, if you have trouble opening the TIFF, try using Microsoft Office Picture Manager. So is lead paint still available? Last edited by speakerguy79; 2nd July 2008 at 08:34 PM. |
Won't the end of Analog TV at the end of the year solve your problem?
Carl |
To convert to digital he would, of course, have to buy digital TV's or rent a digital cable box(s).
Carl |
Sounds like a mandate to me.
Senate approves 2009 for end of analog TV - MSNBC Wire Services - MSNBC.com |
Back to the scope thing...
I went to my Dad's office building tonight. In the hallway on the bottom floor of a 4 story building I plugged into a wall outlet. All signs of the 200MHz sinusoidal waveform were gone. The only thing left was 12.2mv pk-pk broadband noise, which still seems high to me but this building has flourescent lights, etc all over the place. GND coupling the channel made it totally clean. 12.2mv seems a little high to me, what about you guys? I also have a little DC offset (about 3mv) but I think that can be corrected for with the scope. All this work was done on 10mv/div scale. |
Any scope probe will pick up stuff out of the air. "Grounding" the scope probe only eliminates the signal under some circumstances. It often just creates a pickup loop. In your case, 204 MHz has a 1/4 wavelength of about 30 cm, which is probably shorter than the length of your probe cable.
This is your (unwanted?) opportunity to learn more about RF. Myself, I find it fascinating. You can experiment with loops that pick up the 204 MHz even better. This sounds silly, but in the end you'll learn how to suppress it, too. Suppressing unwanted pickup from an external field generally involves minimizing the total loop area between 'signal' and 'ground' (neither of which are absolutes). Although analog broadcasting is supposed to cease in February 2009 (USA) the channels will eventually be sold to others who will replace the current QRM with their own. Cable TV in the US is not required to stop distributing analog signals in 2009. It's their cable and they can use the bandwidth as they wish. They cannot broadcast analog signals, but this is no different. They were never allowed to broadcast anything. There are strict rules requiring them to confine the signals to their cable. Lead paint isn't electrically conductive. |
What your talking about is what we use to call a sniffer probe.
Back to your regularly broadcasted post Last edited by Mikebits; 3rd July 2008 at 03:33 AM. |
(permalink) | ||
| Tektronix 2246 Scope Problem | Mendoza | General Electronics Chat | 8 | 23rd March 2008 04:38 PM |
| MADELL O-Scope question | Ambient | General Electronics Chat | 2 | 24th March 2007 04:01 PM |
| rookie scope question | chancecasey | General Electronics Chat | 26 | 25th January 2007 04:04 AM |
| Quick question/problem on a BCD counter. | czwalga | Electronic Projects Design/Ideas/Reviews | 4 | 13th August 2006 11:27 PM |
| HV scope probe question | Oznog | General Electronics Chat | 1 | 13th October 2005 11:56 PM |
